Old 06-22-2012, 12:32 PM   #1
1955 mancave
1955 mancave's Avatar
Eng. compartments
i was looking and maybe there is a thread but could not find it.
anyways i'm putting a BBC in my 64 and looking to see any other pictures of these swaps, i would like it to look as it came that way from the general, i don't plan on over doing it with chrome i want it to look like if you lifted the hood of a bb chevell or? just simple and clean.
thanks.
1955 mancave is offline   Reply With Quote
Old 06-22-2012, 01:09 PM   #2
1963c-10
1963c-10's Avatar
Re: Eng. compartments
Big blocks were not available in the 60-66 models. With the exception of the 348/409 engines. You will not find a reference for stock big block engine compartments. There are quite a few threads here on big block swaps that have been performed though. If you went with a period correct block color and painted valve covers, you'd be fine. If you look under the thread...most original truck in existance, you will find plenty of pics of stock engine compartments.
1964 Short bed trailer
Old 06-22-2012, 01:50 PM   #3
1955 mancave
thank you, yes i'm aware that they were not offered in those years, and maybe i put a way that could be confused,
but yes i'm more looking at BBC swaps and how they look. and is there any issues that i need to be aware of before hand.
Old 06-22-2012, 02:21 PM   #4
1963c-10
1963c-10's Avatar
Are you running an auto or manual trans? Headers or factort manifolds are the two big ones. If manual trans, you'll have to go w/factory exhaust manifolds or you'll run into clearance /headers. Most guys running manuals convert to hydraulic clutches to remove all the stock linkage from the frame. Also...if you run headers its not uncommon to have to trim the frame rails 1/2" the length of the headers to allow for clearance. Other than that...pretty much a bolt in process. Im sure some of the BBC guys will chime in. Im dropping in 427 myself in the fall, so I have alot of the info...but have not done the conversion yet.
Old 06-22-2012, 07:14 PM   #5
1955 mancave
thank you, i will be running a 700 R4, i will be converting it over to P/S and pwr Brakes, my idea is at some point to most likley make this my daily driver so want all the comfort stuff i can have, the outside will most likley stay about the same but i want to add chrome front bumper and grill.
Old 06-22-2012, 08:23 PM   #6
coleyperformance
Suscribed as i too am putting in a bbc in my 64 apache
coleyperformance is offline   Reply With Quote
Old 06-22-2012, 08:45 PM   #7
1955 mancave
well when the time comes i will make sure to take many pictures , please do the same and we can post all of our progress
Old 06-22-2012, 10:55 PM   #8
198plus
198plus's Avatar
No problems.........
198plus is offline   Reply With Quote
Old 06-23-2012, 12:46 AM   #9
Chevy Fleetside
Chevy Fleetside's Avatar
No bling in my truck. I have since painted the firewall.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 06-23-2012, 01:08 AM   #10
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Arrow Re: Eng. compartments
Lets see some 1960 - 1966 engine bays
http://67-72chevytrucks.com/vboard/s...=417165&page=1
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 06-23-2012, 10:23 AM   #11
1955 mancave
that looks really nice sitting in there what pwr brake system are you using ?
Old 06-23-2012, 11:37 AM   #12
Chevy Fleetside
That power booster came out of a 79 Chevy truck and is modified to be able to use on the 65. The master is just a wilwood 1 1/8 bore. I have not used the set up yet on the street but I have with the power brake booster and a stock master. I need to repaint the power brake booster black.
Old 06-23-2012, 11:42 AM   #13
ABX131
ABX131's Avatar
Mine is not show quality by any means but it is clean..
ABX131 is offline   Reply With Quote
Old 06-24-2012, 09:25 AM   #14
66farmer
66farmer's Avatar
Hear is mine a little bling. I'm saleing those headers if you need a set.
66farmer is offline   Reply With Quote
