Old 05-29-2012, 07:58 PM   #1
Bubba Aaron
Starting issues after reaching operating temperature
I have a 68 c10 with a 400 sbc. It's runs 11:1 compression with Keith black pistons. It has a edelbrock performer rpm top end. 850 speed demon carb and a complete MSD 6AL ignition. I run a electric water pump and fan and just recently had a 18 circuit wiring harness installed. As well as a new hi torque mini starter. My issue is after I start my pickup and it get to operating teperature and turn it off it won't start untill it cools. It does this untill my battery drains. I just had my alternator checked and it passed. I was told not to ground my battery to my aluminum heads so I moved the ground to the frame and i still have the same issue? Thx for any advice anyone can give.
Bubba Aaron is offline   Reply With Quote
Old 05-29-2012, 09:29 PM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: Starting issues after reaching operating temperature
First, welcome to the site...
I'm assuming here that when it does run you have no issues with it until it gets up to operating temp.
Since I'm not familiar with any carb but quadrajets the first thing to check is the choke, if you have one, to make sure it opens up completely when warmed up.
Next is to check inside the carb throat to see if it is flooding. Check with a flashlight and see if you can detect any dripping or a strong gas smell. You should notice black to dark gray smoke on startup out the tailpipe.
Check the battery cables at the end connections to make sure they're clean and if they're old, replace them. They corrode internally at the connection and it's not visible because of the insulation.
Check the battery posts with a vdc meter for 13.5 to 14.5 volts give or take. Mine checks out at about 13.8 volts when idling.
The only other thing that's a possibility is if the piston rings were not gapped correctly and expanding when engine is warm seizing the engine until it cools and they contract again. I've seen this only once but it can happen.
68gmsee is offline   Reply With Quote
Old 05-29-2012, 09:46 PM   #3
southern parts
southern parts's Avatar
check your timing too
southern parts is offline   Reply With Quote
Old 05-29-2012, 10:56 PM   #4
Bubba Aaron
The piston ring issue sounds like a possibility. Because shortly after getting my engine built I was getting oil spitting out my dip stick. So when I took it to a mechanic other than the one who put the engine together to do a compression test I was loseing compression anywhere from ten to twenty five percent compression per cylinder. So when I took it back to the mechanic who built it he reved the engine and poured automatic transmission fluid into The carb while reving it. After doing so the blow by stopped and oil stopped coming out the oil dipstick. could this hAve caused the ring gap to expand? Also the timing is at 14 degrees advanced if I remember correctly.
Old 05-29-2012, 11:19 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Originally Posted by Bubba Aaron View Post
..... could this hAve caused the ring gap to expand? Also the timing is at 14 degrees advanced if I remember correctly.
No. What he probably did is seat the rings in. Some recommend driving at different speeds and revving the engine several times while driving to introduce raw fuel into the cylinder walls. This removes the residual oil or dilutes it so the rings can seat quicker. The revving and adding tranny fluid does the same thing.
Play with the timing some. Maybe move it to 8 or 10 degrees btdc. Also check the vacuum advance to make sure it's working (you can use mouth suction) then hook it up to manifold vacuum if it's on ported vacuum.
Old 05-30-2012, 12:03 AM   #6
Bubba Aaron
It doesn't die on me. But when I shut it off there is no squeak but it does stay on for a second or two when the ignition is off an it sounds like pressure being released.
Old 05-30-2012, 04:47 AM   #7
Chevyman680063
Chevyman680063's Avatar
I had a similar issue with mine several months back and it turns out it was a hot start problem. The heat from the motor/intake was boiling the gas in the carb. I had to wait several minutes until it cooled down before it would start. I put a carb spacer on and it fixed the problem.
1963 Chevrolet C10 Short Step
1968 Chevrolet C10 Short Step
Chevyman680063 is offline   Reply With Quote
Old 05-30-2012, 07:06 AM   #8
hjewell2
hjewell2's Avatar
I dare say it is heat soak after you shut it off. try a 160* T-stat if you do not have one in already. 14* to 16* initail is normal for spicy motor what is the LSA and duration for the cam Maybe you can back it off tad. I myself never worry about initail I check for total advance 36*@ 3000 rpm. Does it crank over or does it ring the flywheel and not rollover when at this heat soak period. my LT1 motor is 11-1/2 with pop up pistons. when it hits the
90* mark its gets cranky (LOL) I know to let it set for an hour before restarting. At the racetrack I use fans to cool the engine bay between runs. Hope this helps.
hjewell2 is offline   Reply With Quote
Old 05-30-2012, 09:39 AM   #9
68gmsee
Active Member
68gmsee's Avatar
Sorry, I was responding to another post on the squeak and inserted into this one by mistake.
