#76 |
![]() Join Date: May 2011
Re: 540 BBC 68 Burb Dually 54" Boggers on Rocks
Nothin like a steady diet of WD40 and Coors Original to make the work go by! great looking work!
#77 |
Started welding the chassis in tonight heres some booger weld pics!
#78 |
6>8 Plugless........
![]() Join Date: Sep 2007
Nice welds!!!!!!!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#79 |
#80 |
Nope, sure wouldn't have.
#81 |
I applaud your outstanding vision, design and fab skills - your rig is bold and different
66 GMC Suburban Custom 66 Chevy K10 Suburban |
#82 |
#83 |
Started on the other side of the chassis...
#84 |
Just a wide view pic.... Trying to make there mirror exacts once the chassis are done i will tie them together and start to build my motor and body mounts ect
#85 |
Amazing.... simply amazing.
#86 |
Thank you for the kind words sir. Im only 26 so theres a huge learning curve cause this is the first time ive ever taken on somthing like this....
Any advice from members like you is greatly appreciated (execpt for your small block theory!). A huge majority of the individuals on this forum are light years ahead of me with a wealth of knowlege that i would love and be honored to tap into as my build progresses... thanks again man Posted via Mobile Device |
#87 |
Just getting the center part of the chassis together... still trying to make sure everything lines up.
#88 |
Chassis almost done!!!! Time to pull the bottom one off and tack the chassis to the table to make sure its all level and get ready for full weld.
#89 |
Just about there just finishing up some of the bottom
#90 |
Hold Coped tube batman!!!!!
#91 |
Just more progress...
#92 |
yay! finally done, just need to fully weld it together!!!!
#93 |
Has taken 77 hours to get to this point. I figure it will be another 3 or so hours to weld together depending on how much the frame wants to flex and oil can. Id love to complete it all together ready to powder coat in 90 total hours...
#94 |
Great work! There are a lot of cutting and fitting in these pics! Man you have talent and big kahones!
By the way, sweet car next to the lift!
#95 | |
The car if its blue is a 71 challenger rt with a 383 stroker. If its a truck then its a 59 chevy fleetside with a crate 350 regardless thanks! Posted via Mobile Device |
#96 |
I know about take about half off other wise you end up with a pile of tubing that is worthless to anyone other than the scrap pile.
Yeah, it was the Challenger. I'd love to have one some day!
#97 | |
#98 |
Charlie Daniels w/ a Tq Wrench
Needs more triangulation
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#99 |
#100 |
So started welding the chassis together and its just taking a bit of time cause just want to make sure it doesnt warp real bad by heating up. So the technique is just weld a few joints then do some body work and let it cool down. When body filler is applied while waiting for it to harden weld a little bit more ect.
In the mean time i transfered the body from my house where alot of the work was done to it and brought it over to my friends shop so that i would have a bigger spot to work on it as well as making the chassis mating alot easier. |
| Bookmarks |
| Tags |
| 54" boggers, big block, dually, monster truck, suburban |
| Thread Tools | |
| Display Modes | |
