Old 06-25-2012, 10:53 AM   #76
J Knight
J Knight's Avatar
Re: combo Tach/Fuel gauge cluster
Jon, I think the its more noticeable on the tach because they didn't add the 5, 15, 25, 35, 45, 55, 65 font to it.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 06-25-2012, 07:40 PM   #77
x ReAcT x
Originally Posted by my4by2 View Post
They're made for the 2-1/2 ton trucks that used the square body cabs. They had an air pressure gauge & a tach, so they had to combine the fuel gauge in. I found mine on eBay & then had it re-done to modern internals & all by Redline Gauge Works.
Does that have metal backing? its original right, so im assuming so. Im curious on how much that whole process cost you if you dont mind
1986 GMC K15 4.3V6/SM465/NP205
will be converting to
5.3LS E-ROD/AA adapter/SM465/NP205
10 Bolt Axle Rebuild Tutorial:
http://67-72chevytrucks.com/vboard/s...d.php?t=536415
x ReAcT x is offline   Reply With Quote
Old 10-13-2012, 01:39 AM   #78
MalibuSSwagon
Just thought you guys would want to see my factory tach:
Found a clean cluster out of a 85 C70. Swapped the pickup speedo in to retain my mileage, and the pickup oil PSI gauge, and lens. It all works the 86 dash connector circuits all matched up too! Best $40 i've spent in awhile.
For those of you who have used the combo tach/fuel gauge, what are you using for a Brake warning lamp?
MalibuSSwagon is offline   Reply With Quote
Old 10-13-2012, 11:40 PM   #79
Joesjunk
Joesjunk's Avatar
Very interesting thread......I might have to get one
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 10-13-2012, 11:58 PM   #80
INSIDIOUS '86
INSIDIOUS '86's Avatar
Brake warning lamp? For ebrake? Pshhh your truck just don't move or smells bad. That's your warning
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-25-2012, 05:34 PM   #81
duane350
How bout pic lit up. Does it light up?
duane350 is offline   Reply With Quote
Old 10-25-2012, 09:39 PM   #82
duane350
insidious 86 where did you get that tach and speedo? I want that.
Old 10-25-2012, 11:34 PM   #83
Jedipartsguy
Jedipartsguy's Avatar
A little off topic but, I thought it is weird that no one ever mentions removing spedo cable from tranfer case or transmission to give more slack when removing guages. Also a quick tip to anyone removing there guages anytime soon, wet sand and buff the clear guage covers. Its a real simple project and so worth it. You can see above insidious 86 has spider webbing on his clear plastic.
"Hank" 78 k10 6" lift 33's, good wrench 350 sm465 np205
Jedipartsguy is offline   Reply With Quote
Old 01-31-2013, 11:44 AM   #84
UATahoe
Will the Gm sports gauge work with my fuel injected 87? Called to ask but they weren't sure if it would or not.
UATahoe is offline   Reply With Quote
Old 01-31-2013, 11:53 AM   #85
Jonboy
Slots go on anything!
It should.
Jonboy is offline   Reply With Quote
Old 01-31-2013, 11:56 AM   #86
UATahoe
That's what I thought. Was kind of caught off guard when they said they would har to call and verify. Hopefully I will hear back soon.
Old 01-31-2013, 04:19 PM   #87
homemade87
It will work just fine. I put one in my truck but I used it with my 5.3. The tach comes with a wire harness that you run direct to your hei dist.There is a place on your dist to plug it in. It is a plug and play for you. I love mine. There is a thread on here that has some good info on the gm sport tach.
homemade87 is offline   Reply With Quote
Old 01-31-2013, 04:33 PM   #88
UATahoe
Cool. They called back and said I would need to run some type of adapter to run it off my coil pack??? I'm thinking I should be good just running it off the distributor right? I am about to swap in a vortec 383 but I am keeping the factory tbi system. Thoughts on this adapter?
