Old 01-29-2012, 07:02 PM   #276
hgs_notes
GEARHEAD
hgs_notes's Avatar
Re: "Will it Ever Get Done?"
Your rear end ratio will be a factor for deciding whether to go over drive or not. Mine was originally a 3.73 rear with a small v8. I grew tired of nearly 3000 rpm on the highway. I kept the TH350 and changed rear ends to a 3.07 and it's about perfect now. With that V6, if you have a 3.73 or 4.11 rear end you will want the overdrive. If you have a 3.07 now you would probably be happy with it and the TH350. Just my opinion, but it comes from my own experience.
As for the 4.3, it is just slightly smaller displacement than my old 283 and more displacement than the original 250. If it has a good cam it should run great in that truck.
hgs_notes is offline   Reply With Quote
Old 01-29-2012, 07:22 PM   #277
Thanks all.. Hgs, mine has a 3.07 in it now. I am thiniking still about just keeping a T350 because of the simplicity and not having to worry about TV -Cable issues.
Old 02-03-2012, 07:26 PM   #278
Got a little time today and put the accessories on the engine. I am still planning on using the Grand Cherokee electric fan setup with this engine. I got most of the stuff in and the hood back on today. It is nice to clear off the floor again.
Old 02-03-2012, 07:29 PM   #279
VA72C10
VA72C10
VA72C10's Avatar
Nice! Progress!!!
Old 02-03-2012, 07:55 PM   #280
krazy_texan
krazy_texan's Avatar
geez i remember going with you to buy that truck and attempting to drive it back lol we definatly didnt get to far haha.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 02-03-2012, 08:26 PM   #281
This is my original Jacob, not the 69 we attempted to drive back. What is left of the 69 is in pieces throughout the shed and yard But you are soooo right, it didn't get very far.
Old 02-03-2012, 08:35 PM   #282
Alan's Classic
1 thing at a time is progress.
Alan's Classic's Avatar
Very cool progress Bill!!
Alan's Classic is offline   Reply With Quote
Old 02-04-2012, 12:26 AM   #283
70LonghornCST
Moderator
70LonghornCST's Avatar
I'm glad one of us is making progress. Keep it up!
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 05-25-2012, 09:19 PM   #284
Not really progress, but I acquired a long tail (well 9") T350 from a squarebody to put behind the 4.3 With the way things are set up, I think I'll be able to use the original 3 speed drive shaft. Right now I am around 3" too short, so hopefully the difference in the tail shaft will work out.
Old 06-21-2012, 07:00 PM   #285
fakerwade
fakerwade's Avatar
Hey Bill,,,any new progress??? How's your transmission working out???
Wade
JUST WALK AWAY, AND I'LL SPARE YOUR LIVES!!!
Build thread "TANGERINE" http://67-72chevytrucks.com/vboard/s...d.php?t=498570
Board Members Met: bigblock68, ol_skool_chevy ,68TT,atvpro
fakerwade is offline   Reply With Quote
Old 06-22-2012, 02:03 AM   #286
firedog
firedog's Avatar
Seen you are running a v6 which mounts did you use and which location did you mount it in
*SOLD*
1968 Chevy SWB Fleet
350/350 combo
Tach/tilt/buddy buckets
Bagged/18" Wheels
Black on Black
Project "Pandemic" the Farm Rat
1927 Chevy Capitol Truck Rat rod
'30 Model A Frame
Dual Carb 5.3 LS
http://www.67-72chevytrucks.com/vboa...d.php?t=804162
2007 GMC 4 DOOR 2WD
BUILT 5.3 STAGE 3 CAM 93 TUNE
LIFTED 22X12 WHEELS 33" TIRES
2023 Jeep RENEGADE
Wifes ride
firedog is offline   Reply With Quote
Old 06-22-2012, 04:00 PM   #287
No nothing really. I think I got most things caught up around the house and on the 83 that I'll be touching it some thiw weekend...I hope.
