05-27-2012, 07:16 PM | #1 |
VA72C10
PRICES REDUCED Nice Cab, frame, bed and 70 truck part out
225 for the pair of doors (better than average originals with minor rust (some repaired already) and with good working internals most blasted/painted)- can have ready for paint for $300 total
500 for the rolling frame (had 500 worth of brake work/wheel cylinders/brake lines done recently-can provide receipts) trailing arm rear, front sway bar, sbc mounts, wheels and tires included Have listed on craigslist locally also. Picking up another project (a swb) from a member so looking to sell asap! Make an offer for one part or everything (all items plus shipping) bench seat 100 good foam and brackets (one that came in truck) super nice full foam 69-70 style for 125 available also) Gas tank with sending unit and good new cap 100 (truck ran great up until a couple months ago when I took front clip off and sending unit worked) Almost new drum/drum master cylinder with prop valve and lines 50 3spd pedal setup incl. z-bar, 50 e-brake pedal setup 25 heater box setup inside and out. Everything worked includes heater control-no broken levers (face is loose though) 100 good under dash wiring harness for gauges and heat. Everything electrical worked on this truck. No splices. 100 Windshield no fogging 75 Rear window 40 3ott column with shaft, rag joint no shifter handle 50 column brackets 15 for all three 67-70 gas pedal setup complete with rod to carb 50
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 06-10-2012 at 11:50 AM. |
05-27-2012, 11:15 PM | #2 |
VA72C10
Re: Almost rust free Cab, frame, bed
Open to offers on all of it or will sell together (cab/bed/frame)
Frame has a good working manual steering gearbox. Factory sway bar on the frame
Looking for a 67-72 swb or blazer project in or around VA. |
05-28-2012, 09:21 AM | #3 |
What has been repaired and what needs to be repaired on the cab? How is the drip rail/header panel,how is the cowl area,and how is it at the supports/rear brace areas?
05-28-2012, 11:04 AM | #4 |
VA72C10
I will take some better pictures this afternoon. No rust in the header/driprail area. The truck was originally a budget build looking to get it fixed and on the road honestly so I used some slip on cab mounts I had to go over the originals. New rocker panels. Pass cab corner patched. Will need drivers cab corner patch. There is a spot on the pass side floor near the jack I planned to fix but haven't yet. Front floor pans were better than average so two patches welded in. The pictures in the build thread should show pretty well what was done. But I didn't get cowl pictures before so I will look that area ovedr real well and let you know.
05-28-2012, 06:20 PM | #5 |
Ok,thanks. I didn't want to go through a thread to find pictures. The price isn't bad,but sounds not as almost rust free as what I had hoped.
05-28-2012, 06:48 PM | #6 | |
VA72C10
It's a great cab for someone who doesn't want to do their own body work who wants a solid cab for a driver/weekend cruiser. Not for a show truck. Also lowered the price. Looking to move it fast. Will try to post some more pics soon.
05-28-2012, 09:22 PM | #7 |
Re: Nice Cab, frame, bed
More pics of the cab please!
www.nsanehotrodz.com customerservice@nsanehotrodz.com 865-761-0460 Tennessee's #1 HotRod Shop! |
05-28-2012, 11:23 PM | #8 |
VA72C10
took some...getting ready to post...
05-28-2012, 11:25 PM | #9 |
Just a Member
Hey Jon...honesty how hard do you think it would be to modify a longbed to short? I think it would be fairly elementary... I would love to get this bed from you. After I square you up of course.
