Old 05-16-2012, 01:38 PM   #1
sunk99
sunk99's Avatar
69 Disc brake conversion questions
Converting my 69 to front disc brakes and have a few questions. Do I need to change my brake lines to the front of the cross member from the rear? It was factory power brakes so do I need to change my master cylinder or prop valve and if so should I use 71-72 parts or later model parts? Thanks in advance.
sunk99 is offline   Reply With Quote
Old 05-17-2012, 10:23 AM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 69 Disc brake conversion questions
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 05-17-2012, 11:14 AM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
You need to change the M/C and prop valve to a disc brake version.
71-72 parts here would be a direct bolt on.
There is no need to re-route the brake line.
You can buy direct bolt-on 63-70 standard spindles and drop spindles.
You will need to bend up a couple hard lines from the prop valve down to the crossmember.
Have you bought any parts for the conversion yet?
Read this thread:
http://67-72chevytrucks.com/vboard/s...68&postcount=4
Nates thread details installing disc brakes on a '69:
http://67-72chevytrucks.com/vboard/s...d.php?t=353633
Keith
Convert to disc brakes.
Old 05-17-2012, 11:25 AM   #4
sunk99
sunk99's Avatar
I ordered my conversion from way2low2 and it is a Mcgauhy's kit but is only for the spindles out. So I will need to run new hard lines for the front brakes?
Old 05-17-2012, 02:04 PM   #5
sunk99
sunk99's Avatar
What size lines do I need to run from the prop.valve to the hose?
Old 05-17-2012, 03:10 PM   #6
lolife99
lolife99's Avatar
Your original line to the front hoses will work.
You just need a new line from the M/C to the tee on the crossmember.
It's either 3/16" or 1/4".
Keith
Old 05-17-2012, 03:53 PM   #7
sunk99
sunk99's Avatar
Ok thanks lolife.
