Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 06-30-2012, 11:21 PM   #1
Marv D
Registered Truck Offender
Marv D's Avatar
Ut Oh......
Ohhh man my heart sank when I found this today
Notice anything a little strainge here,,,, (big picts for the detail)
http://www.small-block-chevy.com/ima...2010/UtOh1.jpg
how about here......
http://www.small-block-chevy.com/images/662010/UtOh.jpg
heres a hint.. look what is laying in the back corner of the air pan
http://www.small-block-chevy.com/ima...2010/UtOh3.jpg
Look close other squirter is wedged in the venturi of the rear carb,,, bu NO screws!!!!!!!!!!!! and no where for them to go but into the motor.
I heard a short knock knock knock as I made the turn onto the turnout road at the last race but it went away and the motor ran fine (10.9x all 119all night) figured just a lifter climbing the adjacent lobe or something. Checked the cam end play last weekend and the Hex-sajust bolts,, no problem. So NOW I think I found th esource
Got all the plugs out and #2 and #5 show hint of damage bit not all beat up. Ordering a borescope to decide what to do here. If the new Dart Littel M block is beat up,, I gotta get busy and get teh chassis cert and the trans cert and a bunch of crap up to date on the Nova!!!
Man this is NOT what I needed right now!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 06-30-2012, 11:30 PM   #2
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Ut Oh......
Wow , that sucks .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 07-01-2012, 12:04 AM   #3
Captainfab
60-66 Nut
Re: Ut Oh......
Ut Oh is right
Hopefully there is minimal damage.
Old 07-01-2012, 02:56 PM   #4
Super73
Super73's Avatar
Re: Ut Oh......
I feel for ya Marv!!
A buddies Fox Body did something similar with a throttle body screw. Very little damage when the head came off. I have been pulling my TB blades out of my TB to drill for more air at idle. Everything I put them in I think about the Fox Mustang. Once I get idle airflow where it needs to be, out with the lock tight.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-01-2012, 05:26 PM   #5
fastwillie 696969
~Rest In Peace~
fastwillie 696969's Avatar
Re: Ut Oh......
any time when metal and metal gets pounded something gotta give ,i drop a small hose clamp down a 454 when removing the intake ,and i didnt see that the clamp fell down the head, until it started to make noise ,tore it down and found the clamp beat into the piston and one valve was crack
good luck
is it fast ? it has a lighting bolt donut?
B___H please, I can remove 90% of your so called "beauty" with a kleenex
fastwillie 696969 is offline   Reply With Quote
Old 07-03-2012, 11:36 AM   #6
GMR-PERFORMANCE
GMR-PERFORMANCE's Avatar
Re: Ut Oh......
Sucks... Whow knows you may not be in much trouble at all.. I have seen some pretty large items go through an engine and never do any real damage A few dings on the comp chamber and piston dome and whoosh they are out the ex system..
Hope it works out that its just minor..
Marv I have a killer bore scope, want me to ship it to you??? no issues brother.. super small probe that you can bend around in a 180 to look at the top or the chamber..
GMR-PERFORMANCE is offline   Reply With Quote
Old 07-03-2012, 10:52 PM   #7
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Ut Oh......
ouch....hope it all turns out OK. Those kinds of things can be expensive.
took me the 2nd pic to even catch it.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 07-04-2012, 12:43 AM   #8
Marv D
Marv D's Avatar
Re: Ut Oh......
Thanks guys. Bore inspection scope on it's way.The cheep ones are not much more than the gaskets to open it up and take a look-see. If it hadn't ran only 0.02 slower after I heard the knock knock,,, I'd be more anal about it. I'm sure a couple of pistons are marred up, as is the head (it's a zero decked motor like that would make much difference). But if there is no screws embedded in a piston, or damage that would pinch a ring against the bore,, and leakdown doesn't show something ugly.... well lots of "if's"
I only have 3 more ADRA races this year (Sept, Oct, Nov) . If it hints of being seriosly wounded,, I guess it's inspiration to get busy with the Nova certs for the last 3 races.
and to all our boys serving wherever you are,, HAPPY 4th of July guys. THANKS!!!
Old 07-04-2012, 02:37 PM   #9
68 C-10 KID
Mean Green
68 C-10 KID's Avatar
Re: Ut Oh......
Marv,
I feel for you. I believe you fall under this old saying if it wasn't from bad luck you wouldn't have any luck at all.
