Can anyone identify my brake booster? If not can any one recommend one? This one has plastic collar in rear and has broken and doesn't work any more.
1970 442 convertible 1970 Cutlass SX 1962 Chevy Stepside 2011 GMC 3500HD Crewcab SLT DRW |
Re: Power Brake Booster
Bump, id like to know to, it looks pretty clean and thats the way il do it.
My first ever build!! 1965 c10 LWB 283v8 sm420 http://67-72chevytrucks.com/vboard/s...63#post5337863 |
![]() Join Date: Sep 2009
i don't know what the booster is from but the master looks stock. you can still by the stock master and booster from auto parts stores--napa,autozone for $106
Surprisingly, i found out recently autozone also carries replacements for the factory boosters for our trucks as well. They are advertised on their website. It is remanufactured by a company by the name of Cardone. I'll try to attach a picture from their website. This one is for a 1960.
60-66 Nut
I can't tell from that view. I need to see the backside more. Either way, someone has fabricated a custom bracket to mount the booster to the firewall. This was likely done to cover the holes for both the brake master and clutch master on the '60-'62 Chevy's and the '60-'63 GMC's, and provide a mounting place for the booster. I agree that the master appears to be original for a '64-'66 truck.
Very nice looking engine/engine compartment.
The master is a stock piece. The booster bracket seems to be attached (welded)at factory. The rod has been modified to work with this booster and i want to try to find a manufacture that makes it. I will try to get more photos and post asap.
Here an old picture and have no idea what year the picture was taken but it was before the booster was installed.
Hurting my neck...help you out a little bit...
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
I had a power brake booster very similar to that in my Chevelle, that came out of a 64 GM intermediate (I don't remember which one, sorry). It factory mounted flush to the firewall just like that does.
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck |
#11 | |
Hope I am not intruding in this thread... Craigerrr
Craigerrr My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709 |
60-66 Nut
Which bracket are you referring to? The one in this thread, or the ones that I sell? Maybe send me a PM so we don't hijack this thread any more.
Since im insearch of another brake booster please post a picture of it.
Attached are photo's of back top view of booster and 3rd picture bolt that tightens band around the booster together.
#15 |
60-66 Nut
Whoa, looks like someone welded those brackets to the booster. Hopefully they disassembled the booster before doing that.
When I replied to your PM, I sent you the link to the '63-'66 booster bracket. I didn't realize you were the guy who posted this thread. Here is a link to the '60-'62 booster bracket for sale thread. http://www.67-72chevytrucks.com/vboa...d.php?t=357542
#16 |
i purchased a booster from Advance Auto for a 65 c-10 was a direct bolt in and works very good.
#17 |
Could I see a picture of that, and can you give me a link to that part on their site?
#18 |
i just installed tonight. i will take photos and get you info as soon as i can.
#19 |
great thanks, did you need an adapter for the firewall like captainfab sells?
#20 |
Part Number is 54-73537. $154.00 includes $40 core charge. Listed under 65-66 Chevy C-10 Pick up. It comes with brakets already installed. As you can see i painted the booster and the brakets.
#21 |
m455sx, just to clarify, you bought a 65-66 c10 booster and bolted it right up to your 62 c10? no mods or anything needed? Longer rod or anything needed? clutch rod, etc?
#22 |
Nope, the rod appears to be out of the same year truck i guess( look at the begining pictures). All i did was pull the bolt shaped pin and everything went back together. The rod has threads for adjustment and i adjusted until all play was taken out. I am not sure if the rod in the pictures was custom made or from same year truck?
#23 |
Let me know if more pictures are needed as i can take some under dash pix and post them.
#24 |
Thanks for posting this up, is the MC just a single line unit?
#25 |
Yes, i want to convert to a dual MC. I have to wait until i can afford the proper tools to do so properly.
