Old 05-30-2012, 03:32 PM   #1
NoNeck
NoNeck's Avatar
How Do You Remove the Knobs from Heater Panel?
I am replacing a missing lower heat control arm on a '70 GMC. I have a replacement arm with the little chrome knob, but can't figure out how the knob comes off the arm. Does it just pull off? I don't want to break my replacement arm if I am missing something.
I can't remove the replacement arm from the old panel with the knob on.
Thanks,
NoNeck
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 05-30-2012, 05:24 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: How Do You Remove the Knobs from Heater Panel?
Yes, they just pull off. They can be tough to get off. I don't have any secret chants or VooDoo spells to make it easy, but if you can get something behind them and pry a little bit they should come off. Just move the lever to the off position and put some kind of padding on the face of the panel to protect it.
LockDoc
Leon
Old 05-30-2012, 07:54 PM   #3
JimKshortstep4x4
I use a pair of needle nose pliers and close the jaws gently up to the lever so that the knob is touching the needle nose. Once the pliers are in place I use a small hammer against the needle nose pliers to drive the knob off.
It works well and the knob is not damaged. A small thin open end wrench would probably work also.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
