06-05-2012, 01:02 AM | #1 |
343 3/4 t 2wd axle for a 4x4
im considering changing my 87 4x4 fr. & rr. 10 bolt 373 axles for a more fuel efficient set (rear now has a little whine) i found a rear axle from an 80 2wd tag says 343 im told that the 342 fr 4x4 axle works fine with this didnt want to purchase it and not find a compatable fr. axle thanks
1990 chevy 4x4 with a 1940 IHC body |
06-05-2012, 02:21 PM | #2 |
Re: 343 3/4 t 2wd axle for a 4x4
If you're gonna do any type of serious or even semi-serious wheeling, stay away from the 10 bolt and look for either a 14b semi-float or a full float
06-05-2012, 08:32 PM | #3 |
ty kwmech, i found a 78 14 bolt 373 its an 8 bolt can that axle be drilled for 6 bolt? spring pads/u joints work? thank you again
06-06-2012, 04:02 AM | #4 |
IF it's out of a 3/4ton truck, the spring pads should be ok. You might have issues with the rear u-joint, but a conversion joint should fix that.
My Projects: 1960 GMC 1/2ton with 305 V6 (daily driver) 1963 Chevy 1/2ton 2wd...converting to 4x4 1967 Suburban 1/2ton 2wd My Girlfriends Projects 1985 Chevy Suburban 3/4ton 4x4 with 6.2L diesel, 4" lift, converted to TH-400, Warn Premium manual hubs, & Wildcat 315/75/R16 tires. (daily driver) 1978 Camaro Type LT with a Marine 350 & vortec heads, Rochester Carb, & roller cam 1978 Camaro Z28 |
06-06-2012, 08:41 AM | #5 |
You can find a 14-bolt semi-floating axle from a heavy 1500 with 6-lugs. You will need to move the spring pads.
06-09-2012, 04:56 PM | #6 |
the 3:42/3:43 will work together, but it will take a bit longer to switch into overdrive the higher ratio you go (lower number=higher ratio), so its a crap shoot as far as fuel savings. I like the 6 lug 14 bolt semi-float idea myself
