Old 06-13-2012, 11:17 AM   #1
dbruhn
73-87 high rise transmission tunnel
Where can I locate a high rise transmission tunnel for a 1978 cab. I am converting a 2wd 3 on the tree to a 4wd 4-speed.
dbruhn is offline   Reply With Quote
Old 06-13-2012, 12:06 PM   #2
notyo_cheez
Cool Re: 73-87 high rise transmission tunnel
I'll trade cabs with you. Logistics might be difficult, though. Mine came from a 83-87 that has the 4wd hump with the embossed area for the 4-speed shift and cutout for the transfer case shifter.
notyo_cheez is offline   Reply With Quote
Old 06-14-2012, 02:25 PM   #3
beamn7
What are you going to do with the, linkage, shifter and trans? Might be interested........ (I assume you will be leaving the column in....)
beamn7 is offline   Reply With Quote
Old 06-14-2012, 03:16 PM   #4
cory d
cory d's Avatar
look in jubk yards or on craigslist for people parting trucks out. theres plenty out there
cory d is offline   Reply With Quote
Old 06-14-2012, 03:22 PM   #5
dbruhn
I have the column for the 4WD to swap out with the column shifter. Everything is good except for tunnel. Any idea how much of a lift would be required if I leave the low rise tunnel in it?
Old 06-14-2012, 10:32 PM   #6
88Jimmy4x4
88Jimmy4x4's Avatar
just add a body lift, 3" max
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 06-15-2012, 07:05 AM   #7
xrcr
I have one that I'd sell
xrcr is offline   Reply With Quote
Old 06-15-2012, 01:25 PM   #8
dbruhn
A tunnel or a lift kit?
Old 06-15-2012, 03:48 PM   #9
xrcr
Tunnel. It's out of a 76 3/4 2wd 4spd
Old 06-18-2012, 08:46 AM   #10
dbruhn
Will that tunnel work for the 4wd/4sp conversion? I actually have the ability to get one from a standard shift 3/4 ton truck.
Old 06-19-2012, 08:10 AM   #11
dbruhn
If I can use a tunnel out of a 2wd 3/4 ton standard shift truck then I am set. Let me know if this will work.
Old 06-19-2012, 02:02 PM   #12
xrcr
I'm not sure, I don't know where 4wd shifter comes through in relationship to the tunnel.
Old 08-13-2015, 02:30 AM   #13
Stocktongoodrepair
Im looking for a High Hump Transmission Cover for 73-87 Chevy GMC truck 2wd
Ebay just sold one minutes before I logged on ... Or some place to buy one.
Last edited by Stocktongoodrepair; 08-13-2015 at 02:40 AM. Reason: It looked terrible
Stocktongoodrepair is offline   Reply With Quote
