06-12-2012, 02:02 PM | #1 |
NEED ADVICE, Should I buy this TRUCK/ RUST. GOOD DEAL OR BAD?? THANKS
Hello Everyone,
Im new to this forum but the information throughout forum is great so I decided to post a question. I have been looking for a C10 project for some time and I came across this truck below. It is a 1972 c20 lwb and the guy wants 3k for it. I went and looked at the truck and of course was excited however it had rust in several places and I don't know much about body work as I have never restored an older metal body vehical. There is rust throughout the drip line, on the inside of the cab the roof is not rusted but it is very rough to the touch and seems it may be rusted under the paint, the door jams have rust in them, the rocker panels as well. The body seemed straight with a good hood but Im just not sure if the $ is too high with all this cab rust...ooooorrrr does it not look too bad to you all with EXPERIENCE restoring vehicles. I could drive truck as is but I just dont want to wrap up 4,5,6k in body work plus my initial 3k investment. ANY THOUGHTS? GOOD DEAL OR BAD? |
06-12-2012, 02:05 PM | #2 |
Re: NEED ADVICE, Should I buy this TRUCK/ RUST. GOOD DEAL OR BAD?? THANKS
There are much better choices in the Atlanta area for $3K, just my honest opinion....
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
06-12-2012, 02:08 PM | #3 |
Thank you for that advise, Im am new to this and just don't want to get in way over my head.
06-12-2012, 02:10 PM | #4 |
Yeah. I'd keep looking.
Doug Looking for a 67-72 short bed driver..... |
06-12-2012, 02:13 PM | #5 |
There's a ton of great trucks out there, if I were you I would avoid this truck and keep searching because that doesn't look like factory paint and who knows whats underneath it. Someone could have done a half-ass restoration like I found on my truck, I've been finding pounds and pounds of body filler on my truck. Good deals are easy to find you just have to keep looking via Craigslist, KSL, Newspaper, Ebay... etc
Calder |
06-12-2012, 02:15 PM | #6 |
Ok great, I think I will end up passing on this truck. I trust you guys that have experience and I think your correct about a prior half assed restoration. I ll keep looking and Im sure Ill eventually find something clean. Thanks for all the quick responses!!
06-12-2012, 03:13 PM | #7 |
I would continue looking..I bought mine without knowing much about these trucks except that I wanted one and paid for it. I was looking for a 67 to go along with my 67 Firebird and find out that it was really a mix of 67/70 parts put together. There are common rust spots to look at such as rear cab corners/rockers. Make sure that you try to lift of the carpet to get a inspection and don't be afraid to look under the cab too. I would make sure that before you buy it do a little research on the spec sheet which is located on the glove box door. Capture that information and come back here and do a search. This way you can know if everything is original or not with the truck.
True |
06-12-2012, 03:30 PM | #9 |
[QUOTE=realsales87;5430820]It is a 1972 c20 lwb and the guy wants 3k for it. I went and looked at the truck and of course was excited however it had rust in several places and I don't know much about body work as I have never restored an older metal body vehical. There is rust throughout the drip line, on the inside of the cab the roof is not rusted but it is very rough to the touch and seems it may be rusted under the paint, the door jams have rust in them, the rocker panels as well. /QUOTE]
PASS!! Keep looking. You gained very valuable knowledge with this one, now take that and keep looking. Never, EVER jump on the first thing (unless it's a complete frame off). Everyone is right, there's better out there for 3K. Good luck.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
06-12-2012, 03:30 PM | #10 |
You did the right thing to ask.
IMO the rust was not that bad, but the location the rust was in makes it very bad. Rust in the lower areas is a lot easier to pick up $20 patches that could be slapped on to replace. The higher you go, the more likely that the rust is deep and structural, not to mention harder to get to
In my opinion, it works best to have the seat out so you have room to flop your body around while standing on your head. -ashx2 |
06-12-2012, 04:33 PM | #11 |
another vote for PASS on it.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
06-12-2012, 05:01 PM | #12 |
Junior Member
pass
71 Suburban 350/700R4 Project Trixie 72 CHEVY,Highlander,SWB,396,T400 |
06-12-2012, 05:37 PM | #13 |
run!!!!!!
