Old 05-19-2012, 02:41 PM   #1
1972BackInBlackC10
1972BackInBlackC10's Avatar
truck wont stay running while driving
i hope you all can help as i dont know what to do anymore, my truck starts and runs fine even when you put it into drive it stays running, but when you get about a block distance or more it seems like its losing power and when you give it gas it tries to die or just dies completely
once you start it again it just wants to do it right away when u start driving, the truck has a brand new carb on it, it was doing it with the old one too, new spark plugs, wires, cap and rotor, the amp gauge shows a good charge so the alt and battery should be good and iv checked all my vac lines and it has gas i checked lol and added more
what else am i missing? any ideas???
1972BackInBlackC10 is offline   Reply With Quote
Old 05-19-2012, 03:40 PM   #2
deth_1970
deth_1970's Avatar
Re: truck wont stay running while driving
HEI dist?, if so check the coil, and module,
78 dualy crew cab wife calls "the beast"
79 silverado "yeller"
99 tahoe
02 Gmc sierra
deth_1970 is offline   Reply With Quote
Old 05-19-2012, 04:04 PM   #3
frog210
gas pump?
filters?
fuel lines for cracks on the inside?
frog210 is offline   Reply With Quote
Old 05-19-2012, 04:13 PM   #4
Car'n'Guitars
Car'n'Guitars's Avatar
Fuel pump maybe.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 05-19-2012, 04:58 PM   #5
wilkin250r
wilkin250r's Avatar
I had a similar problem years ago on a 72, my issue was a kinked fuel line. Since the gas tank was above the line, gas would slowly drain past the kink and fill up the fuel line. When I would start the truck, it would pull all the fuel from the line and run for a little while, but couldn't pull any past the kink. So when the fuel in the line ran out, it died. Letting the truck sit for several hours would allow the fuel line to fill up again.
I'd recommend a small inline fuel pressure gauge right before the carb. They're relatively cheap (I think mine was $6.50 ) and will tell you if you're getting proper fuel pressure. Easy way to find or rule out at least one of your main possibilities.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 05-19-2012, 06:08 PM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
im betting on the module in the distributor
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 05-19-2012, 06:50 PM   #7
Pro/StreetPete
Pro/StreetPete's Avatar
Exactly where I was heading..........
"You're only as good as the people you keep around you"
Pro/StreetPete is offline   Reply With Quote
Old 05-19-2012, 08:51 PM   #8
Mrknowitall
Pop the dist cap and check those two little springs, make sure theyre still there and opening properly. Then id check for fuel, if it was starved it would cough and spudder then die. If its weight problem it will back fire and die or just die. But these trucks will run on 3 dead cylnders, so a fuel issue is most likely the problem.
Mrknowitall is offline   Reply With Quote
Old 05-19-2012, 08:58 PM   #9
Pro/StreetPete
What do you think you are Mrknowitall or something ? oh ya you are......... .....just kidding,,,,
Old 05-19-2012, 08:59 PM   #10
Mrknowitall
Dont forget it
Old 05-22-2012, 12:30 AM   #11
1972BackInBlackC10
i replaced the coil already where is this module your talking about? i just put a new fuel pump on it yesterday but its still doing it, no kinked fuel lines and the truck will start right away after it dies no waiting
could it possibly be the timing??? im inches away from selling my truck im so pissed at it, ic spent almost 3 grand on it between the motor, tires, exhaust and interior that im at the point where i dont want to spend anymore money on it or screwing with it
Old 05-22-2012, 12:47 AM   #12
Mrknowitall
Under the dist cap u will see two weights anchored by 2 springs.
Old 05-22-2012, 01:09 AM   #13
1972BackInBlackC10
ok and what am i checking to see if they do or dont do? and what is the fix if they arent doing their job?
Old 05-22-2012, 01:46 AM   #14
deth_1970
deth_1970's Avatar
the module is in the dist, what the wires from the cap hook to, has 2 wires on 1 end and 2 wires on the other, kind angled shaped,
99 tahoe
02 Gmc sierra
Old 05-22-2012, 01:54 AM   #15
1972BackInBlackC10
if its on the cap it was replaced
Old 05-22-2012, 01:57 AM   #16
Mrknowitall
are u running stock ignition or hei?
pop the cap, u will see two claws, they will b anchored by 2 springs,
1)check if they are present
2)take ur finger and gently pry them apart, they should move freely, and spring back into place. they work just like a centrifugal clutch. when spun quickly they throw outward thus creating igniton advance. if they fail to work, the truck will sputter, and run ritch.
the fix depends if they are sticking or broken springs, report findings and well go from there.
also, have u checked the vaccum advance? that could also b a problem. check the line for corrosion/holes/vac leak.
idk what he is talking about, i have always ran hei. i refuse to use points, so ask him what hes talkn about i am not familiar with the stock coil type dist.
Old 05-22-2012, 02:00 AM   #17
1972BackInBlackC10
mrknowitall the truck has hei
Old 05-22-2012, 02:05 AM   #18
Mrknowitall
ok, then ur "module" will be UNDER the weights, it could b bad, but chances r its not. when they fail they usually just quit.
check those weights, see if they are sticking, make sure the springs r still there....
also, pull cyl #1's spark plug and take a pic, if u cant take a pic, report the color. that will tell us ALOT
Old 05-22-2012, 02:20 AM   #19
1972BackInBlackC10
ok will do tomorrow after work, just to save me time as im sure you know what one is cylinder one lol dumb question i know but will save me time from looking it up
Old 05-22-2012, 03:00 AM   #20
Mrknowitall
perfect!
and not a dumb question, if u dnt know u dnt know
Old 05-22-2012, 03:04 AM   #21
drec
It could be a lot of different things. Have you checked your fuel pressure at the carb? You could have something in the tank or line that is restricting the flow.
drec is offline   Reply With Quote
Old 05-22-2012, 03:52 AM   #22
1972BackInBlackC10
thanks mrknowitall i figured thats where it was but wasnt sure, drec lots of pressure at the carb
Old 05-22-2012, 01:28 PM   #23
motornut
78K & 79C Jimmys
motornut's Avatar
some pics
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
Old 05-22-2012, 06:33 PM   #24
thesickc10
if the truck cutting in and out when it tries to die? if so this is the module.
1985 c10 355 th350 (working on 4 speed conversion to super t10)
1979 camaro 358 super t10
2003 f250 superchip slp exhaust
thesickc10 is offline   Reply With Quote
Old 05-22-2012, 09:37 PM   #25
1972BackInBlackC10
thanks for the pics motonut i will check mine tomorrow since its been raining,
thsickc10 when im driving it feels like its losing power and when you give it gas it cuts out like its going to die, doesnt matter if you gently give it a lil bit of gas or ush the pedal in half way basically same scenario no matter what
also no pics of spark plug due to the above mentioned rain