72 C-10 Cheyenne 350/350 ALL ORIGINAL 81,158 miles (1st) 69 7/8 ton(s & l) 66 327 short block rebuild.325 hp(2nd) 70 C-20 88 350 long block rebuild .040 bore. forged crank GM ZZ4 Hot Cam 1.5 roller rockers.375hp Aluminum TH400(3rd) 71 SWB frame off with 68 body. POSI PayPal: remimartin257@aol.com Business Inquires: 812 801 5111 "Help me, help you" that's my motto Members met... BuildinA68, jessewebb, daddymoo2, 70STOVEBOLT, irishfan77, feller, fine69, chevytruckguy70, jamie72, Nohatch, 2112, drtydog |
05-28-2012, 11:27 PM | #10 | |
VA72C10
doesn't look too hard...measure twice cut once Still a lot of welding to do though once you cut it....
05-28-2012, 11:29 PM | #11 |
VA72C10
I actually have two longbed complete rolling frames right now...one 5 lug and one 6...selling both to fund my project...both have swaybars. 5 lug is leaf rear/disc fronts.
05-28-2012, 11:33 PM | #12 |
Just a Member
I am in the same boat... I have a completely rust free 70 C-20 I been partial too. All in primer besides bed floor. Frame has already been painted.. not show quality but nice and clean for the next 4 decades at least. Got my built all roller 350 in it and I would probably swp in a nice solid 35o stock. I am ready to move to my 71 swb frame which I am putting a 68 body on.
05-29-2012, 12:46 AM | #13 |
VA72C10
been trying to post the pictures. Found rust in the drivers lower cowl. That will need some attention imho. I never noticed it before today. Not bad but definite rust. Shown in last picture. Keep in mind this was being built to be a solid driver. Not a show truck. Would never use slip on mounts on a show truck
05-29-2012, 12:51 AM | #14 |
VA72C10
In the picture above you see the metal has separated in the cowl. No rust holes. May be able to tac/spot it back together. That is what I would do
Here is a few more pictures. First is pass rocker and floor patched. Last few show the only spot left on the floor (in cab corner near jack as mentioned before) Then the underside and slip on supports. Posted via Mobile Device Posted via Mobile Device
05-29-2012, 02:27 AM | #15 |
VA72C10
this is all for sale locally also of course...
05-29-2012, 11:14 AM | #16 |
Moderator
Re: Nice Cab, frame, bed and 70 truck part out
If it's not a hassle, would you be able to post pics of the harness and fuse block?
Thanks~Leevon
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
05-29-2012, 01:15 PM | #17 |
VA72C10
I have a couple more nice ones already out of trucks I can take pictures of if you'd be interested. This one I want to wait to see if whoever takes the cab wants it before I contort myself under the dash to remove it
05-29-2012, 01:22 PM | #18 |
swb or lwb bed? more photos if swb, please
05-29-2012, 01:25 PM | #19 |
VA72C10
Lwb. Sorry, thought I had that in there
05-29-2012, 02:53 PM | #20 |
Moderator
Oh yes, no problem I didn't realize it was still installed, that would qualify as a hassle! When you have a chance, pics of the others.
05-29-2012, 04:49 PM | #21 | |
VA72C10
I'll get pictures later this evening...
05-29-2012, 06:25 PM | #22 |
VA72C10
Re: PRICES REDUCED Nice Cab, frame, bed and 70 truck part out
will throw in a complete 67 front clip if you buy everything and pick up by this weekend...needs work but it's a true 67 front fenders, hood, rad support, and grille/latch/center support/splash shield. (and I'm offering it for free with the package deal )
Looking for a 67-72 swb or blazer project in or around VA. Last edited by VA72C10; 05-29-2012 at 06:34 PM. |
05-29-2012, 06:34 PM | #23 |
VA72C10
also have a 69-70 or 71-72 front clip I can include in the deal if someone wants to make this a complete truck. These are both nice and would be 650 complete with used grills
rust free fenders, hood, core support and good hinges.
05-29-2012, 06:59 PM | #24 |
Just a Member
You are killing right here with this!!! I need a 67-68 front clip EXTREMELY BAD
05-29-2012, 07:04 PM | #25 | |
VA72C10
When can I expect you? I'll throw in several other parts if you can pick up soon. Need to clear up some room and sell this for the cash for the new project's needs...
