Old 05-27-2012, 09:04 PM   #1
SRVBLUES64
trottle questions
Not sure if I asked this one or not I have a 66 with a 350 I dont seem to be getting enough acceleration its kind of a slug. I have the typical trottle bar with threads on the end at the carb a 600 avenger that you can adj a bit but no matter which I go I still get nothing. Any thoughts and how to's? should I get a trottle cable if so how will that work on my truck Thanks
SRVBLUES64 is offline   Reply With Quote
Old 05-27-2012, 09:12 PM   #2
CRGRS 66
CRGRS 66's Avatar
Re: trottle questions
hmmm, maybe make a note of how far the throttle turns via pressing the gas pedal, disconnect it, and see if it will turn further. Maybe post up some pictures as well. Check your timing, if it is over advanced it will run, but will run very poorly when you start giving it some gas out on the road. Pinched fuel line, plugged fuel filter. Fuel pump going...
Some food for thought for you! Cheers! Good Luck!
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 05-27-2012, 09:14 PM   #3
CRGRS 66
CRGRS 66's Avatar
If someone has advanced the timing, they would have found the RPM's going up, and turned down the idle adjustment, so if it is the timing, and you retard it back to where it should be, the idle adjustment will need to be reset as well
Craigerrr
Old 05-28-2012, 10:16 AM   #4
SRVBLUES64
Thanks for the suggestions, I have a new fuel pump and a new fuel filter, and I believe the the timing is correct. I power brake it and is does not fail going forward meaning no stalling. When I push the gas pedal it just seems that the pedal does not have much travel even before the carpeting I was having this issue. I drove it yesterday and it runs nice however I push the gas all the way down nothing Thanks
Old 05-28-2012, 07:44 PM   #5
gimmy 64
have some one push the gas pedal all the way down and try and move the throttle on th outside and see if it goes farther. it could be throttle adjustment. what tranny are you running? if a 350 auto do you have the vacume on the back of tranny hooked up or the modulator could be bad
gimmy 64 is offline   Reply With Quote
Old 05-28-2012, 08:07 PM   #6
padresag
did you just change over from a 6 cyl. I think that you need a longer bellcrank where it comes out of the firewall. you may not be getting enough travel to open the throttle fully
ron
padresag is offline   Reply With Quote
Old 05-28-2012, 09:32 PM   #7
SRVBLUES64
I decided that pictures are worth a thousand words has they say
Old 05-28-2012, 10:05 PM   #8
SRVBLUES64
How mant questions can one guy have, well heres one more, I 've been hearing something about the tv cable? that if its not adjusted correctly it will destroy my trans? how do I know if Im ok?
Old 05-28-2012, 10:20 PM   #9
Rich 5150 69
Rich 5150 69's Avatar
First lets fix the throttle, disconnect the throttle linkage rod and kick down linkage, hold the carb lever all the way open and open the pedal linkage and compare, it not match you`ll need the longer linkage from a v-8 or change to cable assembly either aftermarket or off of a donor truck, when that is straight you can adjust the kick down linkage, is it a th350 or 7004r....?
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 05-29-2012, 12:56 PM   #10
CRGRS 66
CRGRS 66's Avatar
I second the motion, rule out (or correct) the throttle linkage, then move on to other possible problems.
Craigerrr
Old 06-01-2012, 09:45 PM   #11
SRVBLUES64
I thought about getting a cable anyone know what kind to get and where and how to install
Old 06-02-2012, 06:24 AM   #12
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: trottle questions
Edelbrock & Holley Carburetor Installation and Troubleshooting
http://67-72chevytrucks.com/vboard/s...d.php?t=504369
More Tech Videos Here:
http://www.youtube.com/user/HolleyPe...eos?query=carb
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