I'm located in Huntsville, AL by the way. Small world. Lol
Old 01-31-2013, 04:38 PM   #89
Jonboy
No adapter needed. There is a white wire coming off of the coil that is the tach output. Run the tach signal wire from the tach (mine was brown) to that wire. It should accept a regular female spade connector. Done.
Old 01-31-2013, 04:40 PM   #90
UATahoe
Awesome guys! Thanks for the help! Got it ordered.
Old 04-09-2013, 10:01 PM   #91
duane350
Originally Posted by Jonboy View Post
Maybe the font is a little thinner on the later cluster (91)? I thought mine looked pretty close. Since I wanted it to look somewhat original, I may not have given it the "eagle eye".
Jon: Do you still like the aftermarket tach with fuel gauge? Does it light up?
Duane
Central Louisiana
1985 k10 custom deluxe
1966 gmc
1998 chevy c2500
2003 chevy excab c1500
Old 04-10-2013, 08:25 AM   #92
Jonboy
Honestly, I sold the truck before it got installed. JKnight has his installed; I think he was pleased with it.
Old 04-10-2013, 08:30 AM   #93
Rich84
Rich84's Avatar
I have one installed and I am very happy with it..The only negative thing I would say is that the orange color is a little off..No big deal to me..Otherwise I am very pleased.
Rich84 is offline   Reply With Quote
Old 04-10-2013, 08:44 AM   #94
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Instead of unscrewing it from but "bullet" in the tranny why not just use the quick release on the back of the speedometer to detach the cable?
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 04-10-2013, 08:51 AM   #95
Jonboy
That's how I always do it, unless it has cruise. If it has cruise, I will take it loose under the hood.
Old 04-10-2013, 08:53 AM   #96
J Knight
J Knight's Avatar
Im very pleased with it and it lights up the same as a factory tach or fuel gauge.
I would say not a 100% perfect match to an original it does far out weigh any other option for our trucks for the low cost of $195.
John
Old 04-10-2013, 09:45 AM   #97
homemade87
I agree with JKnight. I have said it more than once that I was way better off going with the gm sports fuel/tach guage rather than spending $250.00 with a factory tack and maybe it worked. Not a factory exact match but it looks great.I put mine in a 91 cluster. Had to have a electronic speedo with my 5.3.Mine looks great.
Old 04-10-2013, 06:05 PM   #98
69GMC910
MOTORHEAD!
69GMC910's Avatar
What is the part you need to run the gmsportssalvage tach with a full msd ignition?
82 GMC High Sierra
VortecPro 496
12 Bolt, 3.42's
AFR 265
Holley 850
Performer RPM Air Gap
Hooker 2455's
TCI Turbo 400 Super Street Fighter
TRRC 12 Bolt
Eaton Posi
Mark Williams Axles
Cal-Tracs
Hoosier 30x10.5 Radial Slick
Full weight long box pickup
Current best- 11.33@117mph
69GMC910 is offline   Reply With Quote
Old 04-10-2013, 06:24 PM   #99
Jonboy
I think there is only one tach. If you have an output for a tach, it should work.
Old 04-14-2013, 07:02 PM   #100
biggsteve97
Well, I finally found a tach setup for my truck. Took almost two years from when I started this thread on 6/17/2011 and here it is 4/14/2013. Geesh. Yes I know I put on the white face overlayment but thats the look I was going for. When I get a chance to take some night pictures I will get those up on here as well. The black box up the speedo and tach which is normally used for diesel engines, has a service engine soon side and a blank side. I have never before seen the service engine soon in that box before and I am very curious as to what truck this bezel would have originally been in. I am using the blank side as the brake warning lamp since that area is not being taking up by the fuel gauge. The second pic is to share the original mileage on my truck. All 437,515 miles. The original motor was pulled at 417,000 though it was still running strong it was just a 305 and could not handle what I was planning for the truck but it served the original owner and myself very well. My girlfriend thinks I should make a coffee table out of the original motor. I dont know though.
biggsteve97 is offline   Reply With Quote
