Old 05-25-2012, 03:58 PM   #626
FrankieD
FrankieD's Avatar
Re: Rebuild on a shoestring.....continued
Here is good product works great for cleaning rusty fender bolts you if you are going to reuse them, lot easier than using a wire wheel.
http://www.theruststore.com/Evapo-Ru...FbEBQAodjE1SWw
94 k2500 EXCab Long Bed 350ci New Toy
95 K2500 Suburban New PlowTruck 454ci
Support our Troops @ http://anyairman.com
http://www.woundedwarriorproject.org/
FrankieD is offline   Reply With Quote
Old 05-25-2012, 05:56 PM   #627
VA72C10
VA72C10
VA72C10's Avatar
Thanks, I've used that before on other parts. Might have to grab some more for the future but thankfully I have a new front end bolt kit.
Old 05-25-2012, 06:03 PM   #628
VA72C10
VA72C10
VA72C10's Avatar
UPDATE: You guys know my propensity to change.....
So today I got a radiator (new 3 core) and some fenders as part of a parts swap. The other swap I had done a while ago but never had delivered was a rebuilt engine. I honestly was thinking it was on a stand but it has been run for a few months. For 1 second I was bummed when I saw it on the trailer and realized it wasn't fresh.
Then I get up close and realize it has a just rebuilt quadrajet on top of a complete motor. The update is this will now be the powerplant for this project . Ready for some paint (po did a lousy paint job) and drop in. Pics in a few...
Old 05-25-2012, 06:30 PM   #629
VA72C10
VA72C10
VA72C10's Avatar
Its a remanufactured block. 4 bolt mains 2pc rear main seal. It's my first ever corvette option (intake). Supposedly the cam is one step over stock and it has flat top pistons and big valve heads. Ill pull the valve covers tonight to verify which heads. The guy I bought it from had it in his truck and it ran well and sounded great so we shall see what it has once installed.
Last picture shows why I think it was a recent rebuild/install. Freeze plugs look new front and rear. We will see when I take off the valve covers
Old 05-25-2012, 07:54 PM   #630
brn agn
brn agn's Avatar
I hope the engine works out for you. I'm sure you already have checked out the casting number on your new purchase, but here is some more info if you need it:
http://67-72chevytrucks.com/vboard/s...d.php?t=226879
1969 C10 SWB Project Charity Case AKA "Roscoe"
1971 Cheyenne Super A Combined Effort
The Service Station-A practical ministry for those in need
brn agn is offline   Reply With Quote
Old 05-25-2012, 08:23 PM   #631
VA72C10
VA72C10
VA72C10's Avatar
Thanks and thanks for that link. I use nastyz28 sometimes but this time all the numbers came up on google.
This quote from your link makes me feel pretty good about it
Originally Posted by Wrenchbender Ret View Post
Ive put hundreds of them in light duty fleet trucks. You put the engine in tune in up a bit & send it out the door & never have to mess with it again. They are better quality then the original equip. engine in the car's & 1/2 tons. I would put it in with a good 4 barrel, HEI, & dual exhaust & it will probably do everything you want.
Old 05-25-2012, 08:49 PM   #632
Hmmmmm...spunds like you fit in there with me. Hope the engine works out for ya too. Been fun readingabout all you have done on it so far.
Old 05-26-2012, 01:22 AM   #633
VA72C10
VA72C10
VA72C10's Avatar
Won these headers on ebay tonight for 149 shipped to me. Ceramic coated mid length. Look like the sandersons that are a lot more expensive. They are for chevelles/camaros/etc....but several here have used them with some minor tweaks at the collector they are supposed to fit nicely....we will see shortly...
Old 05-26-2012, 01:34 AM   #634
lolife99
67-72 parts collector,…
lolife99's Avatar
I think you will have to modify the engine frame stands to make those headers work.
Look at this thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=521929
It's the front tube on each side that is the problem.
Keith
Convert to disc brakes.
Old 05-26-2012, 01:57 AM   #635
VA72C10
VA72C10
VA72C10's Avatar
I guess we'll see if these are exact copies of the hedman ones or not...I've heard several guys run these exact ones with no issues...the 158 ebay header thread I believe? Either way It's 200 less than the hedman ones and doesn't look like he had to modify the mounts that much...for right under 150 for new headers with 3/8" flanges and ceramic coating... I'm game to try and willing to do a little work to make them fit
Old 05-26-2012, 02:07 AM   #636
VA72C10
VA72C10
VA72C10's Avatar
Here is the picture of the heads. Looks clean. The bad news is they are 624 castings which are supposedly aren't the best heads chevy made Although most of that is guys wanting to build high hp motors...if you read guys with mild motors they seem to be fine. The good news is these were also corvette heads so they have the 202/1.6 valves in them...so they should be decent. The motor pulled strong in my friend's truck and he got pretty decent mileage so I think it'll make a great motor for the next owner.
