Old 05-09-2012, 11:36 AM   #1
gmech
Which Cummins to put into my truck?
I am seriously thinking of putting a Cummins into my 79 1 ton 2wd CCSWB project. I definatly want an automatic trans with overdrive. What I would like is input on what you all like and any other helpful info. Id like to keep away from all the electronics if I can. Plan to use the truck for everyday driving and towing.
gmech is offline   Reply With Quote
Old 05-09-2012, 11:45 AM   #2
v30crewcab
v30crewcab's Avatar
Re: Which Cummins to put into my truck?
94-98 is best for power, they have the p-pump. 89-93 has the ve which gets 1-2 mpg better supposedly.
for auto you'll want a 94-95 47RH. only electrical on it is a 12v switch for overdrive and lockup, which you can control with two switches, or use pressure switches on the trans to do it automatically.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-09-2012, 02:07 PM   #3
gmech
Are the 89-93 and the 94-98 the same except for the pumps?
Old 05-09-2012, 06:19 PM   #4
86c20
86c20's Avatar
i think that the cummins wiring is the ezest out there. if you can get a motor with the ecm that is a runner on stand you will see it is only i few wires that you need to run. i am thinking about runnning a commin rail in my 85 k30. just for something diff
86c20 is offline   Reply With Quote
Old 05-09-2012, 10:57 PM   #5
yousesteers
I am running a 96 p-pump in my 84 only wire you have to have is to the starter. I ran a fuel shutoff relay to operate the electric solenoid but fuel shutoff can be controlled by a cable. I run a 5 speed trans so am no help there.
Clint Youse
Paris, MO
1984 Chevrolet 3+3 K30 with Cummins
1966 IH Scout has been a work in progress for 16 yrs
yousesteers is offline   Reply With Quote
Old 05-09-2012, 11:36 PM   #6
1774btcrew
1774btcrew's Avatar
I say 4bt but I guess I am just partial to them since that is what I have in my truck. Not as easy to come by as the 5.9 but quite a bit lighter and fits in the engine bays nice. We have done both 5.9 and 4bts conversions. My 2wd CCSB seems pretty well balanced as far as weight goes to and it rides really nice.
1774btcrew is offline   Reply With Quote
Old 05-10-2012, 12:18 AM   #7
mikev
mikev's Avatar
Is that converted to 1/2 ton as well??
mikev is offline   Reply With Quote
Old 05-10-2012, 01:17 AM   #8
andrewmp6
A 4bt will be better as a driver and can handle most smaller loads like a 1/2 ton could pull.If your gonna use it as a 1ton i would get a 12 valve then.On the trans a dodge one will be easier but you might have to mess with the trans crossmember and have a driveshaft made.The pricey way with a auto is a adapter kit and run a 4l80 with a controler.You can get the motor mounts from http://www.tndieselpower.com/site/products-page/ or http://www.autoworldmt.com/Page_11.html has a lot of nice stuff.
Old 05-10-2012, 01:26 AM   #9
63chevyll
gets board easy.......
63chevyll's Avatar
Ive had a hard time looking for a Cummins lately. Not many out there.
Are you having any luck finding in your area?
63chevyll is offline   Reply With Quote
Old 05-10-2012, 09:26 AM   #10
1774btcrew
1774btcrew's Avatar
We did convert it to a half ton which was the easiest part of the build. I am running a compushift controller for the 4l80e and love it. You can program it for almost anything
Old 05-10-2012, 10:02 AM   #11
gmech
Is the 4l80e a better trans than the 47rh?
I only know of 1 right now for sale. I beleive its an 94 with an auto trans and transfer case for $1200. Its suppose to have 87,000 miles on it. Something is wrong with the trans though.
Thanks for the input.
Old 05-10-2012, 10:24 AM   #12
Edahall
The 88-93 Cummins have VE injector pumps. They are good for about 450 hp. The biggest advantage of this model engine is they're quieter and get slightly better fuel economy. The Cummins under the hood of my 1990 Suburban hardly makes any more noise inside the cab than the anemic 350 that was ripped out. Another advantage is these engine usually go for about $1k less.
