Old 05-22-2012, 03:55 AM   #1
mcmlxix
Collector of Projects
mcmlxix's Avatar
5x7 LED Headlights: Truck Lite
So this started out in the 67/72 section because I found the round 7" style first, but you square body guys can get in on it too.... HERE
27450C
* When properly mounted, exceeds FMVSS-108 and CMVSS-108 DOT requirements for low beam and high beam performance
* Excellent option for light, medium and heavy-duty trucks, off-road vehicles, classic cars, motorcycles and more.
* Metalized reflector optics provide a lighting experience that smooth and clean across the driving surface
* Provides a brighter, crisper and whiter light output, closer to the color temperature of daylight, dramatically improving light projection distance and overall visibility
* Durability and dependability of LED lighting provides a solid-state, bulb-free headlamp design that impervious to damage from shock and vibration
* Military grade, die-cast aluminum housing and non-yellowing, polycarbonate lens offer optimum protection against damage from impact, roadside debris and other hazards
* Electronics are sealed in epoxy to resist from damage caused by corrosion or moisture
* Advanced circuitry protects against voltage spikes up to 600v
* Drop-in replacement for #6052, 6053, H6054, and HP6054 headlamp designs.
* Uses standard, H4, 3-blade wiring connector
* Equipped with Truck-Lite 3-Year Limited Warranty.
Rich
1972 K5 Blazer CST Click HERE
Old 05-22-2012, 12:25 PM   #2
hatzie
Moderator
hatzie's Avatar
Re: 5x7 LED Headlights: Truck Lite
Is the whole assembly DOT / FMVSS 108 certified?
Some of the sleazier outfits have discovered they could emboss DOT certification on the lens if that piece met DOT when the assembly as a whole didn't.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 05-22-2012, 12:48 PM   #3
bigwheel15
bigwheel15's Avatar
Those look pretty interesting, it seems like a good alternative to hids. I think however they might look a bit odd when installed simply due to their styling.
bigwheel15 is offline   Reply With Quote
