Old 06-20-2012, 11:18 PM   #1
bilfman
bilfman's Avatar
4l80e/NP205 Swap
I have found the rare 1991 4L80e/NP205 combo and am taking the plunge and putting into my 79 dually 4x4. I have done some research on the net and have found several tips on getting the unit to work. I have wrenched vehicles for many years and have several complete restos under my belt, but this computer controlled tranny is totally new to me.
Has anyone done such a switch, I am just networking to try and have as much information as I can. I see a Throttle position sensor is required and think that I have that setup all locked in the ol brain.
Is a map sensor required? Anything else to watch out/prepare for? Sensor, electrical?
Driveshafts and crossmember are handled, that stuff I have done many times in the past.
Thanx in advance!
1979 Chevy Dually Crew 4X4 454, D60 Tru-trac, D70 Detroit Locker, 3.73, 4L80E/NP205
1971 GMC 3/4 Ton 4X4
bilfman is offline   Reply With Quote
Old 06-21-2012, 01:00 AM   #2
Chevy1TonFun
Grease Monkey
Chevy1TonFun's Avatar
Re: 4l80e/NP205 Swap
You'll need a few wire adaptors. 80e's have electric speedo, shift sensor, and few others I can't remember. Hope someone chimes in to give you more specifics. A map sensor should not be required, that is for the air/fuel mixture.
Tow Rig: 2012 Chevy 2500HD CCSB LTZ Z71 4x4 Duramax
Ultimate Offroad Build: 1978 Chevy Silverado K30 Crewcab Build Link http://67-72chevytrucks.com/vboard/s...d.php?t=654053
Mud Truck: 1972 Chevy Cheyenne K30 4x4, 468/400/205, D60/D70HD, 18" Custom Lift, 17x39" IROKs
FOR SALE http://67-72chevytrucks.com/vboard/c...ton-4x4&cat=12
Chevy1TonFun is offline   Reply With Quote
Old 06-21-2012, 07:46 AM   #3
andrewmp6
I would talk to http://www.transmissioncenter.net/ see what all they say you need for the swap.I know you need a ecu to control the trans and i remember seeing a converter box that had a drive cable to make a cable speedo work with a electric trans but can't remember what its called.
Old 06-24-2012, 09:13 PM   #4
superchevy
Got big-block?
superchevy's Avatar
I swapped a 4L80/NP205 into my '72 K25...see my build thread for info on making it work.
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
Old 06-25-2012, 12:07 AM   #5
bilfman
bilfman's Avatar
Thanx much, tranny and tcase should be in my hands this coming week. Everything helps. Going to your thread now
Old 06-25-2012, 08:42 PM   #6
superchevy
Got big-block?
superchevy's Avatar
A couple of specifics not in my thread. I hooked my mechanical speedometer cable to the speedo output on the NP205. Also, I would highly recommend using the TCI EZ-TCU to control the tranny...it is simple to install, and the handheld allows easy set-up and shift adjustments as well as a default base program so you can't burn up the tranny.
If you are running a carb, you will have to fab up a TPS switch...see my thread for a pic of the one I made.
When I switched from carb to the FAST EZ-EFI, it made everything much easier to hook-up with the built in TPS switch on the throttle body. If it's in your budget, you might consider it.
SC
build thread
build thread
Old 06-25-2012, 08:54 PM   #7
fencepost
fencepost's Avatar
I seen a TPS switch in Jegs and Summitt that bolts to the carb. Holley may make it just do a search.
fencepost is offline   Reply With Quote
Old 07-04-2012, 10:58 AM   #8
54chevytruck
54chevytruck's Avatar
I am almost finished putting a 4l80e np208 in my 54 pickup. I used an Optishift controller. Holley sells a tps sensor that works, unless you have a manual choke, then some cutting and welding is required.
1954 Chevy Truck 4x4
1964 Pontiac GTO
54chevytruck is offline   Reply With Quote
Old 07-05-2012, 11:32 AM   #9
mud slut 350
mud slut 350's Avatar
i have a 91 k3500 3+3 i bought for a parts truck has this combo it. we pulled the 6.2 out last year and if i recall right the eng had a tach and a throttle positioning sensor for the trans. my computer has a big bundle of wires on it not sure where they all go but they are still hooked up. if ya need i can email you pics pm me. idk how to post em on here. i just pulled the t case off mine to use for something else and it had a electronic speedo sensor on it.
82 k10 350sbc, sm465, np205, dana 60 front 14 bolt ff rear 4 inch susp lift 33's aka "MUD SLUT"
2007 cbr 1000rr
mud slut 350 is offline   Reply With Quote
