07-01-2012, 10:10 PM | #4276 |
Re: What did you do to your truck today!
Went an looked at another swb step bed today,It needs some work but combining the lwb step bed I have it should make one nice bed.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
07-02-2012, 12:23 AM | #4277 |
optomistic ah-so
I lost my front right hubcap.
Hey, if I don't post a picture then it didn't really happen, right?
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
07-02-2012, 12:28 AM | #4278 |
C/10 junkie
Installed the lower courtesy lights, boy what a difference. Also replaced defrost hoses, not that I need them at this time of year but now the air at least blows onto the windshield.
Shawn 70 LWB C10 current driver/project http://67-72chevytrucks.com/vboard/s...d.php?t=663051 68 SWB C10 Work in progress.....SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=559520 72 LWB C10 Sold 71 LWB C10 Sold 68 LWB C10 CST Sold http://youtu.be/kbB0QrBIs9k My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!" |
07-02-2012, 12:30 AM | #4279 |
I evacuated and charged my a/c with 134a today. It gets cold a I think I have no leaks.
07-02-2012, 12:52 AM | #4280 |
Low68 and I installed the Nolimit Wideride C10 IFS .
07-02-2012, 08:20 AM | #4281 |
Re : What I Did To My Truck Today
I finsally got off my duff and installed my powerbrakes ~ note the correct GM vacuum hose and clips , brackets etc. ~ it took me a while to find the bell crank and related parts , they're in good shape but were nearly frozen having never been greased when new .
Lucky there was no wear , all I had to do was take it all apart & wire brush then grease everything and Lo ! I now have killer good brakes and am happy .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH |
07-02-2012, 08:37 AM | #4282 |
Installed a new fuel pump and replaced the rubber lines while I was at it.
-Scott- |
07-02-2012, 09:35 AM | #4283 |
67cheby
tore it apart !
07-02-2012, 09:46 AM | #4284 |
Tore most of the wires out yesterday since the p.o. spray painted straight over them all... It would be nice if the horn didn't go off when I turned too hard haha
07-02-2012, 12:13 PM | #4285 |
Just a car guy
So far today,
installed plug wires, installed water temp probe, connected carb linkage and such, sprayed primer on new valve covers. Aost ready to fire and break in new engine! Posted via Mobile Device
1955 belair Blown Pro Street cruiser 1971 Camaro Pro Touring 1973 Vega Drag Car 1970 C20 tow rig |
07-02-2012, 02:09 PM | #4286 |
Got my front brake hoses in and found new banjo bolts, and ordered a shiny new set of headers that hopefully fit I had the headers next day aired so that I'll have something to work on on the 4th! Nothing like an American tradition of working on your truck
61 apache |
07-02-2012, 03:33 PM | #4287 |
Oh yeah ~ the brakes was Sunday , to - day during lunch I finally washed the poor old thing .
07-02-2012, 04:01 PM | #4288 |
C/10 junkie
Well I got the motor this far, now just waiting on a carb from Jerry Jones.
07-02-2012, 04:04 PM | #4289 |
Engine looks really good, old style water pump, what year is the engine.
07-02-2012, 04:11 PM | #4290 |
C/10 junkie
Thank you. It's a 1970 Z28 350 with a nice Crower cam.
07-02-2012, 04:15 PM | #4291 |
RAT1968 '68 Cab/'71 Parts
I guess it's the same for all of us. I seem to get about a half or less done than I think I should every "wrenching day".
Today, I planned to get all the wiring done in the cab. Instead, the gage cluster is still out and laying on the floor. But I did get the wiring done and finished for the cig lighter (no smoking in the truck...but it'll get used for all the silly electronic stuff ...like recharging the phone...), glove box light, patch in for the driver's electric seat, finish connections at the fuse block for the windows, panel lights, a couple of grounds, dead-ended a few of the P.O.'s scragglers, and organized the wiring. I'm hoping the gage cluster, aside from the tach connections, will be plug and play. Should be, I've mocked it up five times. But you all know how THAT goes.
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
07-02-2012, 07:06 PM | #4292 |
Today, I got the hood ready for primer (epoxy) in the morning----along with that I got both front fenders sanded down, putty touched up, inside of fenders sprayed with chassic coat---and they are ready for primer as well in the morning. Have to primer early before the heat rises. Within the last week I finished up the step side bed, fenders,tailgate , etc and got the epoxy primer on them . Should get the cab back soon------ my "solid" cab ended up needing inner, outer rockers as well as kick panels and both floor sections. Oh, and work to the air boxes on both sides!!!
1997 shortie stepside 1968 short stepside 1966 mustang 1966 chevelle ss Dont always go the cheapest route--You can save yourself into the poorhouse! My Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=489030 |
07-02-2012, 07:41 PM | #4293 |
Made my own J-Washer for my Zbar. Also found a good use for vacuum hose, makes a nice hole gromit.
Brad handshoe |
07-02-2012, 09:11 PM | #4294 |
You know what, nothing to my truck but a little abuse, used to working on it "every" day for the last 4 months, but today cruised and enjoyed it, finally.
07-03-2012, 03:35 PM | #4295 |
KEEP ON TRUCKIN'
I got my front clip off so I can swap out the old tired crate motor for the 1970 LT1 out of my camaro. Just need to finish cleaning and painting before I can get the motor back in it.
JIM '97 GMC Sierra K1500 '95 Chevy Silverado C1500 '71 Cheyenne Z71 / LT1 & 4-Speed SWB K/10 Father/Son Project http://www.youtube.com/watch?v=4l689JKXPnA http://67-72chevytrucks.com/vboard/payments.php "LIVIN' FREE FOREVER" |
07-03-2012, 05:11 PM | #4296 |
mine is all done and now up for sale
when the smoke clears all your gunna see are my Tail lights |
07-03-2012, 07:15 PM | #4297 |
Why are you selling it, so nice all completed, enjoy it some.
07-03-2012, 07:29 PM | #4298 |
Installed a 16 gal. fuel cell.
Brad handshoe |
07-04-2012, 02:55 PM | #4299 |
Drove it in the parade!
Posted via Mobile Device |
07-04-2012, 07:38 PM | #4300 |
Amazing what getting some help can do...I've been a one-man-show for almost three years on this build.
Today, Butch (who is going to do body work) had a free day so he came to help on some "mechanicals" from the punch list. While I (almost) finished up the under-dash wiring and installed the parking brake and tin cover, Butch chased...and maybe stopped... what I thought was a brake fluid leak, filled the differential, cleaned up the routing of the wiring on the rear harness, started the locking down (welding) of the roll pan. Then, together, we bled the brakes and adjusted the e-brake. A good day.