I wish you the best on your inspection.
427 SBC 683HP & 590ftlbsTRQ @ fly wheel.
60'-1.38 1/4-10.43 MPH-124.6
New ET current 4/2019
AKA MEAN GREEN.
68 C-10 KID is offline   Reply With Quote
Old 07-05-2012, 02:53 PM   #10
kpeztruck
kpeztruck's Avatar
Re: Ut Oh......
Marv,
You got me thinking that I need to add carburetor hardware to my between race check list. Ouch!! Hope it all turns out to be minor. Paul
kpeztruck is offline   Reply With Quote
Old 07-06-2012, 09:39 AM   #11
Marv D
Marv D's Avatar
Re: Ut Oh......
Yup,, this motor has been bad luck that's for sure.. It's been through 2 vehicles and both have been a serious money pit!!! I should have known when it came off the dyno at 666HP that it was going to be TROUBLE!!!
Old 07-06-2012, 11:33 AM   #12
Super73
Super73's Avatar
Re: Ut Oh......
Marv, you should have taken a few degrees of timing out out it on the dyno just to teach it who's boss, and that you wount stand for such a thing. But I am afraid it is too late. You have let the possesed motor live on the way it wants to. Now you unfortunately are paying the price
Old 07-08-2012, 09:30 PM   #13
fryco
fryco's Avatar
Re: Ut Oh......
Their all bad luck! Lol! Sorry to hear your having trouble with again.
Can I ask you Marv what you use for a rear gear? We have a fairly similar power and weight, just curious. I'd like to do some test and tune in a few weeks. I have a 3.89 in it as of today (street gear) also have a 4.56 setup. I use a 29 inch tire. Sorry to hack your thread.
fryco is offline   Reply With Quote
Old 07-09-2012, 08:45 AM   #14
Marv D
Marv D's Avatar
Re: Ut Oh......
Was running a 5.43 gear with the last motor (mid 12's) and now a 4.33,, but remember I'm running a 32" tire . Crosses at 6800 @ 119 with my converter
Old 07-09-2012, 07:05 PM   #15
fryco
fryco's Avatar
Re: Ut Oh......
Thanks Marv, best of luck with the bore scope.
Old 07-09-2012, 09:51 PM   #16
VALDEZ
VALDEZ's Avatar
Re: Ut Oh......
Sorry to hear about that, i found my throttle plate screws kept coming loose this season thankfully i caught it in time, not that it would be expensive to fix my cast iron everything stocker haha. good luck with the inspection, fingers crossed!
VALDEZ
1971 C10 LWB 350/350
http://67-72chevytrucks.com/vboard/s...d.php?t=400327
VALDEZ is offline   Reply With Quote
Old 07-12-2012, 09:46 AM   #17
nxtruck
nxtruck's Avatar
Re: Ut Oh......
Wow Marv, that stinks. I hope you don't find any terminal damage.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 07-12-2012, 09:27 PM   #18
Marv D
Marv D's Avatar
Re: Ut Oh......
Welp, bore-scope here,,,, #5 and #4 wounded. 30% leak on #5 and looks to have taken a hit out on the edge of the piston. Can't see if the wall of the bore is hurt or not.
SO she's coming apart this weekend.
The heads aren't leaking , just a 1/2 a dozen whacks in the quench on #5 and one in #4. Looking around for a head that uses the .10/.45 offset like the 220's and decide if were going to upgrade, or weld em up, mill them down and run em. Truck was really fast enough (If there is such a thing)
So , that's that story!!!
Old 07-12-2012, 11:52 PM   #19
Super73
Super73's Avatar
Re: Ut Oh......
Bummer Marv! There is never a fast enough
Old 07-13-2012, 12:57 PM   #20
nxtruck
nxtruck's Avatar
Re: Ut Oh......
Sorry to hear that Marv. Hope you get it back together quickly and as inexpensively as possible!
Chris
Old 07-14-2012, 04:19 PM   #21
regan wilson
regan wilson's Avatar
Re: Ut Oh......
Dang Marv dont you have a Phillips screwdriver ? Just kiddin man . Hope the blocks ok . If it hurt it bad hopefully you can save it with a sleeve. Best case maybe you bent a valve or killed one of the seats.
NHRA Super Street 469C
It only runs 10.90 at 156 mph
I was Dragtruck when Dragtruck wasn't Cool!
regan wilson is offline   Reply With Quote
