Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 01-10-2012, 01:05 AM   #1
Fw190d9
69 Blazer build
Starting another build thread here on a 69 Blazer Im doing for a buddy. We got the blazer off of Ebay in ElPaso. Its in pretty good shape with no rust. It currently has a 6" lift and a built 350. Mods planned are a new Gen VI 502, 700r4 and an atlas Tcase. Also installing Dynatrac axles front and rear. I started by yanking the small block and th350 and am trying to shoehorn the 502 in. The firewall needs major surgery to fit it in the stock location. I cut the firewall sections out and am welding in some sheet metal to make room.
Evan Q.
Fw190d9 is offline   Reply With Quote
Old 01-10-2012, 01:15 AM   #2
Fw190d9
Re: 69 Blazer build
A few pics of the firewall adjustments
Old 01-10-2012, 03:57 PM   #3
CTENTA1
Registered 1971 K5
Re: 69 Blazer build
This should be a good one.
CTENTA1 is offline   Reply With Quote
Old 01-13-2012, 02:42 AM   #4
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
Re: 69 Blazer build
holy sh%% nice motor and truck... love the rim and paint combo
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 02-17-2012, 02:54 AM   #5
Fw190d9
Re: 69 Blazer build
Got the motor all gussied up. Painted the block/pan red and will paint the valve covers too once I get the breather and oil fill mounted. The heads and intake will remain bare aluminum. I also mounted up the vintage air front runner serpentine system. Lots easier to do it now than when mounted in the blazer.
Evan Q.
Old 03-22-2012, 10:02 PM   #6
Fw190d9
Re: 69 Blazer build
Progress continues. Dynatrac front axle installed with new spring bushings and greaseable shackles from Offroad Design. New PSC 2WD steering gearbox for the crossover steering. Also test fit the engine again to check Header fitment. They fit real well with only minor frame grinding (about 1/8") in 2 spots. Gotta get the rear Dynatrac axle installed so I can set it at ride height to measure for the steering draglink. More to come.........
Old 05-24-2012, 08:52 PM   #7
Fw190d9
Re: 69 Blazer build
Progress continues on the blazer. Havent updated in awhile as Ive been pretty busy. I have installed the Vintage Air A/C unit, applied dynamat extreme to the firewall area, sanded down and repainted the entire dash panel and fabricated a center panel to house the Kenwood Nav unit and 2 a/c vents. I also scored an awesome rebuilt center console from a forum member here. The one that was installed in the blazer was a cheap repo. Im also planning on installing Cadillac escalade 2nd and 3rd row seats. Got a brand new set off ebay, just need to fab up some brackets for em. And last but not least, I finally got my 4 speed Atlas which will be installed soon.
Evan Q.
Old 05-24-2012, 08:55 PM   #8
Fw190d9
Re: 69 Blazer build
more pics
Old 05-24-2012, 09:55 PM   #9
72truckman
72truckman's Avatar
Re: 69 Blazer build
this thing is gorgeous
My 1972 Blazer 5.3 E85/ NV4500 5spd 4x4
Work in Progress
http://67-72chevytrucks.com/vboard/s...d.php?t=291482
****SOLD!!!!!**** 1965 GMC 4X4
http://67-72chevytrucks.com/vboard/s...d.php?t=294727
72truckman is offline   Reply With Quote
Old 05-25-2012, 12:18 AM   #10
d.garza9
d.garza9's Avatar
Re: 69 Blazer build
If You Ain't First, You're Last - Ricky Bobby
It doesn't matter if you win by an inch or a mile; winning's winning - Dominic Toretto
The LORD himself goes before you and will be with you; he will never leave you nor forsake you. Do not be afraid; do not be discouraged- Deut. 31:8
d.garza9 is offline   Reply With Quote
Old 05-25-2012, 12:28 AM   #11
Fw190d9
Re: 69 Blazer build
Originally Posted by d.garza9 View Post
Thanks Man! Ive been following your build too, like what you done with your 72.
E.
Old 05-30-2012, 01:43 PM   #12
CTENTA1
Registered 1971 K5
Re: 69 Blazer build
Looking really good, any updates?
Old 05-30-2012, 02:17 PM   #13
ColoradoK5
ColoradoK5's Avatar
Re: 69 Blazer build
Sweet Blazer what size rims & tires are those?
ColoradoK5 is offline   Reply With Quote
Old 01-25-2013, 12:06 AM   #14
Fw190d9
Re: 69 Blazer build
Well, the Blazer is just about done. Ive been slacking on posting updates here. I will try and catch up with the pics.
Evan Q.
Old 01-25-2013, 12:10 AM   #15
Fw190d9
Re: 69 Blazer build
more
Old 01-25-2013, 12:16 AM   #16
Fw190d9
Re: 69 Blazer build
and more.....
Old 01-25-2013, 12:20 AM   #17
Fw190d9
Re: 69 Blazer build
did some repairs to the double wall top. The bottom mounting areas were in bad shape and most of the captive mounting nuts were stripped or missing. I was able to drill out the rivets, and slide the nut strip out of the end of the top, weld new nuts onto the strip and fish it back in and glass it up. Worked great.
Old 01-25-2013, 01:11 AM   #18
Fw190d9
Re: 69 Blazer build
Then it was off to paint prison where alot of hidden damage was found. Not too bad tho.
Old 01-25-2013, 01:15 AM   #19
Fw190d9
Re: 69 Blazer build
And after getting parolled, its RED!
Old 01-25-2013, 01:19 AM   #20
Fw190d9
Re: 69 Blazer build
Next, I fabbed up some seat mount bases for the Escalade seats.
Old 01-25-2013, 01:24 AM   #21
Fw190d9
Re: 69 Blazer build
Then Dynamatted the whole tub for some serious sound proofing. Also mounted the winch bumper with winch and installed all the CST trim
Old 01-25-2013, 01:29 AM   #22
Fw190d9
Re: 69 Blazer build
Little stuff......
Old 01-25-2013, 01:33 AM   #23
Fw190d9
Re: 69 Blazer build
Couldnt find any aux battery trays, so I ordered another pass side tray from LMC and cut it up and reversed it to fit on the driver side to mount the aux battery. Also scored a battery separator that lets the ALT charge the truck battery first, then the aux battery.
Old 01-25-2013, 01:36 AM   #24
Fw190d9
Re: 69 Blazer build
Redid the repop LMC door panels and kick panels with a layer of foam and some GM escalade vinyl and finished the carpet
Old 01-25-2013, 01:39 AM   #25
Fw190d9
Re: 69 Blazer build
Made a subwoofer box and side panels from 1 sheet of 1/2" birch ply, then covered them in the same vinyl.
