Old 06-15-2012, 12:26 AM   #1
peglegs
peglegs's Avatar
what wrong with this 12 bolt ?
looked @ a 12 bolt 3:73 posi from a 77 1/2 t 4x4 yesterday with new richmond ring & pinion but on the left of the ring gear & right of the posi were round shims? very loose different thickness' & one actually came out broken i passed on it not knowing what was going on here anyone explain this i would like it for the $200 with springs,16" white spokes & 1 excellent tire but dont have the expeience to work the internals thanks
1990 chevy 4x4 with a 1940 IHC body
peglegs is offline   Reply With Quote
Old 06-15-2012, 02:43 AM   #2
andrewmp6
Re: what wrong with this 12 bolt ?
A diff has to to be shimed in for it to work prefectly,Its not hard to build one if you know what your doing.If you have time you can read this http://www.pirate4x4.com/tech/billavista/Gear_Setup/
Old 06-15-2012, 08:07 AM   #3
OLDCHEV4X4
OLDCHEV4X4's Avatar
Sounds like they didn't get the bearing preload tight enough and it kicked a shim out/broke. If it wasnt driven too long that way, everything should be ok. I have come across this before and i reset-up the ring and pinion and everything was fine. Its still driving with no failure.
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