The 94-98.5 Cummins have P-pumps on them. The pump can supply enough fuel for roughly 1000 hp. The huge power potential is the big advantage with these engines. It can make enough power to rip apart the rest of the drive train in no time.
Not really. A 6BT Cummins will rip it apart just as fast as the 47rh. If you have to have an automatic and want some reliability, look into having the 47rh upgraded. It'll be very expensive (around $6k) but worth it IMO.
1990 ¾ ton 4x4 Chevy Suburban
-Cummins Diesel - 12 valve - factory rebuilt
-6 speed bullet proof manual transmission - NV5600
-Gear Vendors Overdrive - HX35 Holset Turbo
-NP205 iron transfer case
-3.73 gears -2" Lift
Edahall is offline   Reply With Quote
Old 05-10-2012, 10:27 AM   #13
1774btcrew
1774btcrew's Avatar
I have had a 4l80e behind my Cummins for 5 years with no issue's.
Old 05-10-2012, 10:36 AM   #14
Edahall
Is the 4L80e behind the Cummins 4BT?
Nice conversion by the way. What kind of fuel economy are you getting with the 4BT?
Old 05-10-2012, 10:44 AM   #15
1774btcrew
1774btcrew's Avatar
It is behind a 4bt . Not the fastest truck in stock form. It tops out at about 85mph but will pull any hill at 65 so it is good enough for me. I get 26 highway with 3.73 gears.
Old 05-10-2012, 12:09 PM   #16
tucsonjwt
Just curious - why not just by a RAM truck with a Cummins already installed?
tucsonjwt is offline   Reply With Quote
Old 05-10-2012, 12:13 PM   #17
92GMCDriver
92GMCDriver's Avatar
everyone talking about the 12 valve p pump cummins... why not a 24 valve with the p pump conversion? would that not make more power?
Cole.
1967 GMC c15
1991 k2500
2005 2500hd Duramax
92GMCDriver is offline   Reply With Quote
Old 05-10-2012, 02:19 PM   #18
Edahall
P-pump conversion is done on a 24 valve to make more power. You would think 24 over 12 valve would make more power however, with forced induction, there is not much advantage in terms of power with having more valves. That said, I would be careful with a 24 valve block. They are known for the blocks cracking. Do a good on "53 block crack" to find more about it.
Old 05-10-2012, 02:20 PM   #19
Edahall
"Love the engine, hate the truck".
Old 05-10-2012, 08:12 PM   #20
gmech
How about an Allison. I imagine it would be pretty costly.
Old 05-10-2012, 08:18 PM   #21
yousesteers
Ram tuck drives terrible and it is not hard to do a conversion.
Today 09:02 AM
A guy can put an Allison 1000 behind them with a stand alone controller.
I bought a complete truck it was the easiest I had a lot of the little knick knack pieces that one does not think about until they need them I found one that the drive train was pretty decent on but the body was shot.
Right now I got about $1200 in my complete swap but I still have the Dana 70 Front and Dana 80 Rear Axle that should cover part of that expense. I parted the rest of the Dodge and crushed all that was left.
Clint Youse
Paris, MO
Old 05-10-2012, 09:09 PM   #22
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Cause who wants a dang dudge? I work on them all the time and they are rattle traps. Great power train and drive train, crap body!
Ryan
1969 Chevy milk truck
Old 05-10-2012, 09:12 PM   #23
Dieselwrencher
Not all 24v blocks are the 53 blocks. Beware that the early storm 53 blocks were also used in late 97 and early 98 12v's too. There are 2 versions of 53 blocks and I've seen plenty of 53 blocks that never cracked.
As far as the heads, yes the 24v heads flow more air in stock trim and tend to make more power on mild builds. Once you hog out a 12v head, it's hard to beat them though.
I also agree the 47rh is the auto trans to run behind these.
Ryan
Old 05-10-2012, 09:23 PM   #24
nekkidhillbilly
if i where going to spend the money on a allison 1000 and stand alone.......id just get a duramax allison combo. its not that much more wiring.
nekkidhillbilly is offline   Reply With Quote
Old 05-10-2012, 09:25 PM   #25
joe231
joe231's Avatar
Pics of the engine bay, please?!?!
CHEVY ONLY
joe231 is offline   Reply With Quote
