Hood & fender emblems
Havent seen a thread on emblems yet, so I figured I start one. What I want to do is identify all the different emblems from 60-66...hood, fender, glove box. I have 63 OEM and repop emblems that Ill post tomorrow, and if you have emblems that you can help post, please add them. This thread should help some people that are looking for emblems and the differences in OEM and repoped. I have noticed slight variations in the repop/OEM emblems.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-12-2012 at 08:29 AM. |
Re: Hood & fender emblems
Ill start with the 60 & 61 hood emblems. The 1st picture with all three (starting from the top) are GM part # 3768897 V8 big truck (has three studs), #3763798 V8 light duty truck (has two studs), and #3767009 is the I6 emblem. These are all OEM emblems and and not reproduced as of yet. The second picture shows the difference in size of the big truck/light duty V8 emblem. The 3rd pic is the light duty V8 emblem. The 4th picture is the I6 emblem. The 5th picture is the big truck V8 emblem.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-12-2012 at 10:14 AM. |
1960 Glove box script. GM part # 3743688. Not being reproduced. The same emblem was also used on the 1958 Chevy Del Ray Glove box.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
i always thought the V8 emblem only came on the custom cab, not the base model?
1961 chevy K10 my build is------------61K10 build |
Im not sure of the application of the emblems...if they had to be custom cab or not. Thats some of the stuff I was hoping that this thread could help on. I have seen standard cabs and custom cabs with them, but not sure if factory, dealer or owner installed. I just know the difference in the big/light duty truck and the trucks with 6cyl engines.
1964 Chevy c10. Goes on fenders
1965 Chevy c10. Goes on cowl extensions
'66 chevy lwb c10 '65 chevy lwb c20 |
1961 crewcab
as far as I know all the 60-61 v8's had the v custom or not.
correct me if I am wrong, but was the large "V" for the tilt cabs only , and the short "V" for the c/10-80? looks like the tilt cabs used the V up until at least 66...
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 06-13-2012 at 01:15 AM. |
1961 crewcab
some of us will probably never see these emblems: a 64 (62?)-66 toroflow diesel gmc emblem-the 3rd and 4th pics show a 66-, and the 60-61 V-12 emblem (I don't know if the V-12 emblem changed in 62 like the light trucks-although this pic shows 63?)
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
1961 crewcab
60-65 GMC big truck emblem, and then the 66
60-61 v6 emblem, then 62-66 v6 GMC. all GMC emblems were available in either chrome or white depending on the trim package.
1961 crewcab
61 only apache,spartan and viking emblems were mounted on the side of the hood.
10-40 series were denoted on the hood with the apache emblem, 50-80 series used an emblem in the grille
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 06-13-2012 at 02:07 AM. |
1961 crewcab
gmc grille emblems 60-65 , and then 66 with the block letters, again available in either chrome or white
1961 crewcab
GMC used these same letters on thier lcf/snub nose truck (I could not find a pic of a 66-square letters on a lcf..), on the hood, and on thier coe, bolted to a square panel in the grille shell.
the also used the square 66 letters in thier 7000-8000 series (this truck might have replaced the lcf/snub nose truck that was available 60-65)
Wow...the turbo flow diesel is a new one to me. Haven't seen these emblems before. Keep them coming
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-13-2012 at 01:50 PM. |
Heres some OEM 1963 c-20 fender emblems. GM Part # 3818128. These are not being reproduced. To the best of my knowledge, only the 63 c-10 emblems are being reproduced. I will post those pics tomorrow to show the difference in the repops/OEMS
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-13-2012 at 09:48 AM. |
#15 |
Here are some 1964 c-80 fender emblems. GM part # 3838746
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 11-05-2012 at 05:52 PM. |
#16 |
1960 Apache 10 hood emblem. GM Part # 3766879
#17 |
1962 c-60 fender emblems. Go on the hood extensions.#379625
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 07-20-2012 at 04:49 PM. |
#18 |
Reproduction 1961 Apache 10 emblem on left...OEM on right. Best pic I could find....maybe one of the guys with a 61 can help with a better pic of a 61 emblem.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 06-13-2012 at 10:10 AM. |
#19 |
1962 c-10 emblems. Repop on the left, OEM on the right. There are some small differences in the bowtie in the repops
#20 |
1966 c-10 fender emblems. The two top pics are OEM and the pic on the bottom is a repop.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer Last edited by 1963c-10; 10-01-2013 at 11:42 AM. |
#21 |
Glove box emblem for 64-66. Repop on left, OEM on right
#22 |
1962 c-20 emblems OEM
#23 |
I believe this is a 1960 Chevy Viking emblem
#25 |
Here are the 63 c-10 emblems. The OEM parts are #381827 and are pictured 1st. The 3rd pic is the repops. There are several differences in the two that are hard to tell from the pics, but the top part has a slight taper on the OEM emblems & there are some minor differences in the bowtie.
