Insert funny comment.
![]() Join Date: Dec 1999
Swapping in a 10 bolt into a 68 C10
I have a nicely built 10 bolt I pulled out of my 86 IROC (3.73 gears and Auburn Pro Posi) . Will I be able to drop this into my 68 C10. I have the trailing arms / coil spring setup. Does anyone make brakets to mount it to the arms and brackets for the panhard rod?
Thanks ( I wish I could search on this board. Anyone know if it will ever be turned back on?)
------------ - Mark -My Build Thread... -68 C10, LT1 - Undergoing Frame off resto -86 IROC-Z T72 turbo 355, M6 -70 Camaro http://www.iroc-ss.com |
![]() Join Date: May 2002
you might want to try your local trailer supply shop. they might have something for you.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
CCRider
Chevyduty has a kit in their catalog...I'm sure other vendors have it as well.
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Wiseass secured himself a BAN
Why don't you sell the 10 bolt rearend and buy a 3.73 posi gear set for your 12 bolt rearend. I think the way you are wanting to do it is a hard way.... JMO
Fabricate till you "puke"
It would be easier to go for the truck pcs, but I think the strength/weaknes to be found will be in axle spline/diameter.....you will also be on a 4.75 bolt circle, vs the 5 on 5 on the truck(71 up). Here is a link.. http://www.classicperform.com/produc...ersion-Kit.htm good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
