Old 06-06-2012, 08:42 AM   #1
1963c-10
1963c-10's Avatar
wiper motor /washer question
Trying to convert my single speed wiper to the two speed w/washer. All of my research shows that 63-72 are interchangeable. The question is what are the difference in the 60-62 motors that wont allow them to interchange with a 63? They use the same switches, transmission arms, wiper heads/arms, so why wouldn't they fit a 63? Any help would be great. I have the switch, bottle, bracket and nozzles (already were on truck, but none of the other stuff was), so im looking for the motor/washer assembly. Have found a unit on a 62, but I dont know that it'll work.
1964 Short bed trailer
Old 06-06-2012, 09:08 AM   #2
theastronaut
theastronaut's Avatar
Re: wiper motor /washer question
I've got one in the for sale section from a '66 that I parted out, havn't been able to check it though.
theastronaut is offline   Reply With Quote
Old 06-06-2012, 03:15 PM   #3
63sbssbbw
UCA63
63sbssbbw's Avatar
60-62's mounting is different
And the motor is situated differntly(90 degrees).
everything outside the cab is located in the same spot,( hence the common rods and linkage,everything behind the cowl is different.
i'm working on converting my 61 cab to a 63,not too difficult,but the wiper motor mount is one I'm considering cutting out to swap.
mainly because of avialibility of the the later motor(and the more likelyhood of finding a 2 speed).
Trent
member#7816
"63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt
'61 GMC in progress
'63 GMC to use for parts
'90 Chevy Ext cab sbfs 5.7l (current d d)
63sbssbbw is offline   Reply With Quote
Old 06-06-2012, 03:56 PM   #4
1963c-10
1963c-10's Avatar
Thanks trent. Thats the info I was looking for. But 63-72 are interchangeable from the research Ive done...anybody know anything different from this?
Old 06-06-2012, 05:07 PM   #5
markeb01
Senior Enthusiast
markeb01's Avatar
Newport Engineering has pictures of the two different mounting styles, but I don't remember which is which. On my 1960 the wiper motor lays flat against the firewall:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-06-2012, 10:07 PM   #6
Captainfab
60-66 Nut
The '60 and '61 mount as shown in the first pic in Mark's post above. Then '62-'66 uses the mount shown in the second pic.
Old 06-07-2012, 09:19 AM   #7
1963c-10
1963c-10's Avatar
Thanks for all the help guys. I have an extra 1 speed motor from a 61 to find a home for and will have a single speed from the 63 once I get the 2 speed motor/washer installed. I didnt have time to get by the 61 yesterday...I was going to take some pics since the cab is gutted, but Markeb01 beat me to it. Thanks again
Old 06-08-2012, 07:54 AM   #8
maxwoof
The 61-62 shop manual supplement has some details as to the differences. I have a 62 that I am working on installing a washer system. With respect to the washer system it looks like 60-61 are the same, 62-63 are A little different and 64 up interchange. I notice that when I look up the washer at various part suppliers, they usually list 64 and up.
maxwoof is offline   Reply With Quote
Old 06-08-2012, 08:13 AM   #9
1963c-10
1963c-10's Avatar
Yeah Ive noticed that with about half of the ones I looked at. And 1/2 of the show 63-72. Makes it harder to want to jump on a unit when you dont know for sure that it'll work.
Old 06-08-2012, 08:30 AM   #10
McCoyAZ
McCoyAZ's Avatar
Curious to know if a guy could adapt one of the newer delayed wiper systems into a 60's truck? Would love to have one in my 64 stepper.
McCoyAZ is offline   Reply With Quote
Old 06-08-2012, 09:24 AM   #11
64shortbox
64shortbox's Avatar
Smile Re: wiper motor /washer question
I also wanted windshield washers and a radiator overflow I pulled a washer/overflow combo from a Ford Exploder. Cleaned up the crusty over flow side with Lowe's cheap version of CLR, moved my horn to a 73 C-10 location next to the radiator between the grille & radiator support and moved the voltage regulator & horn relay to the front side of the radiator support using the existing holes. Less than $22.00 including the CLR stuff and now it's all good. I'm CHEAP!!!!!
64shortbox is offline   Reply With Quote
Old 06-08-2012, 09:53 AM   #12
1963c-10
1963c-10's Avatar
Talk to MarkeB. He did this conversion on his truck.
Old 06-08-2012, 09:55 AM   #13
1963c-10
1963c-10's Avatar
64shortbox...I like the work you did, but Im looking for an stock look. the assembly book shows two different mounting locations for the factory bottle. In one pic it shows th ebottle to the right of the radiator and in another it shows it mounted on the firewall by the master cylinder. Also...did Chevy trucks ever use the OptiKleen glass bottles or always plastic jugs?
