Old 06-09-2012, 08:14 PM   #1
kwin
kwin's Avatar
4l60e questions
I have a 6.0 , motor mount adapters, fuel filter, fuel pump etc... I want to run a 4l60e and I have the opportunity to buy one from a 1996 gmc 1/2 ton.
Its behind a 5.7 vortec, are there any concerns , it has a performance rebuild and the truck.
Will it bolt up? any problems that I should know about before i purchase it?
Thanks of your time.
Keith
kwin is offline   Reply With Quote
Old 06-09-2012, 09:21 PM   #2
72gmcshorty
72gmcshorty's Avatar
Re: 4l60e questions
what year 6.0? i have been told that the EASIEST option is to find one from the same year..
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 06-09-2012, 09:27 PM   #3
kwin
kwin's Avatar
Re: 4l60e questions
Its a 2002 6.0, 2wd 4l60e's here are incredibaly hard to find.
99% of trucks up here are 4x4.
I've been looking for 3 months & this is only
The second chance I've had to buy.
Keith
Old 06-10-2012, 01:02 AM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 4l60e questions
The external plug is wired completely differently. You might be able to rewire and make it work, but the early trans is generally avoided due to not being plug and play.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 06-10-2012, 12:23 PM   #5
Dustytrix
Re: 4l60e questions
Check and see how many pins it has in the round connector make sure its 13. it will work with the flexplate adapter. I am using a 97 4l60e. It will bolt up minus one bolt. The original would work better but sometimes we have to use what we got.
Dustytrix is offline   Reply With Quote
Old 06-18-2012, 10:36 PM   #6
kwin
kwin's Avatar
Re: 4l60e questions
Well put!
Old 06-20-2012, 12:36 PM   #7
kwin
kwin's Avatar
Re: 4l60e questions
I'm told it has the longer bell housing so I will have to use a spacer. But they say the converter is supported better that way and that this set up lasts longer.
Either way I'm gonna buy it.
Keith
Old 06-20-2012, 01:59 PM   #8
gringoloco
A guy with a truck
gringoloco's Avatar
Re: 4l60e questions
The 6.0 already has the appropriate spacer/flywheel, so your spacing is good. The main concern is the electronics and if your PCM can control it...
-Chris
