05-30-2012, 09:03 PM | #126 |
Re: Project: LS1ick68
I just noticed I have the wrong flexplate! The holes don't line up with the torque converter nuts.
So, no, we are not done yet, B.
05-30-2012, 11:59 PM | #127 |
Truck and auto performance nut
hang on.....is it just like 1/8"-1/4" off? Several of us have had to elongate the holes in the flexplate because the bolt pattern on the flexplate is about 1/8"-1/4" off (larger or smaller, can't remember)... from the bolt pattern on the torque convertor. your not changing much or effecting balance...just making slots vs holes on the flexplate for mounting.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
05-31-2012, 06:26 AM | #128 |
Yeah, the holes on the flexplate are about 1/4" off. Either way, the trans has to be moved out of the way, and the flexplate removed.
06-21-2012, 02:03 PM | #129 |
Well I've not made much progress lately. I've been a bit under the weather. I've had some sort of viral bug for the past couple weeks, and I just don't feel much like working out in the heat and crawling around under the truck. Along with my sons baseball games and practices, when I have felt like doing something, I haven't had the time.
Anyway, enough of my whining. Here's what I have accomplished. I bought the 750 HP Street carb from Kurt(68GMCCustom). Worked on mounting the fuel lines. I wish someone made clamps with holes bigger than 1/4". I had to drill out these clamps to use 10mm bolts. I'm gonna take them along with the bolts to my buddies machine shop to make them look a little cleaner. Here's how I had planned to run my steam lines, but I don't really care for it. A friend of mine gave me a better idea that I may try. I'm trying to keep from running AN lines which is costly. So far, I've got about $12 in this setup. Here's the modified power steering hose. It's not pretty, but it will do for now. Wiring finally put into loom and cleaned up a bit. With my custom plug wire looms, the Lokar dipstick interfered, so I cut 8.75" out of the housing and the dipstick cable itself. The dipstick handle should sit underneath the headers. This will make checking the oil a real PITB, especially when hot, but at least it works. Things not pictured: Driveshaft is shortened with new 1310 U-joints, painted and ready to install. Lokar TV cable installed at transmission end. I still need to cut it to length after the carb is actually installed for good. The headers are coated and ready to be picked up. Hopefully I can go get them today or tomorrow. I'll get pics of them when I get them. I bought a Lokar column shifter linkage setup, but can't finish it until I get the headers back to know where to bend the arm. I still need to wire the fuel pump. I found a fused wire from my fuse panel to hook it to. I just need the time to route the wire along with the rear light section of the harness. I also need to plumb the trans cooler lines. I'm not sure if I want to run an external cooler or just run it with the cooler in the radiator. I may just hook it to the radiator for now with a temp guage and see what the temps run, and if I need it to add a cooler, I can later. Lastly, I need to ream the holes in the flexplate to fit the torque converter. The only things left to pick up is an alternator, belt, hoses and a trans dipstick.
06-21-2012, 03:02 PM | #130 |
A guy with a truck
Lookin' good!
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
06-21-2012, 03:17 PM | #131 |
Very nice, keep up the good work.
Rex |
06-21-2012, 03:43 PM | #132 |
VA72C10
looks great!
Looking for a 67-72 swb or blazer project in or around VA. |
06-21-2012, 03:47 PM | #133 |
Nice progress
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-21-2012, 08:36 PM | #134 |
Wow that looks amazing. Very clean
82 c10 5.3/4l60 84 c20 5.3/sm465 85 chevy k10 suburban LQ4/4l60 91 chevy c10 suburban Lsa 5.3/4l60 2017 Silverado whipple 5.3 1964 Vw beetle 1974 vw beetle |
06-21-2012, 10:05 PM | #135 |
Restoration Virgin!
Looking good Matt...I'll get those parts off this weekend and get them boxed up for ya!
