06-02-2012, 11:40 PM | #1 |
70+ ( Old Skool Club )
85 S/Box Silverado Dual Fuel Tank Question
Last week me and a friend flew to LA to pick up a 1985 S/Box Silverado 305,4 bbl. A/T truck which we drove 1800 miles home. We made it but had a strange issue on the way home. Day 1 we drove from LA to Vegas without incident. Day 2 heading north up the I15 about 50 miles from Vegas going up a slight hill the truck started bucking and feeling like it was gas starved yet when we were coasting down a hill or on the flats or pulled over idling it ran perfect. The truck has the factory dual tank setup and we were only going to use the left tank as we knew it worked. As we drove the sputtering and starving got worse. When we hit Mesquite Nevada we were limping pretty good so pulled into an AutoZone store and asked ( this was Sunday of the Memorial Day weekend) if they knew of a garage that was open. There was no one open but a local young man has a mobile repair service and he came. He changed the fuel filter on the carb but that didn't help. As we were test driving after the fuel filter change and the truck was acting up the mechanic flipped the gas tank switch and the truck straightened out. The mechanic then suggested that is was probably the valve that is mounted on the frame that controls the flow from the gas tanks. He changed that for us and it didnt help as the truck still bucked and f**rted on the left tank but ran perfect on the right tank. We headed home using the right tank and made it with almost no issues. The truck started hesitating a bit going through the mountains in Idaho and Montana but never to the extent that we had to pull over. Over the next two days we drove exclusively on the right tank and when it reached the half full mark that is when the truck hesitated. I'm thinking the gas tank sending units are shot but my friend and a few friends we've talked to think its the fuel pump and my thinking on that is if its the fuel pump it would act up on either tank. Has anyone experienced this before with a factory dual tank truck?
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
06-03-2012, 08:16 AM | #2 |
Re: 85 S/Box Silverado Dual Fuel Tank Question
My thought is the fuel pickups also, or at leas the socks on the pickups.
Far as the right tank, are you sure the gauge is accurate. When my original hit !/2 tank she was empty. Fuel was fuel, but empty was 1/2.
06-03-2012, 10:20 AM | #3 |
Fuel pump that's what happened to me
Going up hills and felt like it was dyeing and was jerking Posted via Mobile Device |
06-03-2012, 12:14 PM | #4 |
Moderator
What led him to believe the valve was at fault? If it's sucking air at the valve it will leak when it's off. If it's leaking internally you can blow 5PSI through it to check. Parts changers.
Was the LH tank full when it misbehaved? When the RH tank reads 1/2 how many gallons does it take to fill? It's a 16 gallon tank that should take 12-15.5 to fill from empty on the gauge. You may have crud in the tank being kicked loose by higher alcohol content fuels or just plain rust blocking the socks. I've seen pinholes in the sender pickup tubes at around 1/2-1/4 from the tank bottom. Pull the bed, then the senders, and take a look. Replace the rubber fuel hoses while you're down to them. If the tanks are dirty but sound you can get em cleaned and just replace the socks. You could be sucking air around the hoses on the new switching valve that the parts changer installed. Look for wet fuel lines.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
