Old 06-06-2012, 02:38 AM   #1
MikeS.
MikeS.'s Avatar
Moving a front seat
I'm thinking I'm going to need to move the front seat back some on my 63 burb. I'm 6'6" and have had issues with these pick-ups in the past. I'm thinking the burb is going to be as well.
Will it be feasable to unbolt the seat, drill new holes and rebolt back a few inches? Are the seat bolts into the frame or just the sheet metal or???
Thanks.
Past Master
Triluminar Lodge #117 GL of WVa
My 1963 4x4 Suburban build;
http://67-72chevytrucks.com/vboard/s...d.php?t=531274
My Gallery, now with pics of my 1966 C30 motorhome.
http://67-72chevytrucks.com/gallery/...&ppuser=103447
MikeS. is offline   Reply With Quote
Old 06-06-2012, 03:11 AM   #2
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
Re: Moving a front seat
I don't see a problem with that , espically on a burb. the original location just has a 4 inch square pad made out of some heavy guage metal, with some captive nuts welded to it, this piece is spot welded to the underside of the floor. only problem that might arise is the rear bolts might line up with the center body cross brace. if that happens you should still be able to make it work, just might have to drill another access hole in the body brace.
Old 06-06-2012, 09:05 AM   #3
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Might be a good time to lower the seat. Buddy of mine is all upper body height and has to twist his head to get into vehicules. Course for those of us that are not that tall you feal like a kid again in his modified seat.
Old 06-06-2012, 10:54 AM   #4
66 lwb cs
66 lwb cs's Avatar
Do you know of a link to the mod he did to his seat to lower it Im trying to figure out a good way to do this too
66 C20 LWB CS 327/TH400 A/C
66 lwb cs is offline   Reply With Quote
