Old 05-11-2012, 10:11 PM   #1
cory d
cory d's Avatar
cutting down a drive shaft
I know its possible but is it a good idea? is there a driveshaft that can be used for a crew cab short bed like a long bed extended can off 88+ or even 73-79 ferds? i was thinking of chopping out and chunk with a chop saw and having a buddy who is a pipe fitter weld it up.
cory d is offline   Reply With Quote
Old 05-11-2012, 10:15 PM   #2
ghettoluxury
ghettoluxury's Avatar
Re: cutting down a drive shaft
Take it to a local drive line shop and tell them how much shorter you want it to be.
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 05-11-2012, 10:16 PM   #3
cory d
cory d's Avatar
sounds like it will cost me an arm and a leg but if its the only way then i guess i dont have a choice. i'll look into that
Old 05-11-2012, 10:29 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Go to driveshafts nw in Everett. They have great prices and do an awesome job as well
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-11-2012, 11:24 PM   #5
cory d
cory d's Avatar
is that the place by the train station?
Old 05-11-2012, 11:27 PM   #6
cableguy0
Driveshafts have to be right. They have to be balanced and they need to be exactly straight. Your buddy might be a great welder but pipe sits still. Driveshafts spin at engine rpm. If you ever saw a driveshaft break at speed you wouldnt be asking this question. Driveshaft work is relatively cheap. Last one we had built was guaranteed to 1200hp and with them supplying yokes and u joints was 300 bucks made from scratch.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 05-11-2012, 11:38 PM   #7
cory d
cory d's Avatar
wow thats allot less expensive then i thought. i will give them a call a call in the morning to get an idea on price
Old 05-12-2012, 06:18 AM   #8
andrewmp6
I have had a local diesel shop build all of mine.I have had a few made none have failed and most i paid was 350 bucks.
Old 05-12-2012, 06:30 AM   #9
Al you need is new tube,if it's longer,or cut and re-welded. When I have mine lengthened it has never cost as much as $200...shortening is about $100. It can be done inside of an hour.
Old 05-12-2012, 10:23 AM   #10
INSIDIOUS '86
Yes it is. They built the shaft on my 67 belvedere. And it had a trans brake and a 750hp stroker 440. That shaft took it like a champ
Old 05-12-2012, 04:32 PM   #11
v30crewcab
v30crewcab's Avatar
I always shorten my own. I cut them, put it together with the joints in phase, tack it back together, install it in the truck and spin it to get it dead on straight, and weld it up. never had one break, and my truck will twist up the frame when I get on it. but if you're not comfortable doing it def pay someone else that can.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 05-12-2012, 08:23 PM   #12
INSIDIOUS '86
Mine twist the frame over speed bumps lolololol
