06-02-2012, 04:40 PM | #801 |
Re: What Did You Do With Your Truck Today ?
That's what I like to see, a great classic truck being used as a truck. My hat is off to you.
06-02-2012, 09:29 PM | #802 |
Scored a motor for my drill press at an estate sale for $10. No cheep China poo, this one is from the 60's, made in USA and never used. The guy said his dad had it around as a spare. Perfect fit and runs like champ. I have some things I have been holding off fabbing until I got it running again. Now why can't I find those hub caps I want for that price???
06-02-2012, 10:14 PM | #803 |
06-02-2012, 10:41 PM | #804 |
Install new tires!!!
Posted via Mobile Device |
06-03-2012, 07:29 AM | #805 |
Actually it was a few days ago, but I got my truck inspected - good for another year!! I'll bet when those guys on the assembly line put in the windshield, they never dreamed it would one day have a '2013' sticker on it! I'm driving it to work tomorrow to pick up a shelving unit they're throwing out.
06-07-2012, 02:17 PM | #806 |
Spent the last few evenings welding up the stake pockets & all of those annoying extra holes in the bed!
Robert C. 1950 3600 3600 re-do, shortening it up If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. |
06-07-2012, 03:29 PM | #807 |
Ain't that so cool to think about!?! People didn't buy trucks for pleasure back in the day - they were for work. Easy to imagine them pulling stumps, hauling wood, etc. Makes you feel good to know that your preserving something that has such a long 'storied' history - even if most of it is unknown to us.
06-07-2012, 06:17 PM | #808 |
Bought paint for the steering wheel. Should have researched the paint cost, could have gotten a finished one on Ebay for less. But I have other ideas for the interior to accent the wheel and I can use the epoxy primer on my bed rails.
06-07-2012, 08:01 PM | #809 |
Sold my daily driver yesterday and now driving the 59 until I find a suitable replacement daily driver. First time really hitting the streets since it passed inspection. There are some glitches! Forgot to put a jumper on my alternator from + post to the #2 terminal and boiled my battery! whoops, hopefully it's ok. Developed a leak in heater hose. Fixed both on my lunch break! Here is a before pic and a couple from a few weeks ago after I color matched spray bombed my body repairs
1959 Chev Apache 3100 Short Fleet Big Window |
06-07-2012, 10:19 PM | #810 | |
06-08-2012, 12:08 PM | #811 | |
06-09-2012, 08:58 PM | #812 |
Inventoried part in my bins, and tore apart the stock wiring harness to see what I need to, or can, salvage. That wire is really brittle, found lots or exposed wire, I do not know how it did not burn to the ground.
06-09-2012, 09:11 PM | #813 |
Re-assembled and installed new lower bearing and turn signal swtch assembly, and primed my Van Tilt Coulmn that I recently chopped. see my build, just waiting for no wind to paint it , see my build for pic's
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
06-09-2012, 10:08 PM | #814 |
painted the hood with sealer and going to paint it in the morning.
06-10-2012, 10:18 AM | #815 | |
Love the fleetsides! |
06-10-2012, 12:07 PM | #816 |
I used Blitz Black (many pros and cons depending on the search you do and the forum you search on). A $9 Harbor Freight gun and a rather small compressor. This is a father and 13 year old son build so we are doing everything ourselves with what we have, which is making some really good times. The wheels are Wheel vintiques Chrome Smoothies 15x8's, and Coker 235/75/15's. The tires were close to the most expensive single item purchased so far other than the truck itself. We did find out that the engine block had cracks on both sides and was "repaired" using JB Weld by someone. We have since located another block and are gathering parts as we speak for an overhaul. Did I say good-times...The goal is to drive it to the Redneck Rumble in September. Lots to do!!!
06-10-2012, 02:01 PM | #817 |
I used some money I got from scrapping to buy a sawz all and an angle grinder yesterday. Today I got to work. Cut off the S10 body mounts and ground them down as best I could, pulled my doors and am about to start working on the cab...hear those are a bit heavy.
06-10-2012, 10:22 PM | #818 |
For anyone that is thinking using the existing 53 (or older) harness is a good idea take a look. This is one example of what I found, all it needed to do was short to the firewall and bad things would have happened. I found similar problems on the front lighting harnes, rear harness and under the dash. In 80 when I added a fuse panel I checked all the wiring and decided it was OK, guess 30+ more years takes it toll.
06-10-2012, 10:39 PM | #819 | |
Looks like the hot red 10 gauge wire to ignition, must have changed over from generator to alternator that put out more amps and heated the wire!
06-11-2012, 01:05 PM | #820 |
Nope, I was running the stock generator until I took it apart. You are right it is the harness that goes down to the solenoid.
06-11-2012, 07:41 PM | #821 |
If you are going to replace only the wire put an inline fuse rated for the output of the generator so that fuse blows before the wire heats up. If it pop's (burns fuse) than generator or regulator is faulty causing wire to heat up due to increase current flow.
06-11-2012, 09:37 PM | #822 |
Painted my Tilt Coulmn yesterday no wind and no runs! Also I have been asked why I welded the home made support at bottom, two reasons from the outside looks real nice, and inside carpet will go around bottom won't be seen. I found a two piece chrome thing that used for closet or sinks can't remember which at Home Depot that will fit at bottom of column still debating if I will use it but fits the coulmn perfectly!
06-11-2012, 09:42 PM | #823 |
looked at it. there was too much wind to weld.
06-11-2012, 10:00 PM | #824 |
I weld indoors and paint outside, I think I got the two mixed up.
06-11-2012, 10:56 PM | #825 |
Thanks for the input, I am putting in an EZ wire set up, just looking to see if any of the original connectors are usable, but even about half of them are cracked.