Firedog I am using engine stands and mounts from a mid 80s vehicle. When mounted in the V8 mount holes it actually moves a V8 back as if it were in the 6 cylinder stand mounts. With the V6, I moved the front hole back about 3" and drilled a new holes for the stands. It put the V6 about where it would sit right in relation to the firewall. I am using the stands, mounts and engine brackets off a 80s 305 V8 and not the V6 engine mounts. So far it seems OK.
The 70' s T350 (short - 6"- tail shaft) left me short for the drive shaft, but I have another T350 with a 9" tail shaft which I think will allow my stock drive shaft to work again. We'll find out this weekend I hope on how close my measurements were.
Old 06-23-2012, 06:58 PM   #288
Swapped out the short tail shaft T350 for the one with a 9" tail shaft.
stock drive shaft hooks up now. I will probably still need a new driv shaft down the line as it is still about 3/4" shorter than stock set-up was with the inline 6 & 3 speed manual.
What you guys think? Do I have enough yoke inside the tranny or go for a new drive shaft?
I also cleaned up the stock dipstick tube and repainted it. It is starting to look like an engine compartment again.
Old 06-23-2012, 11:20 PM   #289
fakerwade
fakerwade's Avatar
It looks about right to me Bill,,,as you know the yoke slides forward and backward as the suspension travels up and down and as the box is loaded and unloaded. Using the rust mark and the measurements pictured it looks like your right in the sweet spot of the yoke travel. It probably wouldn't hurt to have a driveline repair shop take a look at it just to be on the safe side.
Wade
Old 07-14-2012, 06:00 PM   #290
Little bit at a time.
Been working on putting front spindles and disk brakes on the old girl. Parts came from a 78 C10. It took a while to get the old stuff off. Many those ball joints did NOT want to come loose of the original spindle.
While I am at it I decided that I would test on how the old girl would look with a small bit of lowering. I took and cut the stock HD springs what I think will bring it down around 2". Depending on how you lower guys say it, I took out either 1-1/2 coils or just a single coil. Anyways, measurement wise it's about 2 inches less than the stock spring.
I had to weld up the lower ball join socket some so the ball joints would have a tight fit, but after all the mess, I finally got the driver's side in. I still have to hook up the cross link and the driver's side tie rod ends yet.
Hopefully I'll be able to get started (maybe even finish) on the passenger side tomorrow.
Old 07-22-2012, 06:02 PM   #291
Finished up the spindle and disk brake swap on the 70. 2 goof ups. 1. I didn't measure the distance before (1st picture) I did the swap and cut springs. I think I got between 2 and 3 inches on the drop. I know the from cross member is a good bit lower now. Sitting as she is now with 275/60x15, she is 30.6 inches from the fender lip to the floor.
Two, my quess-ta-met for my new tie rods is a bit off. They both don't go perfectly straight at the moment. Close, but oh well she's not driving anywhere real soon.. I'll tweak that later.
I am glad I got the cross link from the newer truck. That way I was able to use both inner and outer tie rods for the 78 doaner vehicle. Once I get a new MC and a proportioning valve, I'll bend an finish rerunning new front brake lines.
I am thinking about tackling the axle swap and doing a 2" drop block for the rear next.
Old 08-18-2012, 07:22 PM   #292
Re: Pieces
Care package arrived this week.
Master Cylinder and proportioning valve for the disk brake changeover.
and let us not forget
The 2" lowering blocks for the rear
Time to get to work!
Old 08-18-2012, 07:27 PM   #293
Re: Pieces
Cracked the rear open and got ready to change to the 5 lug axles. Just to find a rounded off bolt head for the lock pin bolt
I couldn't get a grip on it, so I tried using the dremel to make it a screw head, then use my screw head on the ratchet. Success, she came out
Luckily I had a bolt from another axle I took apart that I could use on the reassembly.
