Old 06-18-2012, 04:20 PM   #1
k1rodeoboater
what do you use to secure door weatherstripping?
So what sort of adhesive do I need to go get to install my weatherstripping onto my cab? I saw the 3M stuff at the auto parts store, but I vaguely remembering hearing that it's not that great and that you're better off using this green goop from Ford, or something like that.
1966 C10 Long step build on a budget http://67-72chevytrucks.com/vboard/s...d.php?t=445201
no garage, no shop, limited storage space and tools....no problem.
k1rodeoboater is offline   Reply With Quote
Old 06-19-2012, 08:09 AM   #2
hugger6933
Re: what do you use to secure door weatherstripping?
I have used the 3M Gorilla snot many times and it is good stuff it is a little messy however so you must be prepared for that
hugger6933 is offline   Reply With Quote
Old 06-19-2012, 08:28 AM   #3
late68
late68's Avatar
I use the 3M stuff all the time at work, also used it on my trucks weatherstrip.
1968 C10 SWB Dropped 5 in tha back 3 in tha front
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=470902
late68 is offline   Reply With Quote
Old 06-19-2012, 09:01 AM   #4
RAYDAY
RAYDAY's Avatar
DRYWALL SCREWS and duct tape
96 s10 static drop smooth and blue
99 silverado nothing stock layed out on 24s
65 c10 bagged patina driver
http://www.myrideisme.com/Garage/az480
half-assed build thread
http://67-72chevytrucks.com/vboard/s...=1#post5206828
RAYDAY is offline   Reply With Quote
Old 06-19-2012, 09:21 AM   #5
vin63
It's Better With Nitro
vin63's Avatar
X3...I use the 3M weatherstrip adhesive. Be sure to have some low tack masking tape on hand to help hold the weather stripping in place as the adhesive sets up.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 06-19-2012, 10:25 AM   #6
1963c-10
1963c-10's Avatar
Why would you want to use weatherstrip? You just replaced all the cab metal. Gotta have a little water in her....haha
1964 Short bed trailer
Old 06-19-2012, 01:12 PM   #7
markeb01
Senior Enthusiast
markeb01's Avatar
I've used the 3M gorilla snot, but I prefer the black version they also make. If any of it sneaks out around an edge, there isn't any hideous yellow residue showing. It comes in the same style red box as the yellow stuff so you have to be careful you're buying the right product.
http://3mcollision.com/3m-weatherstr...011-black.html
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
