Old 05-14-2012, 07:05 PM   #1
Mrknowitall
Cool To all who keep asking on battery placement
1300 cold cranking amps, summits remote kit, arco solar charger.
Take that 120 lbs and put it where it counts!
Mrknowitall is offline   Reply With Quote
Old 05-14-2012, 07:24 PM   #2
86c20
86c20's Avatar
Re: To all who keep asking on battery placement
are those both 1300 cca? and are you shure that its not 1300 ca? not saying its not but i would like them for my diesel. thanks, mike
86c20 is offline   Reply With Quote
Old 05-14-2012, 07:31 PM   #3
Mrknowitall
Its really like 1275 or something, 1300 is combined. Both bats. The ca is prob 1400 est, ill look tom for exact numbers,
Btw. To all! Make sure u use a saftey disconnect. My setup in this pic dones not yet have one.
With 1000amps grounding... Oh boy. Thats a welder and quickly a bomb.
86c20: i reccomend u research how many amps ur starter draws, and compair it to the national wire guage chart to estimate if summits kit is big enough, mines right at the limit of 300a on this line with DIRECT FRAME CONTACT.
You may need to order 2 kits and run two positives to the starter to support that amperage draw.
Old 05-14-2012, 07:33 PM   #4
Mrknowitall
Addition: i used wire wrap, wire loom, and heat tape to get my amperage ratings safe from insulative arch through
Old 05-15-2012, 11:07 PM   #5
86c20
86c20's Avatar
wire sizing is ok with me. (work on generators) was thinking about getting some double 00 to run. same thing they run on semis think i can get it cheap lol. i would do bat to starter on the pos and neg then starter to frame. and then frame back to bat. had to do that on my dads ss chevelle. worked well after that.
Old 05-16-2012, 02:13 AM   #6
Mrknowitall
Sounds good, just keep in mind thats a long run. And k
Charging the frame as a ground is proven to accelerate rust/corrosion. So if they salt the roads in mass id coat the frame at least.
Just some thoughts! I think this will work well for you, handeling i noticed was loads better, took her to 115 and noticed the rear slumped in a better manner, calmed down like a dart.
Also i highly reccomend an intruder switch on the container the batts will be in, mine has a dead man switch wired into the door sensor on alarm module so no one can just disconnect batt , shatter window, pop in nuteral and roll away. Hahha
Old 05-16-2012, 02:31 AM   #7
INSIDIOUS '86
INSIDIOUS '86's Avatar
How long does it take to change a battery?? Lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 05-16-2012, 02:36 AM   #8
Mrknowitall
Givin water level is good, 2 seconds-10 hrs depending on amperage selected on charger. Always charge a dead batt with the lowest amperage, perferablely 5a at 13-14v. Monitor your batterys voltage CONSTANTLY. Should b about 12.80 v dc.
ALWAYS ADHEAR TO BATTERY CHARGERS MANUAL
ALWAYS KEEP BAKING SODA NEAR AND FOLLOW PROPER SAFTEY TECHNIQUES.
Acid burns are nasty, believe me. Baking soda saves lives.
PERFORM AT YOUR OWN RISK
