Old 06-20-2012, 01:29 AM   #51
gferris5
gferris5's Avatar
Re: Junk-Yard Shopping list
Don't forget the Jeep Door-checks!
http://www.persh.org/pickup/DoorChecks.htm
Have mercy, I'm recovering from my 4x4 addiction.
gferris5 is offline   Reply With Quote
Old 06-20-2012, 07:11 AM   #52
E.Furgal
Website blocked by Trend Micro Worry-Free Business Security Services
Malicious website blocked
what was this
E.Furgal is offline   Reply With Quote
Old 06-20-2012, 06:27 PM   #53
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
what was this
It didn't block me.
Maybe it's some software you're running on your computer.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 06-21-2012, 11:13 PM   #54
VWNate1
VWNate1's Avatar
Thumbs up Re: Jeep Door Checks
Originally Posted by LostMy65 View Post
It didn't block me.
Yeah , the first time I clicked on it too got a warning but the next time it opened right up and that's a TERRIFIC site ! THANK YOU .
Now , all I have to do is find a Jeep in my local Pick-A-Part yards .
Maybe I should just go buy a pair , these are just the thing .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline   Reply With Quote
Old 06-22-2012, 12:54 AM   #55
E.Furgal
ok then what does this mean..
Is it safe?
Please type the URL that you want to check.
Is it safe?
Dangerous
The latest tests indicate that this URL contains malicious software or could defraud visitors.
How would you categorize this URL?
Disease Vector
Sites that directly or indirectly facilitate the distribution of malicious software or source code
Give feedback
Learn more about the ratings
Old 06-22-2012, 02:47 AM   #56
gferris5
gferris5's Avatar
Is it safe?
Is it safe?
Dangerous
Disease Vector
Give feedback
hmmm, well, I went there, but I have a mac, so it may be different. Just search on this site instead....
Old 06-22-2012, 10:45 AM   #57
ole dollor
ole dollor's Avatar
i can already see this is going to be some good reading....it is nice to know what will work and what has been tried.....count me in.
ole dollor is offline   Reply With Quote
Old 07-03-2012, 11:55 PM   #58
1955 mancave
1955 mancave's Avatar
alot of great info here so lets keep it going.
1955 mancave is offline   Reply With Quote
Old 07-04-2012, 01:03 AM   #59
jocko
jocko's Avatar
i ALWAYS look for wheels, specifically:
1) 71+ K10 6 lug wheels (60-66 guys buy em like crazy to have stock steelies for their disk brake swaps - hard to find)
2) mid-80's chevy 8 lug 3/4 ton wheels - 16.0" specifically. Due to the rarity of 16.5" tires for the original 16.5" rims on our 72's, so many folks have swapped over to 16" rims for wider tire selectiont that now even the 16" 3/4 ton wheels are scarce. Ford 16" 8 luggers are also a good deal.
Old 07-04-2012, 02:26 AM   #60
gferris5
gferris5's Avatar
*****Updated list pasted below********
1. Front ends to use for disc-brake swaps, years, models, what to snag.
Just go to lolife's thread; best ever...
http://67-72chevytrucks.com/vboard/s...68&postcount=4
2. Suspension
- sway bars from 73 up 2wd and 4wd GM trucks.
-sway bar from 84 chevy dually, mount frame to swaybar brackets (make sure to get these when get sway bar)
3. Steering Parts.
-chevy vans for tilt columns
--'73 through '78 truck and van variable ratio steering boxes (quicker steering)
-6 cylinder p-s from chevy cars/trucks.
-Power steering from 73-8? about $50 (get bracketts, check for worn outness)--out of other trucks
4. Transmissions (this might not be worth it)
-81-87 Chevy half tons and vans with manual tranny,many had the desirable A833/NP440/MY6 overdrive 4 speed tranny
5. Bench seat models and years--if different from the obvious.
-dodge buddy buckets can be easily adapted to our trucks.
-bucket seats from chevy lumina minivan, $40, sit at perfect height just drill some holes
6. Engines
-454 and trans from a '74 Caprice Classic 4-door
7. Cooling, i.e. electric fans.
-mid 80's Taurus electric fans
-Radiator Dimensions are the same as the Aluminum units in '89-'93 Chevy Trucks, not sure if the Flow is the same though.
8. Exterior parts
-GM van side marker lights.
-rear license plate buckets,73-87 trucks,73-91 blazers, will fit our trucks.
-headlight buckets in a 69 Caddy
9. Interior parts
-van AM/FM radios (not identical, but close).
- A-C controls from 65-66 impalas are same as our trucks
-early GM cars with metal e-brake handles that are chrome,screw on type.
-early GM cars with metal,chrome A-C balls same size as our trucks
-speedwarning buzzers from early GM cars can all be made to work on our trucks.
-camaro tachs
-Mid 80's S-10 Blazers for door weather stripping
-Dodge Dakota weather stripping for the doors
-1984 to 2001 Jeep Cherokee door stops--front doors better; back doors open far.
10. Ignition and electrical
-mid 70's 6 cyinder novas and, pull the electronic distrubutor AND external coils
- good bulkhead wiring connector assembly you come across for custom wiring harness
11. Rear Ends
-any chevrolet/GMC dana 44/10 bolt front differential will fit our trucks-60-87 on trucks and up to 91 on blazers and suburbans.
12. Odds-and ends
-72 caddy horns
-If you make a pickup bed trailer out of a 67-72, the 73-78 El Dorado rear straight axles work great.
13. Wheels
-71+ K10 6 lug wheels
-mid-80's chevy 8 lug 3/4 ton wheels - 16.0" specifically.
Old 09-14-2012, 11:12 PM   #61
Tinkermc
Ttt
Tinkermc is offline   Reply With Quote
Old 11-19-2012, 02:02 PM   #62
Smokin'Tires
Smokin'Tires's Avatar
Ttt
'68 Gmc SWB
New 350 mostly stock
Cam and heads coming soon
Smokin'Tires is offline   Reply With Quote
Old 01-13-2013, 04:23 PM   #63
mdazb
mdazb's Avatar
Great Ideas
72 C10 SWB 350 Work in progress
98 HD Fatboy
09 HD Heritage Softail
05 Honda Element
mdazb is offline   Reply With Quote
Old 04-23-2014, 12:44 AM   #64
ChefCy
ChefCy's Avatar
bump
63 big window lwb bagged and shaved
ChefCy is offline   Reply With Quote
Old 04-23-2014, 02:47 AM   #65
frank69
I bought a 69 c20 last week that 15x10 8 hole wheels. This is only the second set I've found in 49 yrs of messin with these old trucks. I don't know if they will clear calipers ondisc brake hubs
frank69 is offline   Reply With Quote
