shortening steering column
I am going to shorten my column by 3 inches.
The problem is it was a 3 speed and now it's a 5 speed so I don't need any of the linkage. I need to know if I can just remove all of the steering linkage and the tube and not have an issue from doing so when I reassemble. Also, does anyone make a replacement collar so I don't have the shift lever hole anymore? Or, should I just weld up the whole after cutting off the mounting point. Thanks, Steven
“Life is and will ever remain an equation incapable of solution, but it contains certain known factors.” - Nikola Tesla Matt. 6:27 "Who of you by worrying can add a single hour to his life?” http://www.67-72chevytrucks.com/vboa...=507266&page=2 |
Re: shortening steering column
You can remove all of the linkage, you`ll have to disassemble the column, shorten both the inner tube and the outer tube same length, re-weld the tubes and weld the outer to the inner just to keep them from rattling, don`t ruin the plastic collar at the bottom and reuse, the bell portion of the column nobody makes you`ll have to grind off and I believe it is pot metal which you can`t weld you`ll have to figure out another way to refinish. Ididit years ago use to sell bell covers for this application but no longer does.
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
Thanks for the input!
I will proceed soon and take pics. Steven
if you can find a truck or column from a truck that had a 4-speed floor shift, the column will have a plain bell, no shifter or linkage, I think.
I shortened my 4 speed column a while back, those are pretty simple to do. You can find the smooth bells on ebay fairly often.
These links show where I cut mine. Outer sleeve: http://67-72chevytrucks.com/vboard/s...&postcount=200 Steering shaft: http://67-72chevytrucks.com/vboard/s...&postcount=203
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
I took inspiration from your thread, actually.
![]() So it's called a bell. In all the years I worked on these trucks, I thought it was called a collar. Learn something new every day. Thanks! Steven
![]() Join Date: Feb 2003
gread thread... this will also work on an automatic?
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
