Old 06-04-2012, 08:06 PM   #126
Car'n'Guitars
Car'n'Guitars's Avatar
Re: Build #2 Crusader!
Cool great to see an update on this truck.
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 06-04-2012, 11:11 PM   #127
mcbassin
Still Learning
mcbassin's Avatar
Very nice progress!
Old 06-06-2012, 05:29 AM   #128
mrhino
Deb has I always like cab clearance lights and this truck didnt have any. So I ordered some from ebay. I marked, then drilled holes and got the new lights mounted, and wired up.
mrhino is offline   Reply With Quote
Old 06-06-2012, 08:04 PM   #129
stepside83
stepside83's Avatar
id be intrested in the sound deadner kit if your gonna sell any, and project is looking good
stepside83 is offline   Reply With Quote
Old 06-07-2012, 05:48 AM   #130
mrhino
Yes I will be, I just need to get some consistent packaging lined up.
Old 06-09-2012, 08:12 AM   #131
mrhino
decided now would be as good time as any to replace the the old heater box with a A/C unit from a donor truck. Call me dumb, But to my surprise it was not just a bolt in replacement. I honestly figured all the firewalls were the same coming down the assembly line. I had to cut the firewall on the evaporator side . Also needed to drill new hole for the heater box. but other than that it wasn't to hard. when I stripped the donor truck I was careful to take all the wiring, cables, and vacum lines on the control unit, so it made the transferring everything very easy. now just need to get a condenser mounted in and get the compressor mounted when I rebuild the engine and install that.
Old 06-14-2012, 08:55 PM   #132
mrhino
got the truck out, put the bed on, stripped it of all its glass, grill, markers, and seals and started sanding on it getting it ready for some epoxy.
Old 06-14-2012, 09:00 PM   #133
Car'n'Guitars
Very cool look forward to seeing more of it.
Old 06-15-2012, 09:18 PM   #134
indyrenegade4x4
indyrenegade4x4's Avatar
very nice build. like the short bed on it.
indyrenegade4x4 is offline   Reply With Quote
Old 06-15-2012, 09:21 PM   #135
Low Elco
Progress looks good! Good to see Momma out there helpin'!
Low Elco is offline   Reply With Quote
Old 07-17-2012, 02:06 PM   #136
Car'n'Guitars
Any updates on this truck?
Old 07-17-2012, 02:48 PM   #137
Low Elco
Yeah, hows it going?
Old 07-17-2012, 04:54 PM   #138
mrhino
Haven't made a whole lot of progress. between my work schedule, having to transfer all my pics, documents, music and everything else to a new computers, family members passing away, fixing the wifes car, fixing my daily driver, and this years unbearable heat. I just haven't spent much time in the garage.
Anyway When I last left off we were sanding it and getting it ready for some primmer.
I soon discovered the driver door had been hit and was full of mud and was not repairable (at least by me anyway) so I search the local junk yard and to my surprise found a good door actually it was a new door someone had put a on a old truck and somehow it ended up in the scrap yard. anyway paid $30 bucks for it and took home and painted the inside then hung it on the truck.
spray whole truck in two coats of epoxy primmer
as you can see this primmer dries in a nice semi gloss black. so if you sand it with long sanding block it reveals all the low spots nicely.
So thats where Im at now. I need to finish spreading and sanding the filler (what joy)
oh and this is my new daily driver Thank god the A/C works!
centercaps are on the way
Old 07-17-2012, 06:49 PM   #139
Car'n'Guitars
Sorry to hear about having family passing. The heat has been pretty bad, great progress so far looks great.
Old 07-18-2012, 12:52 AM   #140
96twodoor
96twodoor's Avatar
Great progress , keep it up
96twodoor is offline   Reply With Quote
Old 07-22-2012, 06:25 PM   #141
gtdownonit
Any word on the insulation kit?
gtdownonit is offline   Reply With Quote
Old 07-26-2012, 09:12 PM   #142
mrhino
Yes, I just got the insulation aka sound deadner today I have amost 900 sq ft of it so I hope you guys will be needing some. Im working on getting package quanities and shipping boxes. Im thinking of putting together kits like Dynamat does a 12 sf , 36 sf and then ill add 60sf for the crew cab guys. all will be much, much cheaper than dynamat extream.
Old 07-28-2012, 07:43 AM   #143
mrhino
My old winter beater is going in the demo derby today at my local county fair. I donated it to the local fire dept. I first took everything that was any good off of it., which wasnt much. When its all said and done it will go to the scraper. I am seriously considering taking the engine and trans out when the demo is over if its still good. I just dont have the time right now, although id like to have them for future projects.
Old 07-28-2012, 12:51 PM   #144
68 Four on the Floor
68 Four on the Floor's Avatar
Now that a good use for an old beater truck. Serving a good cause!
68 Four on the Floor is offline   Reply With Quote
Old 07-29-2012, 08:13 PM   #145
mrhino
the aftermath:
Old 07-29-2012, 08:14 PM   #146
Car'n'Guitars
Did it win?
Old 07-29-2012, 09:13 PM   #147
mrhino
na it went out fairly quick. there were several square bodies out there, but there was this 63 ford that looked like it had been in many battles so it was well crumpled. his truck was so soild it came out looking the same as it went in. my truck took a hard hit in the driver front wheel and it broke the steering shaft at the gearbox. so it could not steer anymore plus the front bumper was in the tire.
it was pretty cool to watch it though
Old 07-29-2012, 09:15 PM   #148
Car'n'Guitars
Yeah I wish we could have made it out to the fair this year.
Old 07-29-2012, 11:13 PM   #149
gtdownonit
Let the fire department cut up the front end then grab out the engine.
Old 07-30-2012, 05:40 AM   #150
mrhino
None of us seam to have time to do that. there were only couple guys working on it. I thought about the night before and I already have 4 small blocks I guess I dont need another just sitting around in the way. I did manage to snatch off all the throttle body injection stuff before it heads to the metal recycler this morning.
all in all she donated quite a few good parts that will live on in my other projects. and the cash I get from the scraper will also go in to the project budget fund.
black, disc, paint, seats, shortbed
