Old 07-02-2012, 04:33 PM   #1
CRGRS 66
CRGRS 66's Avatar
Can I move or remove this cross member?
A) Can I remove this cross member altogether?
B) If not, can I re-locate it for my hidden hitch installation?
There was just no perfect spot to place the brackets. The rivet is fine as there is a spacer between the bracket and the frame, but the cross member will interfere with my bolt on the top side of the frame.
Thanks in advance for the assistance
Craigerrr
My build thread, CRGRS 66 Winter Build: http://67-72chevytrucks.com/vboard/s...09#post5638709
CRGRS 66 is offline   Reply With Quote
Old 07-02-2012, 04:36 PM   #2
losthope
losthope's Avatar
Re: Can I move or remove this cross member?
im sure thats the same one everyone moves to install the under bed gas tank upgrade i think it originally had something to do with the spare tire, i would have no problem removing it myself and most likely have to if i put a under bed gas tank.
Timmy D.
"What that grinding noise?Don't worry about that it will eventually clearance itself!"
1966 chevy c10 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=485977
1954 ford customline
H.A.M.B 54 Build Thread:http://www.jalopyjournal.com/forum/s...d.php?t=622142
losthope is offline   Reply With Quote
Old 07-02-2012, 06:09 PM   #3
Greshampiglet
Yes I removed mine to Put my Gas tank in the rear Like Losthope said I've had no issues
GreshamP1GLET
Greshampiglet is offline   Reply With Quote
Old 07-02-2012, 06:20 PM   #4
CRGRS 66
CRGRS 66's Avatar
Thanks! Out with it then!
Craigerrr
Old 07-02-2012, 10:58 PM   #5
Captainfab
60-66 Nut
Yes you can remove it. It was originally there for the spare tire to sit against.
