Old 09-28-2003, 08:19 PM   #1
DC Thomas
handling
I am about to put sway bars on the front of my 69C-10swb . Wil I see a big improvement in handling? Will it be better with rear as well? And lastly, will lowering it 2 inches all around help the handling even more?
Thanks in advance DC
DC Thomas is offline   Reply With Quote
Old 09-28-2003, 11:54 PM   #2
PR454SS
PR454SS's Avatar
Thumbs up
Front swaw bar will definitely help in the handling dept. I just put one on my 72SB and was pleasantly surprised.
Also lowering it 2 inches lowers the center of gravity, this will also give some improvement, depending greatly on the aspect ratio of your tires.
PR Too many projects, not enough time!
72SWB 350/350TH, 3500stall,525 lift cam 3:73 posi. Sold!
69LWB Flatbed 350/Super T-10, ported/polished 481 heads, 480 lift cam.
78SWB 468/400TH, ported/polished Alum. heads, 3:42 posi, 3000 stall on 17x8 and 18x9.5's
77 Jeep CJ-5 304V8 fiberglass body on 36" Ground Hawgs
PR454SS is offline   Reply With Quote
Old 09-29-2003, 02:25 AM   #3
Injected68LS1
Injected68LS1's Avatar
You will see a big improvement over having no swaybar at all. When I added a front swaybar to mine I was pleasantly surprised but still wasn't happy enough. I added a rear swaybar to mine and it was incredible. My truck was very stable through corners. The following rules apply when using swaybars.
By adding a front swaybar or increasing diameter, you will increase your understeer, which will make your truck less likely to spin out and make it more likely to push.
By adding a rear swaybar or increasing diameter, you will increase your oversteer, which will make you more likely to spin out and less likely to push.
So by adding both you can balance your truck better. You can also use the previous rules for sizing of your sway bars.
And lowering your vehicle will always make it handle better provided it was done properly.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 09-30-2003, 10:56 PM   #4
C-10volvo
C-10volvo's Avatar
wow thats great... im gonna install a 1 1/8 swaybar from hellwig tomorrow on the rear. as it is now the tail is all over the place. uhh maybe i sould order that front one right away
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
