Old 09-24-2003, 12:28 PM   #1
fast67chevy2002
Dad's little helper
fast67chevy2002's Avatar
motor mounts?
I have got 2 sets of motor mounts that come from 292s, can I use them for a V8 or do I have to get dif. mounts.
too many projects:
61 biscane
67 swb(shaved)
73 Fiat spider 124 Sport
84 Pontiac Grand Prix
86 olds cut. sup.
fast67chevy2002 is offline   Reply With Quote
Old 09-24-2003, 12:30 PM   #2
adamls
Gotta Startem Early
adamls's Avatar
If I am not mistaken, the 292 used one V8 mount and straight 6 mount. The V8 mount, I think, was on the pass. side and the straight 6 mount was on the driver side. So you can use one of them but not the other.
67 SWB In Progress, one piece at a time, maybe 3 years I will be finished
adamls is offline   Reply With Quote
Old 09-24-2003, 12:33 PM   #3
fast67chevy2002
Dad's little helper
ok,
problem I have now is all four mounts look the same, how do I tell which 2 to use. Is there a small dif. in measurements that I can try?
too many projects:
61 biscane
67 swb(shaved)
86 olds cut. sup.
Old 09-24-2003, 01:08 PM   #4
Hooter
My other Love
Hooter's Avatar
is it the mount on the frame or the mount going from the frame to the block. the mounts that are on the frame are the same as far as I know, or at least they are they same in a 79 chevy truck last time I did a motor swap in it.
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 09-24-2003, 01:18 PM   #5
fast67chevy2002
Dad's little helper
these are the mounts that are bolted to the frame. I guess some people refer to them as towers? There are 3 holes in the frame to adjust the mounts.
too many projects:
61 biscane
67 swb(shaved)
86 olds cut. sup.
Old 09-24-2003, 01:40 PM   #6
crazy longhorn
Fabricate till you "puke"
the 6/250 stands will mount the sb, but will set the eng back 3 1/2" from factory v8 sb spot. I beleive the driver side is the same stand for 250 or 292, but the pass side is foward(you need to swap that one). The V8 sb stands mount in the foward holes on the frame, & also foward hole on the crossmember.....6 /250 stands mount toward the rear. good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-24-2003, 03:38 PM   #7
fast67chevy2002
Dad's little helper
thanks for the info.,
sherm
too many projects:
61 biscane
67 swb(shaved)
86 olds cut. sup.
Old 09-24-2003, 05:17 PM   #8
Ironhorse
Ironhorse's Avatar
Can't help with the motor mount question for the Inline 6 but if you decide you need a pair of SBC V-8 mounts/towers I have a set from a 71 C-10 350 with A/T. $20 plus the shipping and they're yours. Good shape, just need cleaned, primed and painted. Includes attaching bolts if you want them.
1971 Chevy 1/2T 4x4 LWB 350 V-8
Was sm465-now 350TH/np205
Tilt, Tach, Towhooks
Original Truck AM/FM
Wellington, Ks
Ironhorse is offline   Reply With Quote
