Old 07-03-2012, 09:39 PM   #1
widowlane
air bag question
Can you not replace your springs w/bags and air them up like "air shocks" to lower/raise Stance? No pumps or tanks....less $...
widowlane is offline   Reply With Quote
Old 07-03-2012, 10:51 PM   #2
tinydb84
tinydb84's Avatar
Re: air bag question
Using a schrader valve. You have to figure out a way to air up though.
Old 07-05-2012, 11:34 AM   #3
jimmydean
jimmydean's Avatar
There are lots of people running schrader valves. You will still want gauges so you know what pressure you are running per bag and bring a bike pump with you
You could even run a tank with manual valves with no compressor as long as you fill it before you leave the house and don't get switch happy.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 07-05-2012, 05:31 PM   #4
Pro Performance
Pro Performance's Avatar
A lot of guys running schrader valves, and agreed with having a tank that is filled with your before you leave. I always suggest a small portable compressor to carry, just in case you need adjust and no air is around to do so.
Also, we have a 1/4" manual valve air management kit that sells for $575. It is one VIAIR 380C compressor and fill the tank up to 200 PSI. Just wanted to throw that out as an option. Here is a link so that you can see what all comes with this kit.
1/4" Manual Air Management System
Travis
Pro Performance is offline   Reply With Quote
Old 07-06-2012, 10:32 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
There are many way to "rig" a no frills air system. Simply running Schrader valves direct to bags on all four corners is not one I recommend. Thats great for increasing load capacity in the rear, but a recipe for frustration if you try to run it as a low budget air suspension.
Save till you can afford to do it right.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
