06-24-2012, 09:43 AM | #1 |
Bear claws with thrn down handles?
I did a search and can't find any info on using bearclaws on the 47-50 doors. some body has to have don it.
06-24-2012, 10:57 AM | #2 |
Re: Bear claws with thrn down handles?
I can't see why it won't work but you will have to fab your own linkage. You will probably have to study how the stock setup worked and figure out the linkage that you need to make it work.
06-24-2012, 11:41 AM | #3 |
The Speedway catalog has a "Bear-jaw" kit for 47-51 trucks.
06-24-2012, 12:42 PM | #4 |
Trique makes Altman Easy Latch kits. (The kit Speedway sells) Lots of folks have used them on the forum.
http://67-72chevytrucks.com/vboard/s...d.php?t=520589 http://www.triquemfg.com/Altman_Easy_Latch_Kits.html
51 Chevy 3100 5 Window Build Thread: http://www.67-72chevytrucks.com/vboa...d.php?t=516689 |
06-24-2012, 12:48 PM | #5 |
Nice but too much dinero at 350 bucks.
Thanks Mark |
06-24-2012, 01:44 PM | #6 |
If your only concern with the stock door lock mechanism is the fact they can (and do) have a habit of suddenly opening, a cheaper method would be to use a safety deadlock pin like is used when you suicide a door. Autoloc sells some as do others.
06-24-2012, 03:10 PM | #7 |
altman is a gerat set up but too expencive for me right now. That $350.00 would do more good in other parts.
My dad gave me a pair of Petrebilt latches that look like they would be easy to adapt. I am thinking maybe strip the stock latches and useparts of the lock and parts that support the handle on the inside. I am not sure, Is there a return sprins in the stock latch to keep the handle from saging? Sort of make a replacment that uses the stock mounting. We will see |
06-24-2012, 03:36 PM | #8 |
I've had Kenworth/Peterbilt latches on my 48 since 1981. They cost about 8 bucks each over the counter then but you had to build your own mechanism to operate them. They do take a bit of work to mount but worked great for a lot of years.
I think that a guy might be able to look through a Kenworth or Peterbilt parts catalog and find most of the pieces for the linkage and they might be fairly reasonable. Back to the original question, They would go on the door the same as they would on the 53 and later doors but you a guy would have to figure out how to operate the linkage with a turn down door handle. I don't think it would be that hard to do though. |
06-24-2012, 03:51 PM | #9 | |
Here are some of my observations: - the factory latches do have a spring that return the handles to the horizontal position - the factory latches support the back end of the square part of the handle (inside the door). You have to support this somehow or they will flop all over. - you have to get around the window track while the window is down. This can be done by linkages and a cantilever setup, but gets complicated. Altman had all this figured out, and I spent some time studying the latches when I got them to see how they did it. I was impressed with how they did it, and how clean they kept it. I could have undoubtedly got my setup to work, but it wasn't worth the time and effort it would have taken. If I were to switch to pushbutton handles or to shave the handles it would have been much easier, but I didn't want to do either. Happy customer of Altman easy latches....
build threads: 86 Suburban 88 Jeep 6.0 swap 49 Chevy truck 54 Chevy wagon 86 Suburban lowered 4/6 54 Chevy wagon 49 Chevy/s10 mix 88 Jeep Wrangler rockcrawler |
06-24-2012, 04:32 PM | #10 |
One of my buddies who has a 48 pickup with shaved door handles put the striker pin on the door and the latch in the door jamb and it worked out pretty well. That won't work if you don't have shaved door handles though.
06-24-2012, 06:42 PM | #11 | |
At this point I am thinking that I can remove the exturnal parts from the stock latch and retain the main frame for support for the handle on the inside and the return spring. I also think the stock lock can be used. the door and maybe the jam will need some changes. the doors are going on a 53 so it is a good time to do it |
06-24-2012, 07:02 PM | #12 |
Altman sure has a lot of satified customers.
I already have the parts and I know i can make it work. as bluejeep said the support and spring along with the window track are problems. My problem is I like solving problems. Last edited by mknittle; 06-24-2012 at 07:08 PM. |
06-25-2012, 07:23 PM | #13 |
Good luck and post pictures of your progress! A lot of the factory latches are just metal rotating inside metal, so try not to over-think it there. A little grease on the parts and they should last for years. Also what I looked into (and bought) were those plastic clips that snap onto the rods and into the hole in later model style latches. It was my intent to take some 3/16" rod and use those clips with a cantilever-type setup down below the window level to get from one side of the window to the other. First thought was those little baby heim joints, but there the price adds up quickly.
06-25-2012, 08:35 PM | #14 |
i monkeyed around with a rusty crusty old latch this afternoon I cut the parts that stick out through the door jam and the linkage behind them. I was happy to find that both inside and oitside locks still work. So I decided to take it farther apart. I have a couple ideas about a linkage we will see what happens. Iam mostly working on my rear suspension now.