Also a picture of the radiator...you can see the spots where the straps were still. A couple fins bent but nothing major and with a quick prep and paint will look very nice and should cool quite well being a thick three core...
Old 05-26-2012, 07:52 AM   #637
hgs_notes
GEARHEAD
hgs_notes's Avatar
Great deal on the headers. I hope they fit for you without too much work. The engine is looking like a great deal also. A nice solid build there. Paint it and drop it in.
hgs_notes is offline   Reply With Quote
Old 05-26-2012, 01:28 PM   #638
brn agn
brn agn's Avatar
The headers sound like a good deal and the engine looks clean...go, go, go!
Old 05-26-2012, 01:43 PM   #639
VA72C10
VA72C10
VA72C10's Avatar
Thanks guys, ordered a few other small parts last night (plug wires/grommets/skip white HEI (I had one but it has a clear cap) and earlier in the week got a set of restored small block brackets/pulleys from Livrat so should be able to bolt everything up when I get the engine painted. I could have of course restored an old set I have but I can do that and sell mine later....one less thing to have to do now...trying to get this thing done
Old 05-26-2012, 02:08 PM   #640
VA72C10
VA72C10
VA72C10's Avatar
Headed out for family time so won't get time on the truck until this evening...will try to get a little accomplished tonight to keep progress going...
Old 05-26-2012, 03:23 PM   #641
raull
raull's Avatar
good deal ,family always first , but we are youre second family !! c/10 family !!, so dont keep us waiting , lol
check out my build thread
71 c/10 step side 5.3 twin turbo
http://67-72chevytrucks.com/vboard/s...d.php?t=485320
raul
raull is offline   Reply With Quote
Old 05-26-2012, 03:46 PM   #642
hgs_notes
GEARHEAD
hgs_notes's Avatar
My wife calls this site facebook for chevy truck nuts. And like facebook, don't waste too much time online, spend it with the family and project.
Old 05-26-2012, 05:14 PM   #643
68 TT
Still plays with trucks
68 TT's Avatar
A set of square body clam shell motor mounts & stands will give you better clearance for the headers and give you better motor mounts too.
Got a link to the place you found those? I need a set for my 69.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
Old 05-26-2012, 06:18 PM   #644
VA72C10
VA72C10
VA72C10's Avatar
Family first for sure. This truck is like my job right now so I am actually getting more time with my family than most do. Sometimes being laid off can be a blessing.
That's a valid comparison. I do spend a lot of time on here but it speeds up my project by finding easier ways to do things. Now I need some air tools and I'll be really fast
I will post a link tonight. Just leaving the park. Had a great time. Thanks for reminding me about the square body mounts. I have an already restored set with new rubber I can use. Cool!
Old 05-26-2012, 07:25 PM   #645
VA72C10
VA72C10
VA72C10's Avatar
Looks like the seller is out of the headers for now at least...but a lot of other stores have these for similar prices...this was just the cheapest set I found
http://www.ebay.com/itm/160807584993...#ht_2986wt_952
Old 05-26-2012, 10:24 PM   #646
68 TT
68 TT's Avatar
Thanks for the link. Now I just need to let you test fit them with the square body mounts and see if they fit without damaging the ceramic coating
Old 05-26-2012, 10:34 PM   #647
VA72C10
VA72C10
VA72C10's Avatar
My plan is going to be to lower the engine down onto the stock mounts first...loosely bolt them on (with lots of tape where they might hit ) if they will bolt on and see if I can run them that way. If not, I'll drill the extra holes for the square body mounts in the frame and crossmember and install those...
Old 05-26-2012, 11:31 PM   #648
VA72C10
VA72C10
VA72C10's Avatar
Here are some pictures from today's family outing. Posting these for those that follow and also to force me to watch what I eat better
First pic is our whole family's favorite spot....the japanese gardens at maymont. Next is me and my girls at the waterfall there soaking their toes on a sultry day. Finally is a wedding we crashed on our way out of the park couldn't pick a much prettier spot. But the bride had a loooong walk ahead of her to the portico where the groom was
Old 05-26-2012, 11:33 PM   #649
VA72C10
VA72C10
VA72C10's Avatar
hmmm....first time my camera's done that and taken them sideways...guess the two pics I didn't take ended up like that...
Old 05-26-2012, 11:39 PM   #650
67cheby
67cheby
67cheby's Avatar
Thanks for sharing , it's great putting a face with someone I talk with so much !
67cheby is offline   Reply With Quote
