Old 06-16-2012, 08:32 PM   #1
Alford
Hiw does the added weight of a Big Block affect ride height?
Title says it all. I have a 454, 700r4, 2.5" drop spindles, 3"' front drop springs, 185/70/15 front tires. My control arms drag on everything. No match for the bumps on the yellow lines. I can raise it another half inch by going to 215/75/15s but I'm thinking the big block is too much for the 3" drop coils. Other guys with 5.5" drops and small blocks seem to have I problems. Any thoughts? Anybody else out there with a bbc and a 5.5" drop?
Alford is offline   Reply With Quote
Old 06-17-2012, 12:09 AM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: Hiw does the added weight of a Big Block affect ride height?
Why are your tires so small?
Also.. What bracket did you use to hook up the TV cable for the tranny?\
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-17-2012, 12:13 AM   #3
Captainfab
60-66 Nut
IMO I wouldn't use any more than a 1" spring with 2.5" dropped spindles with a 26-28" tall tire. For me, the big block in my Suburban with stock spindles and springs gave enough drop. Bit then again I'm an old guy that likes to drive without worry of dragging my hard work on the pavement.
Old 06-17-2012, 09:33 AM   #4
66farmer
66farmer's Avatar
I have 2 1/2 drop spindel and 2" spring and a 28"-29' tall tire and the cab is not installed yet. I hope I don't have the problem that you have because I'm old too.
66farmer is offline   Reply With Quote
Old 06-17-2012, 02:00 PM   #5
leddzepp
Moderator
leddzepp's Avatar
I currently have a 5.5 drop, with a BBC. If I am not careful my LCA's hit when I go over speed bumps, etc. I am running 215 70 tires up front. I had a truck with the same setup, with an SBC, and it did the same thing. The difference in the weight was insignificant.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 06-17-2012, 07:59 PM   #6
contagious102
contagious102's Avatar
120-140 pound difference, sbc to bbc.Less if you go with alum. heads vs iron heads.
Go Fast and Have Fun.!!
My pro street build, http://67-72chevytrucks.com/vboard/s...d.php?t=551185
contagious102 is offline   Reply With Quote
