06-09-2012, 01:04 PM | #1 |
Fuel tank install ????
I was so pumped this morning as I was finally going to put the bed on my truck, only to be quickly let deflated. I bought this truck with what I believe was a Blazer tank already installed, but with no truck bed. I am now attempting to install the bed and the rear most bed rail is hitting the tank. I know that the Blazer tank install is a very common upgrade, but I have searched and can't find where anyone else has had a problem with the bed hitting the tank.
Am I missing something? Is there some modification that people are making to the bed for the tank to fit? Any help with this problem would be great.
70 SWB 454/TH400 |
06-09-2012, 06:03 PM | #2 |
Re: Fuel tank install ????
you have to cut the cross rail. no getting around it that i know of
1967custom |
06-09-2012, 06:07 PM | #3 |
i cut the cross rail. too. Its easy to do.
ORTEGAMOTOR |
06-09-2012, 06:13 PM | #4 |
Newbee
Like this,
06-09-2012, 07:31 PM | #5 |
Either notch the rail like above, or lower the tank a little, just make sure its not to low that it will bottom out. When I did my blazer tank I didn't notch the rail and my tank didn't hang down all that low, but my truck was stock height and I didn't take it offroad or anywhere I would worry about bottoming out.
"A true hotrodder wouldn't be content untill he had created a car so violent, so hairy, so totally sick that the very act of dropping the hammer would result in instant death. Anything less results in the need to go faster." - Tony DeFeo |
06-09-2012, 08:22 PM | #6 |
If you have a blazer tank with the outlet on the side you will have to notch the rail. If it is a top outlet you can lower the tank. I did mine in like 15 minutes with a sawall. Not hard at all.
1972 Custom Deluxe LT1 Gen V Swap "Green Lantern" 1984 Silverado Red Baron-72 c10 Project |
