Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-03-2012, 09:08 PM   #1
Super73
Super73's Avatar
Truck hit the scale today :)
Last time at the track it weighed 3,650lbs with me in it, half tank gas, Full bottle and my heavy 125lb tailgate. It was 51% front (1,860ish) 49% rear (1,780ish)
Since then:
I lost 25-30lbs
Swapped out the 80E/10.5" verter for a PG trans and 8.5" verter
Back halfed the truck with 1 5/8 CM
Put a full cage in it, again 1 5/8 CM
CE Magnum 4-link
Coil overs
Empty bottle, full tank of gas, heavy tailgate and me in it 1,840 (55.7%) front and 1,460 (44.3%) rear for a total of 3,300lbs.
This is full glass, no door panels, no hood, inner fenderwells cut out, no heater, modified front cross member.
With out the gate, it would be 3,175lbs with me in it, but the weight bias will get worse.
The added weight to the gate is in the top, I put the gate down on the scales and the rear axle went up 20lbs from the leverage ratio (scale is only accurate to 20lbs). It will be interesting when I put it on corner scales.
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 07-08-2012, 03:14 PM   #2
chevytruck1970
chevytruck1970's Avatar
Re: Truck hit the scale today :)
Ave you ever went through the trouble to find your center of gravity height?
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 07-08-2012, 03:18 PM   #3
Super73
Super73's Avatar
Not yet.. I am going to get the truck on my buddies corner scales sometime soon and will do it then. We will also be playing with the rear bars a little bit to see how preload affects things.
