installing a T700 need some help
Hi guys,
I want to install a T700 in-place of my T400 because of my gas milage. Can anyone tell me what is involved. I already have the T700 It came out of a chevelle so it should bolt up, the box is rated to 600+hp, it has a lock up converter and all the cables/hoses that go with it. Do you need to cut the cross member, how does it mount, will the linkages fit straight on to the column shift or do I need an adaptor, etc??? I tried searching the site for info but couldnt find what I wanted, did I miss it? Its a 72 2WD 3/4T 454ci Thanks in advance!
*1972 454ci Burb, C20 3/4T, T700, 2WD *1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES Last edited by 72 DIRTY RAT; 06-05-2012 at 02:31 AM. Reason: extra info |
Junior Member
Re: installing a T700 need some help
Been a while since I did mine, but from what I remember the linkage worked fine and I used the same cross member Just had to drill new holes in the frame to mount it further back. You will probably need a different driveshaft (longer) at least I did. You will also need something to make the converter lock up. There are many different ways to do it and you can find info on a search here, but I went with the painless wiring lock up kit, it was super easy to install and comes with a new lock up solenoid and brake switch. One last thing you will need a bracket to mount your TV cable, I think I used an Edelbrock one that I purchased from Suimmit racing, it bolted to the intake and had provisions for the TV cable as well as the throttle cable. Thats what I remember, there are probably more knowledgeable people here on the subject, but maybe this will get you started.
71 C10 Step Daily Driver 72 K10 Suburban Work in Progress www.louisianaclassictruckclub.com |
The Older Generation
Use the Google search box at the top of the page but type in 700r4 instead of T700. Then click in the circle in front of 67-72chevytrucks.com and click on the "Google" button. LockDoc
Thanks Guys! Good call, I found this... http://67-72chevytrucks.com/vboard/s...ad.php?t=33266
*1972 454ci Burb, C20 3/4T, T700, 2WD *1969 540ci Vette, 540ci Aluminum BB,755 BHP & 734 LbFt torque, No NOS, No Forced induction! Just BIG CUBES Last edited by 72 DIRTY RAT; 06-06-2012 at 08:57 AM. |
#5 | |
![]() LockDoc
