Old 07-01-2012, 12:57 AM   #1
Gordonr1973
Home Built '87
Gordonr1973's Avatar
How to fix the spring in the column for the gear lever
Hi;
I've been searching without luck to find a thread on how to fix the spring in the column that holds the gear selector lever taught.
I can see that my spring is broken, but I am unsure how I would go about replacing it....would I have to take the entire column apart to access it?
Any suggestions??
Thanks!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 07-01-2012, 07:13 AM   #2
chengny
chengny's Avatar
Re: How to fix the spring in the column for the gear lever
I did it not too long ago, IIRC I just picked it out with a pair of needle nose. It came out in two pieces. I picked the longer of the two, streched it as far as I could and squeezed it back in.
It isn't great but it's not nearly as floppy.
I found a source that actually sells just that little spring - let me look around.
Found it (well one place anyway) - 18 bucks, that's probably why mine is still loose.
Just the spring:
http://www.steeringcolumnservices.co...ng-2310995.php
and every other column part you could imagine:
http://www.steeringcolumnservices.co...le-pontiac.php
Oh yeah, as a bonus - if you buy a part you also get free access to their repair tutorials.
chengny is offline   Reply With Quote
Old 07-01-2012, 09:25 AM   #3
mopar346
The bone yard is full of them. A column ins't that complicated. A few special tools needed for a tilt but they are available fairly cheap at most parts houses or Harbour Freight. The other option is to get a complete column out of the bone yard and install it instead.
mopar346 is offline   Reply With Quote
Old 07-01-2012, 09:49 AM   #4
Gordonr1973
Home Built '87
My column is alreay painted, that's why I'd prefer to fix it.
So, is there a better way to get the spring out than stretching it?
I have most of the tools for steering wheels / columns.
Thanks!
Gordon
Old 07-01-2012, 10:02 AM   #5
Gordonr1973
Home Built '87
http://en.allexperts.com/q/Steering-...r-selector.htm
http://www.chevytalk.org/fusionbb/sh...hp?tid/271793/
http://www.carcraft.com/howto/56459/index.html
http://www.gm***************/forum/s...?t=3085&page=3
Found some info on other sites, should be good to fix it now. Thanks guys!!
Gordon
