Old 06-08-2012, 06:47 AM   #1
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Question Help identify 4 spd shifter
Got this chrome shfiter from a 72 C20 but doesn't match the ones in my 2 trucks. They are painted and have 2 bends where this has only one. Could this be newer?
Thanks,
Bob
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 06-08-2012, 12:37 PM   #2
camrycurt
camrycurt's Avatar
Re: Help identify 4 spd shifter
From what I understand the single bend SM465 shifter like in your pics is the 4x4 version, while the double bend shifter is for 2x4 trucks.
FWIW, I think the chrome versions are harder to find (especially in good condition), so you might have a treasure on your hands!
I'm sure others will chime in to correct me if I'm wrong.
Curt
1970 C/10, 250 L6 with Rochester BV carb, SM465 4 speed, 3.73 open rear
camrycurt is offline   Reply With Quote
Old 06-08-2012, 04:32 PM   #3
yfs200p
E.H.F.D Engine #2
yfs200p's Avatar
You're wrong, those things are a dime a dozen. You should probably just send it over to me and I'll throw it out for you! LOL
All kidding aside, any single bend shifter like that is from a 4x4 in years 67-72 only. The chrome ones were only available in higher trim levels, Cheyenne and cheyenne super. If you don't need it, I would do some research on how much it's worth and offer it for sale on the parts board. It's a pretty rare item that someone might really be looking for. But that part is up to you!
Also, many of the 73-87 ones were chrome, but they all had two bends in them.
-NICK
'72 K10 SWB Fleetside. Avocado Highlander 350-4speed-NP205 Frame Off Re-Creation
'89 GMC V3500 C/C Flatbed Plow Truck 454/SM465/Np205
'15 Chevy 2500HD CCSB High Country Duramax
'22 Tahoe Premier Duramax
yfs200p is offline   Reply With Quote
Old 06-08-2012, 04:33 PM   #4
David67
David67's Avatar
Looks like mine. Factory SM420 in my '67 C10.
1967 C10
Fightin' Texas Aggie Class of 2015
IG: david_r67
David67 is offline   Reply With Quote
Old 06-08-2012, 09:08 PM   #5
odog
odog's Avatar
I think that is a sm420 shifter, at least it looks like my sm420 shifter, only mine isnt chromed.
1969 4x4
Nothing beats a good rock drill and some dynamite
odog is offline   Reply With Quote
Old 06-09-2012, 06:20 AM   #6
bobs409
bobs409's Avatar
Thanks guys. I had no idea it might be rare/valuable. Saw it just sitting on the seat of that truck in a junkyard and brought it home.
Bob
Old 06-09-2012, 01:40 PM   #7
David67
David67's Avatar
Mine's no 4x4!
1967 C10
IG: david_r67
Old 06-11-2012, 09:26 AM   #8
camrycurt
camrycurt's Avatar
Originally Posted by David67 View Post
Mine's no 4x4!
The shifters are interchangable so they tend to get mixed up as owners swap transmissions, trucks, etc.
My C10 came with a single bend shifter and I swapped it back out for the "correct" double bend version. Just like most things on these trucks, it's all about personal preference and making what you have on hand work.
Curt
Old 06-11-2012, 01:29 PM   #9
David67
David67's Avatar
Interesting.. I'm very sure my truck came with the sm420. The SPID says 4-speed (could be 465 I guess?), but it didn't appear that my shifter or transmission had ever been swapped.
odog says it looks like the shifter on his sm420.
Can anyone else help out?
1967 C10
IG: david_r67
Old 06-13-2012, 01:24 PM   #10
MJN
MJN's Avatar
How many PTO covers does your transmission have? The SM465 should have two, the SM420 would only have one. Also, reverse on the SM420 is to the left and down where the SM465 reverse is to the right and down.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 06-13-2012, 02:07 PM   #11
Ozark Tim
Ozark Tim's Avatar
On 6's and 4wd's the trans is mounted further rearward in the chassis. I think all 6's and 4wd's came with the single bend shift lever because of no need to clear the dash panel. Not sure about vaiations between 465 and 420's.
Ozark Tim is offline   Reply With Quote
Old 06-13-2012, 03:48 PM   #12
David67
David67's Avatar
Mine has 1 PTO cover and my pattern's left and down. I just meant that the SPID, from what I can tell, doesn't specify between the two. Mine did originally have the 292 L6 so that might make more sense to have the 420 and single bend shifter from the factory on a 2wd 1/2 ton truck. And I didn't think this was that uncommon... I did love how the bell housing from '67 fit perfectly with my '93 350 block!
1967 C10
IG: david_r67
Old 06-13-2012, 05:07 PM   #13
Bob B.
New Process 435's have a shift lever with only one bend. The 435's were only used in 4X2's, and reverse is to the right and down.
1967 GMC CM-2500 Camper Cruiser, 351E V-6, NP 435 4 speed, Dana 60, and factory A/C. 2012 GMC K-3500 WT regular cab, 6.0L Vortec, 6L90.
Bob B. is offline   Reply With Quote
Old 06-13-2012, 10:24 PM   #14
odog
odog's Avatar
My 420 is behind a factory 327, reverse is to the left and down, it messes with my wife whenver she gets in it.
1969 4x4