Great seeing ya last weekend...thanks for stopping by!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
06-22-2012, 06:27 AM | #136 |
Thanks for all the compliments, guys.
Thanks, Geoff. It was fun hanging out with you and Jeff at the show. How did the awards go?
06-22-2012, 06:33 AM | #137 |
I got the headers picked up yesterday!
I'm hoping to get some more work done on it this evening. I may try to pick up an oil primer setup today at lunch and pick up some oil and filter. If I can get the oil system pressurized and get the wire routed to the fuel pump, I may try for a short startup. Don't go getting your hopes up, yet. I'm going to shoot for it, but it may not happen.
06-22-2012, 10:45 AM | #138 |
A guy with a truck
Sho is purdy!
06-22-2012, 11:24 AM | #139 |
Sho' is!!!!
That said....sweet detail work as always Matt! Posted via Mobile Device
06-22-2012, 11:52 AM | #140 |
Nice looking headers.
Kim |
06-22-2012, 01:28 PM | #141 |
Grandpa in the rustmobile...
Like said above, great attention to detail its a beautiful truck!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
06-22-2012, 04:02 PM | #142 |
Restoration Virgin!
Neither one of us received a trophy Oh well...we had a great time and the folks there were sooooo nice! BTW....That red lowered C10 across from me got 2nd and the turquoise and white one was 1st
06-25-2012, 08:19 AM | #143 |
Thanks again, guys!
Geoff, That's no surprise seeing those trucks getting first and second. As long as you had a good time is all that matters.
06-25-2012, 08:31 AM | #144 |
Monday morning update of the weekend. I never got to work on it Saturday, but on Friday evening, I got the wire ran and hooked up to the fuel pump. I worked on the shifter linkage a little bit, and got the arm bent where it needs to be, but I still have to work on it a bit more to get it just right.
I borrowed an oil pressurizer from a local machine shop, but I need a 1/4" to 1/8" adapter to make it work, and I just completely forgot to pick one up while doing all my errands and running on Saturday. I'll pick one up today and get it lubed up this evening.
06-25-2012, 11:19 AM | #145 |
Looking good matt.
Never wrenched a day in my life and now... Im doing a frame off restoration on a 1968 C10 with a Porterbuilt Dropmember, Acuair E-Level kit, Boyd Welds Gas tank and mild c-notch. Click here to view my build |
06-25-2012, 08:56 PM | #146 |
Who did your headers? I used to drag race with two brothers who did coating between knoxville and sevierville. That was 15 years ago and I have forgot their names and the name of their business. Thanks, SUPER looking truck.
06-26-2012, 02:27 AM | #147 |
Please just do your steam lines in AN, your pictures of a nice clean engine are great minus that mess you have as steam lines. I think a -4 line size should be fine and the smaller lines cost much less than the bigger stuff.
06-26-2012, 07:38 AM | #148 | ||
This will also be the possible way of routing with AN lines. I'll use a -4AN-1/8" NPT T-fitting in the pump, 90deg -4AN-1/8" NPT fittings at the ports, then connect them to the T-fitting This also may help with cost since less fittings will be required. I had someone from another forum also mention the power steering lines needing to be changed to AN lines. I would do this also, but I eventually plan to change from the bulky truck accessory drive system to a cleaner, more compact setup from Wegner Motorsports later down the road.
06-26-2012, 07:48 AM | #149 |
C10 Club Tennessee
Is it running yet?
Bryan www.gmtruckshow.com Project "Andes"-Halen's First Truck Project: Patina Burb for he is God’s servant for your good. But if you do wrong, be afraid, for he does not bear the sword in vain. For he is the servant of God, an avenger who carries out God’s wrath on the wrongdoer. Romans 13:4 |
06-26-2012, 08:32 AM | #150 |
I'm going to start it this evening. I don't have a belt, alt., hoses, fluids or the trans hooked up, so it'll be a short run, but I'm gonna start it. I want to hear this mother sing!!