Posted via Mobile Device |
06-12-2012, 08:41 PM | #14 |
Awesome responses everyone. I wasnt sure if I did the right thing but I knew some of that rust looked complicated and way over my head. I appreciate all the Craigslist posts HartRod. Yeah I don't have the budget at the moment for a full restoration. I was kindof looking to buy a solid truck to mess around with, I probably wouldnt want to invest more than 10k total including the purchase of the truck...and then tinker with it throughout the years. I will keep looking and I am really glad I asked everyone. I WILL BE PASSING, THANKS!
06-12-2012, 08:59 PM | #15 |
unless you enjoy headaches and body work, concur - pass. Main reason in my book is all the rust in the pillars, drip rail, roof area. nightmare.
06-12-2012, 09:17 PM | #16 |
that roof line is reaaaaaaal bad. trust me, ive dealt with a truck like that, looked almost the same.
-Mike- '94 GMT 400 ext z71 3" body, 3 in rough country, hd mirrors, 20" motometals on 35s |
06-12-2012, 10:17 PM | #17 |
run like hell!I am in covington just east of atlanta and have no problem helping you find a better deal
06-12-2012, 10:27 PM | #18 |
Cruzin
i agree with the others pass, here in the south these trucks aren't to hard to find
Lime Wife's 67https://www.google.com/url?sa=t&rct=...wZEMODaS2d94u8 Back to the Fifties 59 https://www.google.com/url?sa=t&rct=...NAeStpydfrcj_U Proverbs 3:5,6 "Thanks to the Interstate Highway System, it is now possible to travel across the country from coast to coast without seeing anything."Charles Kuralt In memory of our first baby daughter, daddy and mommy love you. Danica Grace 6/26/14
06-12-2012, 10:58 PM | #19 | |
VA72C10
If you're considering a swb also they will be a little more pricey...but you can still find deals... I'm working on one I'm selling for 12,750...it will be full frame off restored swb with new paint...so there are deals out there to be had
Looking for a 67-72 swb or blazer project in or around VA. |
06-13-2012, 12:40 AM | #20 |
You should start looking in Arizona and California for a nice rust free truck. You may find one in your price range- or less and buy a plane ticket out and drive it back!
06-13-2012, 09:44 AM | #21 |
run!!!!!!!!!!!! but take the bed with you....
ORTEGAMOTOR |
06-13-2012, 11:23 AM | #22 | |
Old Skool Club
Pass it up.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
06-13-2012, 11:34 AM | #23 |
That's too much rust in the wrong place for that price. You would end up cutting the whole roof off and replacing it before you were done.
For a project truck I'd rather hunt a really nice body with worn out original paint and not care much what shape the engine was in. Old faded out original paint doesn't hide a lot of sins or past damage and most guys are going to go through or replace the engine anyhow and I'd much rather have an engine that I knew what was inside and how it was assembled. I'm also gunshy of trucks or cars with fresh primer on them. Especially ones that are hauled to swap meets still smelling of the primer. Are they hiding something or trying to bump up the price because of it? Also don't pay extra for things that you plan to change right off the bat. If a truck has fancy wheels and tires that you don't like ask the seller if he/she will knock the price of the wheels and tires off the price if they keep them. |
06-13-2012, 12:01 PM | #24 | |
Happy to be here
As your looking keep in mind that paint, body , and rust repairs are going to be the most costly. If you can find a truck with original paint that has minimal rust your much further ahead than having to repair and repaint one.
06-13-2012, 12:10 PM | #25 |
Florida Edition
and welcome from Central Florida....glad you passed, keep us posted.
70 GMC Short Stepside "Rose"-An American Beauty: Factory 402/TH400, AM/FM, AC, Tilt, Tach, Buckets, Posi, PS, PB, 3-5 Drop, Complete Resto-Rod 67 C-20 Slant Back Wrecker "Mad Max" 67 C-10 Ratrod "Step-N-Wolf" 71 Serro Scotty Sportsman camper "Scotty" 97 LT1 Z28 "The Hornet" Link to more pics of "Rose" http://67-72chevytrucks.com/vboard/a...p?albumid=1684 Check out my "Cheap Tricks" thread and add to it if you can, lots of good info there. http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
