Old 05-14-2012, 08:48 PM   #1
jbjburbs
jbjburbs's Avatar
Oasis Compressor vs Engine Mount
Alright, I've been looking around I'm not finding the answers I'm looking for, but then again the internet has made me lazy...I'm not sure if this falls under suspension or wiring - move if needed.
I have a York 209 engine mount, but I need all the goods (mount, hook it up, clutch, etc). I saw a nice Oasis on CL and was thinking that might be easier to hook up. I know guys like Dino run them, but I also read about their amp draw.
How do you combat the amp draw or am I better off getting the gear for my engine mount? I currently have 2 old compressor that take about 15min to fill my 6 gal tank...it's not going to work that way much longer.
Thanks!
John J
Bodied 1994 Suburban on custom frame -
http://67-72chevytrucks.com/vboard/s...d.php?t=672297
Dad's 1948 Suburban -
http://67-72chevytrucks.com/vboard/s...d.php?t=563150
Bagged 1995 Suburban - SOLD
Bodied 1995 Tahoe -SOLD
jbjburbs is offline   Reply With Quote
Old 05-15-2012, 12:03 AM   #2
broey
Square
broey's Avatar
Re: Oasis Compressor vs Engine Mount
I have personally viewed dinos oasis set ups on all his trucks and can tell you that he runs a minimum of 2 EXTRA optima batterys for each oasis. the yellow tops. and he trickle charges them every once in a while.
Squarebody Syndicate
broey is offline   Reply With Quote
Old 05-15-2012, 02:02 AM   #3
Dinos63
chevy only
Dinos63's Avatar
I have had 3 of them and there are killer,60 amps when running but fills a 5 gallon in about 70 seconds. and they are good people to deal with
CHEVY ONLY... Nothin Else !
Dinos63 is offline   Reply With Quote
Old 05-15-2012, 12:56 PM   #4
fastbagged68
fastbagged68's Avatar
I have an oasis in my 63 suburban. I think it is the best compressor you can run. It fills my 5 gallon tank fast. I have a 140 amp alt. When the compressor kicks on it does not phase it. It runs for such a short time it is not a problem if my alt couldnt keep up. The only down fall is the truck needs to be running when it runs. I would buy it.
fastbagged68 is offline   Reply With Quote
Old 05-15-2012, 01:52 PM   #5
jbjburbs
jbjburbs's Avatar
Thanks for the information... I here more about the draw from these, even it's short. I'm wondering if a capacitor help with the draw (like what's used with a big audio system)? To story some power for the compressor to suck juice from before drawing the alternator or battery...
Only working while running is fine, especially if it's a short time. I'm hesitating on the engine mount because i'm thinking about an LS this winter, so I'd have to mount one twice....
John J
Old 05-15-2012, 11:55 PM   #6
72gmcshorty
72gmcshorty's Avatar
there are people who have used a/c compressors to run their systems...
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 05-16-2012, 07:10 AM   #7
jbjburbs
jbjburbs's Avatar
a york compressor is an old ac compressor...ford, volvo and other vehicles used to use them. my issue with that the effort in mounting one and getting the right clutch plate to have it work with my motor. even more concern is spending the money on it for this motor only to swap different one this winter.
the oasis compressors use york compressor with an electric motor, but are more like a standard compressor. however, their motors have a lot of amp draw.
my question should have been, is the cost to hook up an oasis more or less than the parts for a en engine mount compressor? since most guys run one or the other, i was more curious to the parts needed to run an oasis, since there is already lots of info from running a york off a motor...
John J
compressor, engine mount, oasis
