Old 09-29-2003, 05:26 AM   #1
TIMSPEED
TIMSPEED's Avatar
Gas Guge Question: Needle Bouncy; Bad Ground?
I think my Gas Gauge problem may lye in a bad ground connection. Tonight, I was driving around on a PERFECTLY smooth road, yet the needle was still bouncing. Also, when I was stopped at a red light, it was still bouncing. So, what wire should I check for continuity or what?
IIRC, the guage used in our trucks has only one wire going to the tank, and it's a ground wire, because the sensor in the tank is basically a resistor, when the tank is full, it reads 0ohm, when the tank is empty it reads 90ohm, right?
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 09-29-2003, 02:46 PM   #2
loweredd
www.loweredd.com
loweredd's Avatar
I was wondering the same thing. Mine goes all over the place. I never know how much gas I hav for sure. It doesnt really bounce, just goes all over the dial.
loweredd is offline   Reply With Quote
Old 09-29-2003, 03:51 PM   #3
79Chevypickup
MY TRUCK IS FOR SALE!!
79Chevypickup's Avatar
Lightbulb Me Too Me Too!!
Mine does the same thing...
I just look at what I think is about the middle of
the bouncing and assume thats how much gas I
have.
I accutally started to think it was normal...
Is it?
1979 Chevy LWB
350ci / 700R4
Edelbrock under the hood
F O R S A L E OR T R A D E
79Chevypickup is offline   Reply With Quote
Old 09-29-2003, 05:38 PM   #4
Prerunner1982
Prerunner1982's Avatar
depends on what you mean by bouncy? every old chevy truck i have seen the needle will move when you accelerate or brake, But if it bounces on a straight smooth road at a constant speed then it may be a wiring or sending unit problem. The connection the float makes with the unit, not sure what it is called the part that controls the ohm that is sent to the guage.. you know what i am talking about?
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 09-29-2003, 05:49 PM   #5
79Chevypickup
So what you are saying is, is that it could be the sending unit for the gas gauge (the one on top of the gas tank)
or
It could also be bad wiring
or
A combination of the both
This is what you are saying right?
1979 Chevy LWB
350ci / 700R4
Old 09-29-2003, 05:59 PM   #6
79BIG10
I'm back with 2nd truck!
79BIG10's Avatar
First check your ground. Then if that's good it's your float inside the tank. It's probably moving alot and thus giving the bouncy reading to the gauge itself.
1979 Chevrolet Bonanza Big10 "Tootsie Roll"
1985 Chevrolet Silverado (wife's)
Member of the Southern Bowties Club
"Don't underestimate how sexy a fat man who drinks to excess can be." Homer Simpson
79BIG10 is offline   Reply With Quote
Old 09-29-2003, 06:47 PM   #7
Prerunner1982
mine "bounces" but only under acceleration and braking. As far as i know from what has been discussed on here that is fairly normal.
Jon
Oklahoma Roll Call
Old 09-29-2003, 08:25 PM   #8
1FaastC10
1FaastC10's Avatar
of the 30+ GM trucks ('49-'97)i have had experience with (most of which belonged to family/friends) ALL had a "bouncy" gas guage. the only exceptions i've found are the 99+ trucks. if my assumptions are correct, they have a baffled fuel tank.
1FaastC10 is offline   Reply With Quote
Old 09-29-2003, 08:39 PM   #9
loweredd
www.loweredd.com
loweredd's Avatar
oh yeah, that could be the case. Probably just replacing the sending unit isn't going to do it.
We'll see when I put in a foamed fuel cell.