The 5 lug axles went in without an issue..sorta...more on that in a minute. Now onto the lower blocks.
I got mine and the brake parts from a place called performance on line (POL). They seem good and went on without an issue.
As you can see from the first and last pic, it really moved that rear end up.
Old 08-18-2012, 07:32 PM   #294
Re: Pieces
I had put new shoes on the drivers side then, mounted the new drum and a wheel for look sees.............Then it hit me. Where is the hole to adjust the brakes?.
There is no punch out in the drum like the 70's 6 lugs drums had (and one of the crappy 72 drums I had), nor was there a whole in the backing plate. So now I have to take the drivers side down again, pull the axle and use the 72 backing plates that have the holes in them.
One of them "you are a tard moments".
I didn't even think about changing the backing plates. I just figured they were the same since everything else fit. Oh well. I was looking at the passenger side and thought I had a wheel cylinder leak too, but it looks like I might need an axle seal on that one The seal looked OK, but whatever leaked in that drum, looks greaser than just brake fluid, so might as well put the seals in when I yank the axles for the backing plate changeover.
1 step forward....2 steps back.
Old 08-25-2012, 10:05 PM   #295
Re: Pieces
Well, got the 70 back together again. New axle seals, repacked the bearings, drop blocks in place.
Turns out the holes in the 72 backing plates are for???? as they do not line up for the adjuster. I ended up using my drill and dremel to make a slot in both drums. I thought I took a picture, but I didn't...so it has to wait.
I like the stance with the 2" blocks and the cut springs. These are cheapie rollers, but front is 275/60x16 and rears is 255/70x15.
Not scraping, but compared to when I had the ralleys and 275/60s on all 4 back in 2002, she has come down a decent amount for me.
I was not real sure how close they would be, but as you can see the 2" blocks with 15" ralleys, I better never have a flat while moving I guess I'll eventually be looking for some 17" (or bigger) wheels so I won't drag if I loose a tire.
For now she is tucked away so I can get both the 70 and the 83 in the shop if it gets extra windy and wet here this week.
Old 08-26-2012, 11:02 AM   #296
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Re: Pieces
Truck is relly comming along bill congrats and stay outta the weather headding your way..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 08-30-2012, 06:25 PM   #297
tantrumpipeline
Master Procrastinator
tantrumpipeline's Avatar
Re: Pieces
lookin sweet, came a long way
My Buildhttp://67-72chevytrucks.com/vboard/s...d.php?t=395506
20 Duramax tow pig
68 2wd short stepper project
77 2wd short fleet beater
52 short project
tantrumpipeline is offline   Reply With Quote
Old 08-30-2012, 10:19 PM   #298
fakerwade
fakerwade's Avatar
Re: Pieces
Wow Bill, I go away for just a little while and look what happens,,, progress!!!
Good job on getting that spider pin out. As far as setting your toe (in or out) I've had good luck getting that setting pretty close by using a friend, a tape measure, and a couple straight edges (about 3 feet long). Hold a straight edge (use a board or piece of square tubing) against the outside of the front tire about 5 or 6 inches from the floor (parallel to the floor) and have your friend do the same with his straight edge on the other side of the truck. Then use the tape measure to measure between the straight edge's at the front of the tires and then measure between the straight edge's at the back side of the tires. If the measurement is the same then you have zero toe in or out. If the front measurement is smaller then the rear number then your toe is "in". Ect. Give it a try, it should get you pretty close.
Wade
Old 01-20-2026, 12:15 PM   #299
raggedjim
raggedjim's Avatar
Re: Pieces
Whatever happened with this build? I remember watching it back then.
raggedjim is offline   Reply With Quote
Old 01-20-2026, 01:20 PM   #300
Re: Pieces
I sold the truck back in August of 2013. The person I sold it to redid a lot, but sold it to someone else. I do know not where it is now days. I do know where some of the body panels ended up, but other than that it is gone. The original doors from it are about to end up on my current 70 build.