I have heard of what Chevyman mentioned on some carbs. It may be worth a shot.
Old 05-30-2012, 10:14 AM   #10
Bubba Aaron
Hjewelle it's doesn't crank over once it's warmed up. The electric fans turn on and run at full power. But it doesn't crank over
Old 05-30-2012, 10:39 AM   #11
hjewell2
hjewell2's Avatar
I bet when it does not crank the temp is saying 210* 220* with analog temp gauge. Two things I check first, Starter then T-stat, New Mexico I would use a 160* T-stat 400 chevy does not like heat. A starter will heat soak as well and cause the dead battery sound.
Old 05-30-2012, 10:44 AM   #12
Bubba Aaron
Hjewelle thx I'll change the therm. Cuz I just put a hi torque starter in it a few weeks ago. I'll keep you posted. Thx again!!!
Old 05-30-2012, 11:02 AM   #13
CC69Rat
CC69Rat's Avatar
Assuming it has headers on it? Do you have a heat shield on your starter .. or is the header pipe really close to the starter solenoid? Sounds like heat soak to me. (starter problems)
I usually run a big block high tourqe starter on high compression motors.
So when you turn the key it doesn't even grunt like it's trying to turn over it sounds like ?? .. if it tried to start up like it wasn't getting any fire then I would think carb or vapor lock / boiling in the bowls.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-30-2012, 11:09 AM   #14
Bubba Aaron
So if it is heat soak on the starter won't a 160* therm help with that
Old 05-30-2012, 01:04 PM   #15
CC69Rat
CC69Rat's Avatar
I wouldnt think so. If the header is close to the solenoid that tube can reach 1000 degrees or more. Ots essentially cooking the solenoid. As it cools it fires off again.
You could also try to fab up an aluminum heat shield for it, just something to keep that crazy hot header tube off or at least away from the starter. I had a 69 camaro with this very same problem and the heat shield took care of it.
Chad
Old 05-30-2012, 01:49 PM   #16
Bubba Aaron
Would a header and exhaust wrap work?
Old 05-30-2012, 02:13 PM   #17
kwmech
Put the ground cable back on the engine. Get a 2 ga. cable and put it as close to the starter as you can. Also put a 2 ga. pos cable on the starter lug. Another possibility is the purple wire for the cranking, the eyelet over time has a tendency to attract oil from leaking valve covers and such. Another thing is the quality of the battery and the CCAs
Old 05-30-2012, 02:26 PM   #18
CC69Rat
CC69Rat's Avatar
Post up a picture of the exhaust tubes as the run down by the starter. Pass side of course.. just to see how close it is..
Yes header wrap might help too..
Not saying this is the problem but definitely a possibility. Speaking from experience
Chad
Old 05-30-2012, 04:27 PM   #19
SS Tim
SS Tim's Avatar
That is where I'd start. If you grounded the battery cable to the frame and not the head you may have a weak ground path for the starter. Running a ground cable from your frame ground point to the starter can really help.
SS Tim is offline   Reply With Quote
Old 05-30-2012, 07:53 PM   #20
Bubba Aaron
Unhappy Re: Starting issues after reaching operating temperature
Well I wrapped the solinoid with a thermo shield and that didn't work. N I don't think it's vapor lock or I'm assuming. Cuz the engine doesn't even turn over once it turns of. I'm thinking the rings are seizing the engine. But what if I get the rings changed and the problem persists.
Old 05-30-2012, 08:15 PM   #21
SS Tim
SS Tim's Avatar
If the motor had a mechanical issue the starter would try to do something. A solid soleniod clunk but nothing turns. Have you tried hot cranking with the headlights on? If the starter is stalling they would go out.
Old 05-30-2012, 08:18 PM   #22
Stevo427
Starter like above or I'd check the timing.
Stevo427 is offline   Reply With Quote
Old 05-30-2012, 08:27 PM   #23
68gmsee
Active Member
68gmsee's Avatar
Okay, what if you don't turn it off? Does it stay running?
If I understand you correctly, the engine isn't even trying to turn over once you turn it off. In other words if you have someone try to start it, you don't hear a click or anything that sounds like the starter is at least making an effort to turn the engine. Right?
Old 05-30-2012, 08:31 PM   #24
CC69Rat
CC69Rat's Avatar
Does it have an HEI in it? maybe that resister wire?
Chad
Old 05-31-2012, 12:01 AM   #25
Bubba Aaron
Correct 68 gmsee. Like the starter ales a half turn n that's it then just clicks after that
