Old 03-30-2012, 11:27 PM   #51
jocko
jocko's Avatar
Re: Original Bucket seats installation????
I just assumed the front mounting points see the most stress because of the lever arm being the longest on the top back of the seat. Amplifies with mild acceleration. But braking reduces the load, without the added leverage on the rear braces. And side loads would be negligible I'd think. I'm gonna install a set of these seats someday, would like to horde away a set of braces along with my console!!! I'm really glad you posted this mcbassin - like I said in one of the early posts - I just thought buckets used the same holes as a bench and I didn't even know there WAS bracing for buckets that benches didn't get. Duh.
Old 04-14-2012, 02:55 PM   #52
7dee2
7dee2's Avatar
Originally Posted by sameyrasmea72 View Post
pics !!!!
Sent sameyrasmea72 a PM to see if these brackets are almost ready to ship....
Brett
66 El Camino: BBC, 4sd. Waiting for its turn.
67 Camaro SS: 67 Camaro Build
72 Cheyenne/C10 Super 115" Fleetside: 72 C10 Build
72 Cheyenne/K30 Super 133" Longhorn DRW: 72 K30 Build SOLD
YouTube: https://www.youtube.com/@6dee7-7dee2
7dee2 is offline   Reply With Quote
Old 04-17-2012, 04:19 PM   #53
scott72
scott72's Avatar
subscribed
scott72 is offline   Reply With Quote
Old 04-17-2012, 10:52 PM   #54
bovey
bovey's Avatar
Great post. I had no idea they were that different. I am just finishing putting a set of Recaros out a Benz in mine - waaaaayyyyy more work than I ever imagined.
bovey is offline   Reply With Quote
Old 05-22-2012, 08:07 PM   #55
7dee2
7dee2's Avatar
pics !!!!
Are these reproduction brackets mentioned earlier #48 still a possibility anybody? My PM was never responded too. Seemed the best way to go because they use the existing floor support.
I also really like Mike's install method as it is also one of the best I have seen from my forum research. Really appreciate you posting yours Mike.
Brett
Old 05-22-2012, 11:21 PM   #56
mcbassin
Still Learning
mcbassin's Avatar
Thanks Brett. I ended up just going with the braces I made. I think it will be more than adequate for my wife and I to cruise around safely. I still need to come up with the correct shoulder seatbelt configuration. HERE is what the bottom of the cab looks like now.
Old 05-23-2012, 12:15 AM   #57
jocko
jocko's Avatar
btw mcbassin - i finally read your build thread for the first time - awesome write up. can't wait to see her all painted up soon. sorry bout the seam sealer! I'd have kicked the dog over that one....
Old 05-29-2012, 11:15 AM   #58
mcbassin
Still Learning
mcbassin's Avatar
Thanks Jocko, no big deal on the seam sealer it's water under bridge now. It did force me into a long weekend off of it though. Just a step back to not get burn out is nice.
Old 06-13-2012, 07:58 AM   #59
SS Tim
SS Tim's Avatar
This is a great thread and I wanted to add these two illustrations as further points of reference.
SS Tim is offline   Reply With Quote
Old 06-13-2012, 08:28 AM   #60
mcbassin
Still Learning
mcbassin's Avatar
Great illustrations Tim! thanks for adding them.
Old 06-13-2012, 04:25 PM   #61
7dee2
7dee2's Avatar
Brett
Old 06-13-2012, 09:24 PM   #62
jocko
jocko's Avatar
YESSSSS! I've been lookin for that picture! Thanks Tim.
Old 07-22-2012, 09:20 AM   #63
budnikguy
budnikguy's Avatar
subscribed,,,definitely a knowledge builder post!
budnikguy is offline   Reply With Quote
Old 07-22-2012, 12:23 PM   #64
slikside
slikside's Avatar
Indeed.
slikside is offline   Reply With Quote
Old 07-22-2012, 03:23 PM   #65
Calvin D.
Active Member
Calvin D.'s Avatar
subscribed
I needed this
Calvin
Calvin D. is offline   Reply With Quote
Old 07-22-2012, 10:05 PM   #66
calvin78612
calvin78612's Avatar
Great info.subscribed !
84 step side
87 swb
calvin78612 is offline   Reply With Quote
Old 08-19-2012, 12:11 AM   #67
peterbuilt
Before I send PM's I thought I'd just ask here...
68 TT - did you finalize an idea you'd like to share on an easier approach to fabricating an under floor bracing bar?
Duncan & Sons - Did you ever get additional brackets made for resale to us?
FWIW - by centering my driver bucket with the steering wheel then measuring for equal distancing from console dimples I came up with the same as I found here - Existing outside front holes for bench seat are key starting references for fitting factory bucket brackets in bench seat trucks: 3/4 to 1" to right of driver outside front hole is good placement and existing passenger outside front hole was good as it stands. All other holes must be drilled after squaring tracks/brackets and marking. Not sure but the passenger seat center may have lined up with the glove box latch...
peterbuilt is offline   Reply With Quote
Old 08-20-2012, 04:54 PM   #68
leddzepp
Moderator
leddzepp's Avatar
Great thread! To add to Tim's illustrations above, here are two more showing the attachment of the factory shoulder belt retainers that mount to the front of the console, if your truck came optioned with both bucket seats and shoulder belts.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 08-20-2012, 07:07 PM   #69
7dee2
7dee2's Avatar
Very cool Leddzepp, I am adding this option to my truck and had no idea about the buckle retainers on the console. I had something very similiar in a 1966 Impala SS I restored not sure if it was correct but I liked them. Do these brackets ever surface on the forum?
Thanks,
Brett
Old 01-06-2013, 01:37 AM   #70
1972SUPERSB
1972SUPERSB's Avatar
Any new info if Duncan and Son is making these underfloor brackets?
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 01-06-2013, 01:56 AM   #71
SS Tim
SS Tim's Avatar
RogerKoop Should still have some left.
http://67-72chevytrucks.com/vboard/s...d.php?t=557195
Old 01-06-2013, 09:43 AM   #72
29od1
Koops rear outer driver's side bracket won't fit if you drill the driver side 3/4" over from the front outer most hole. It was off by about 1/2" from where my bucket seat tracks holes needed to be drilled. It needs to be in the 1-1/8" to 1-1/4" over if measuring center to center.
Can someone with buckets in a truck please measure center to center the distance shown in this picture. Or maybe Koop can answer how far he moved his over.
Thank you.
29od1 is offline   Reply With Quote
Old 01-06-2013, 12:39 PM   #73
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Subscribing........This is great info!
Live life one day at a time!
FIREBALL is offline   Reply With Quote
Old 01-06-2013, 01:27 PM   #74
GOPAPA
GOPAPA's Avatar
Originally Posted by Duncan and son
Hey Trevor, we have made some of those and they came out very correct even down to the square nuts. We only made a few to test quality etc. Do not have any now but will have more made.
Always appreciate you Paul
I would like to get a set of these braces from you also .. what are you asking for the set before postage ,, thx
When you learn a thing a day you store up smart.
GOPAPA is offline   Reply With Quote
Old 01-06-2013, 09:07 PM   #75
octane
octane's Avatar
Subscribing...... Handy info to have around. I'll need this shortly.
octane
1971 C10 Cheyenne - Project Truck
1971 C10 Super Cheyenne - Driver
octane is offline   Reply With Quote
